Is this a new master cyl or a used one?
I had my slave go out on me, and I bled it, and found out I was bleeding it wrong. I thought that if you pushed the pedal down, and then crack the bleeder, like a brake system, it would be fine. But I found out, to bleed a slave, you have to crack the slave, and then push down on the pedal, then tighten the bleeder, then let up on the pedal.
I still have a soft pedal, but I also need to replace the master, the plastic bowl is cracking and soon to give out. Plus I have the stainless braided line for the slave. Which I got from
![Marlin Crawler Turtle Logo :turtle:](https://board.marlincrawler.com/Smileys/marlin/turtle.gif)
which I will install at the same time.
