Lizard Toy 2
Started by Lizard_lips, August 02, 2007, 03:36:24 PM
Lizard_lips
Well my bro traded his 4runner already. He was going to swap running gears but ended up trading for some toyota truck thing. Here's some pics when we got it home. It came with an extra cab on the back and we took it with the truck. anyone want it? It came comeplete with a 22re-i believe a w56? 5 speed- dual toy cases w/ 4.0 in the rear case. 4.10 thirds with an ifs rear. the springs are stock but some drop spring hanger thing. see
The rest of the parts were another rear axle shaved with discs, 3" spacers or something for the front. brand new 5" trail gear springs, trail gear dual crossmember. 5.29's front and rear, arb front, spool rear, brand new longs and chromo inners, arb compressor, a couple driveshafts, and some lame ass 35's. here's some pics of the truck as it sit right now with some rollers on it
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
Lizard_lips
So far all thats been done was thats I installed the dual cases and the crossmember. We used trail gears dual case crossmember. I'm not sure that I like it though. We'll see what happens. I might just make something. The plans have changed again. he'll be putting toy rears front and 52" chevy springs rear but will be selling all the toy 5.29 arb & spool diffs, longs, 5" trail gear springs, rear housing thats been shaved, front axle rebuild kit w/ bearing, new marlin seals, vented rotors, arb compressor and what ever else I missed. He'll be getting the sky's fullwidth kit and swapping 1 ton drivetrian in it. anybody interested in this shtuff
Lizard_lips
here's some of the crossmember
Lizard_lips
here's some pics of the rear. I installed some 52" chevy springs in the stock location to get about another 5" of wheelbase. Still need to install some 2" blocks and it should be alright until we link the back. those c channel shackles are on there until I make some other ones. I bought it with the bling shackes at no extra cost   :greengrin:
Lizard_lips
hopefully i'll have my thirds and the longs sold soon so I can pick up some one tons. I've never had a truck this small before. It looks retarded with rollers on it.
Duffil
did you pick this thing up in Modesto CA?? I swear I saw that thing on a truck over by the 99 hwy...I passed him and he pulled into a gas station.
Lizard_lips
I picked it up in oroville. drove down the 99 going back to vegas. it was a long trip. I stopped in medesto to drop off some chevy springs and stuff.
Duffil
I saw you!!! You pulled in to the Chevron off of Pelandale and 99, right?  I passed you in the left lane and looked over at you... :whythis: that's weeerd.  I was gonna pull in and chat...wish I had. :down:
Lizard_lips
Yeah I was there. I belive I saw your toy drive by. well maybe I saw some guy drive by with a marlin sticker but I can't remember what it looked like. you shoulda stopped. We don't throw sticks or anything at people.
Lizard_lips
here's some finish pics of the rear suspension. well except for the shacles. I need to make different ones.
Lizard_lips
Did a little work yesterday. Took the dash out of the other cab to install part of it in this one.
I need to cut some holes for the ac lines because the truck doesn't have any on it. I also cut the floor and installed the shifters for the dual cases.
I also upgraded to some bigger rollers  :greengrin: pimpin the 33's haha ::)
tom w.
I didn't know you were in vegas, man
Lizard_lips
still in vegas. what about you? you in vegas also?
tom w.
about an hour away from vegas
Lizard_lips
95SAS
i think ive seen you selling some stuff on RME. the toy is looking good
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
tom w.
Lizard_lips
Quote from: 95SAS on August 06, 2007, 02:18:45 PM
thanks, it should start taking form once i swap some fullwidths on it and get rid of the cab
Lizard_lips
logandale has some pretty good wheeling.
Lizard_lips
Did a little bit to the truck again. I put some block in the back and a longer brake line. I tried to drive it with the driveshaft on since I made that work now and the truck wouldn't. I think it's a fuel thanks for the help gtoyonrocks
I have a fuel pump I can put inline. does anyone know if this will work?
Duffil
what pump do you plan on using? it has to meet the pressure and GPH of the OEM pump.
Lizard_lips
not sure if it's the pump I had another one and I don't think the pump is getting and juice. it runs nice spraying some gas down the intake though.
It still sounds like a sewing machine compared to my old 350
Lizard_lips
sweet. it works. Replaces some fuses. moves some wires around shook the truck and bam it starts haha. more pics once I get home from work again
Lizard_lips
I'll be dropping off the cab on the bad at the scrap yard unless someone wants it. just take it away i need it gone by this weekend. then I'll be testing the flex and probably gonna weld the diffs and see how much I can wheel. anyone have a spare driveshaft for dual cases they want to sell?
Lizard_lips
#24
Thanks, I ended up getting it to work. I replaced some fused, kicked it, cursed a little and it worked. I didn't do much on the truck  yesterday. I cleaned the cab out part of the way. I also test drove it and checked out the low range in it.
here's some pics. here's one of the rear suspension.
and one of part of the dash. I'll be making a custom dash
here's some pics of the overall truck
Lizard_lips
Haven't had much progress lately. I took the cab down to the recycling place. got $18 for it.  :greengrin: put some fluid in the cases. drove it around. still need to make some front springs. I got some center bolts for them. I'll be picking up some fullwidth axles here probably this weekend and then swapping them under. here's some pics. I'm not sure of the wheel base. it should be about 115 or so I'll have to measure
DTB
nice clean slate to work with there...cant wait to see whats in store  :biggthumpup:
Lizard_lips
well I'll be puting some kind of tube bed on it or something. I gotta get this done and my other rig done for an even at the end of november. Hopefully it'll be done.
Lizard_lips
my bro picked up some axles for it today. He went with a ford 9" rear and actually a 10 bolt up front. since he couldn't find any 1 ton axles and he wanted to get his rig done. the axles have 5.13's hysteer front, locked front and rear. gonna be swaping them in either today or tomorrow hopefully.
Loosekannon
