Author Topic: clutch problems  (Read 2863 times)
bad luck
  • Turtle Points: 897
  • Male Posts: 271
  • Member since Sep '07
  • sas!
clutch problems
« on: Oct 01, 2007, 11:38:14 PM »
 :yikes: my clutch will not fully disengage need help asap  :driving:
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
Re: clutch problems
« Reply #1 on: Oct 01, 2007, 11:58:11 PM »
Master cylinder, slave cylinder or both. Clutch could be worn out. Any free play at the pedal  :dunno:
87 4Runner redo
bad luck [OP]
  • Male Posts: 271
  • sas!
Re: clutch problems
« Reply #2 on: Oct 02, 2007, 12:09:50 AM »
well all i now is that i can push the pedal to the floor like normal but when i try to put it in revers it grinds but will go in gear what do you guys think is wrong   :ack: and the fluid is normal full
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: clutch problems
« Reply #3 on: Oct 02, 2007, 12:17:51 AM »
how long has this clutch been in this truck? might be time for a replacement. does it only grind in reverse? if so, it might not be a clutch issue but a tranny issue. any more info you can give?
bad luck [OP]
  • Male Posts: 271
  • sas!
Re: clutch problems
« Reply #4 on: Oct 02, 2007, 12:22:12 AM »
i was driven it around town today and it just started today and went to move the truck into the a parkin spot i noticed it really bad  :wall:
« Last Edit: Oct 02, 2007, 12:33:36 AM by bad luck »
  • Male Posts: 8,707
Re: clutch problems
« Reply #5 on: Oct 02, 2007, 12:41:41 AM »
mileage on the truck? do you generally drive it hard? any other freak incidents? hows the fluid level of the tranny? you might be able to adjust the pedal freeplay and see if that heps.... my mc used to leak, and i adjusted the rod behind the pedal, never again had a problem with it
bad luck [OP]
  • Male Posts: 271
  • sas!
Re: clutch problems
« Reply #6 on: Oct 02, 2007, 12:47:02 AM »
it has 196xxx miles on it well i catch my self driven it hard some times the trany fluid is full
  • Male Posts: 8,707
Re: clutch problems
« Reply #7 on: Oct 02, 2007, 12:55:09 AM »
has the clutch ever been replaced before?
i drive hard, always, i burned through a centerforce dual friction in less than a year.....
bad luck [OP]
  • Male Posts: 271
  • sas!
Re: clutch problems
« Reply #8 on: Oct 02, 2007, 12:57:23 AM »
tellin the truth i just git the truck a month ago so i really dont now iam bringen it back to life  after siting for 3 years  :eyecrazy:
« Last Edit: Oct 02, 2007, 01:08:27 AM by bad luck »
Jakesteads
  • Turtle Points: -19
  • Male Posts: 842
  • Member since Mar '07
  • It was Nice....
Re: clutch problems
« Reply #9 on: Oct 02, 2007, 07:30:49 AM »
get someone to push the pedal in and see if the slave is moving if not fix the hydralics.... if it is moving have fun putting a new clutch in i just did one and it was a pain in my ass took about a day and a tranny jack
oh when i did my clutch i did new slave new master and new clutch/pressure plate and throw out bearing .... its worth doing it all the master and slave cost 50 bucks total from autozone....
I like Toyota
Tallchevy
  • Male Posts: 3,562
Re: clutch problems
« Reply #10 on: Oct 02, 2007, 10:18:08 AM »
When you get it fixed, remember, the clutch pedal isn't a foot rest. The slightest pedal pressure will wear out the clutch. I had 163,000 on my 3rd gen & never had a clutch  :twocents:
« Last Edit: Oct 02, 2007, 12:16:34 PM by Tallchevy350 »
87 4Runner redo
bad luck [OP]
  • Male Posts: 271
  • sas!
Re: clutch problems
« Reply #11 on: Oct 02, 2007, 11:58:54 AM »
well i have an uncle at kragen hopfuly i can fix it today
91 super yoda
  • Turtle Points: -56
  • Male Posts: 400
  • Member since Sep '04
  • Axe' em Jacks
    • Old Town Customs
Re: clutch problems
« Reply #12 on: Oct 03, 2007, 08:45:31 PM »
196,000 is about what a daily driven yota gets on the original clutch (if its not wheeled heavily), probly time for a new clutch. if the master and slave are good than it sounds like the pressure plate fingers are weak. go ahead and purchase the whole kit, the marlin kit is the best but there are cheaper ones that you can purchase from your favorite parts store (I wouldnt recomend one with rubber dampeners) the next from the cheapest is only about $80.
Replacing the clutch isnt really that difficult, but that also depends on you mechanical ability. If you would rather have a shop do it than your probly looking about $550-$700. I charge a flat rate of $180 + parts and takes about 3 hours.
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: clutch problems
« Reply #13 on: Oct 03, 2007, 08:55:19 PM »
How bad is it grinding going into reverse?  Is it grining constantly, or just when you put it into gear.  If I recall correctly, reverse is not a synchronized gear, so it will grind if the teeth aren't lined up.  Its not a loud or constant grinding, just a real brief one, so if yours is really loud or prolonged, then I doubt that is the problem.  Just another thing to thin about though :thumbs:
              -Ronald Reagan
91 super yoda
  • Male Posts: 400
  • Axe' em Jacks
    • Old Town Customs
Re: clutch problems
« Reply #14 on: Oct 03, 2007, 09:04:02 PM »
correctamundo, reverse is not synchroed.
highridin4x4
  • Male Posts: 237
  • Member since Oct '06
Re: clutch problems
« Reply #15 on: Oct 03, 2007, 09:09:48 PM »
If the clutch wont disengage it is not worn out it would slip. I have seen transmission input seals leak 90w onto the clutch disc causing it to stick to the flywheel causing input shaft to spin until it brakes the suction. I have also seen the pilot bearing seize causing the input shaft to constantly spin.
Scott
bad luck [OP]
  • Male Posts: 271
  • sas!
Re: clutch problems
« Reply #16 on: Oct 04, 2007, 07:33:11 PM »
i just found the problems its the slave cylinder and the clutch is burnt up so i got a new clutch kit but havent goten the slave cylinder yet  :brick:  :pokinit:
toymech
  • Turtle Points: -155
  • Male Posts: 158
  • Member since Feb '05
Re: clutch problems
« Reply #17 on: Oct 04, 2007, 07:42:04 PM »
  Possibility you have the clutch disck in backwards causing the clutch not to disengage. The clutch hub where the springs are face out. Theres always a possibility the clutch fork has a problem but that would be pretty obvious.  Hope this helps.   Mike :turtle:
87 Runner-rebuilt 22re,3 inch downey ifs lift,allpro rear bumper,Detroit locked rear with 4.88s,detroit true trac front diff,Marlin crawler clutch,R151F trans,Marlin Crawler 4.7 reduction gearset,33 inch Goodyear MTRs
Plekto
  • Turtle Points: 27
  • Male Posts: 863
  • Member since Aug '07
Re: clutch problems
« Reply #18 on: Oct 05, 2007, 02:45:37 PM »
Replace the master and lines while you are at it.  It's always good to do it right, IME, and it's one less thing to have to pull apart later.  (50-$60 more, iirc - not much $$)
Last post Feb 12, 2009, 10:08:38 PM
by toyomr285
Last post Jul 14, 2009, 01:39:09 PM
by hotrod
Last post Aug 05, 2010, 06:38:10 AM
by 79coyotefrg
Last post Mar 07, 2012, 03:03:03 PM
by UndefinedTaco
Last post May 16, 2015, 01:53:20 PM
by AaronB
