40 mph speed wobbles?
Started by 85yotabox, June 25, 2009, 12:49:10 PM
85yotabox
i recently put front marlin 5" springs on the front of my second gen with 2" shackles and im getting some viberations from the front end.  i cant get the tires to stop wobbling back and forth unless i slow down or go faster.  i went through my whole front end and all of my wheel berings and everything is tight and aligned it and still no change. so i took my front wheels to work and balanced them and they only took 4.00 onces each.I was thinking of putting on a steering stableizer on but ive never seen anyone use one before.  is this a common problem or is my front end  :screwy: ?
Chicks dig body damage!
build it to beat it!
_____________________
[  ]===TOYOTA===[  ]
my build:  http://board.marlincrawler.com/index.php?topic=51558.0
Plekto
yeah - sounds like bushings or stabilizer issues to me. All it takes is a little slack somewhere in the steering to get nasty vibrations.
martinez.ryan
death wobble! holly snikies!
Hello Kitty!
wingdaddy
There are a variety of things that can cause the dreaded death wobble. Mine had it for a couple of years. I tried everything, including a steering stabilizer. { it did help a little while } Turned out to be the old tires I had. Two of them had belt separations that were hard to detect. See if someone will let you try 2 of theirs on the front of yours.
Volcom
Good ol' Death Wobble!  Make sure your shackles are tight (but not too tight to bind while flexing), steering arms tight, good tie rod ends, and balanced tires.  I cured mine with hydro assist steering  :greengrin:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Stocker
Gotta agree with either tires, or something worn/loose that you haven't found yet. Steering stabilizer might help mask the problem, but won't fix anything...
My goal in life is to be as a good a person as my dog already thinks I am.
If you don't learn something every day, you're not paying attention.
TacoRunner
There are a few things that can cause this. Check the following or just replace them.
Trunion Bearings
Wheel Bearings this one is very rare
Steering arms are tight
Rodends are not worn out
Check you caster with larger tires you should be around 4-8 degrees personally I like 6
Check alignment to much to-in can be bad
Have you tires balanced
If you dont want todo a Hydo assist then spend some money on a good steering stabalizer. I bought one from FOX for $140 and it was way better than those crappy Rancho ones that lots of people use.
www.4WHEELUNDERGROUND.com
[email protected]
85yotabox
well i just got back from the 'con and realized how much i would benifit from hydro assist so i think im gunna go that rought.
thanks every one for all the info.
[  ]===TOYOTA===[  ]
MiniSimp
Try putting 10oz of plastic bb's in each tire, you'll never have to balance again.
ballzdeep4x4808
death wobbies suck got the same problem did everything that was told to check and do and still got it but tryed using diffrent tires and it was good but tires was to small to run so put the bad ones on and run them at 10 to 15 lbs and seems to be fine at the moment do you think if i run the bbs and put 30lbs of air it well work for now
93tonkatoy
It actually sounds like you may have a tire that is wearing out-of -round. One of my iroks is doing this. shakes from about 40 to 60, then smoothes out. still a little vibe, but not much. from 30 and down, cannot feel any shake or wobble. (and I am running the airsoft bb's)
SAVE TELLICO post 491
Plekto
Had a tire that did that.  Turned out it had separated in one spot (inch bulge in the sidewall near the tread!) and was literally maybe a day or two from blowing out.  Mechanic spotted it when I got my brakes re-done.
If it had blown at 60-70mph...
wingdaddy
These trucks are so lite it makes them extremely sensitive to any imperfection in these larger tires. Most likely will be the problem.
*ROKTOY*
I vote tires, I had the same problem and could not figure it out till I did my 3RZ swap. I had to remove the stabilizer  and of course the shake got worse so I tried swapping  tires front to rear and low and behold no more shaking. Sometimes its the simplest things the ones we over look that fix the problem.
hilux-1983
<James>
Its your tires, air them down to about 10-5 psi and do 40 and see if it still happends if not its your tires.
86 sas'd 22rte, 37 mtr's, 64" Diamond in front with 30spl Longs and Toyota ifs rear with 3' spacers(i try not to think about that part), with 5.29's Aussie front and ARB rear, twin stick 23spl Duals with 4.7 kit in the rear, 4" trail gear springs, 11" bob, custom front and rear bumper,  Best quote of the year: "its so cool, i cant even black out" - (travis shull)
