Lizard Toy 3
Started by Lizard_lips, August 21, 2007, 11:15:35 AM
Lizard_lips
Well it looks like I'll be in a mad dash to get my rig going now that my bro's is done. I need it done by the first weedend of november. I picked up booger weldz old chassis a while. here's some pics of it when we loaded it on the trailer. with some axles and rollers.... even though they are 38's
and one when I got it home
I'll be swapping in a 4.3-th350 and either a dana 300 or dual toy cases or something. I haven't made up my mind.
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
Lizard_lips
so far the only thing I've done is modify the front spring hanger for a fullwidth axle.
I have changed my mind and need to redo it again. I'll be moving it forward a little more.
Lizard_lips
The suspension will be toy rears front. possibly 51" rears. depends on how far forward I want to go and 1/4 ellips in the rear using 57" fords cut in half using the long side. the shackles have felx joints in them. with a dual triangulated 4 link. Here's a pic of the rear axle. with my 14 bolt truss and pinion guard on it. not sure if i'm using it yet
Lizard_lips
no pregress  yet. I did get some parts. 8 flex joints, I still need to get some bushings, I also got some link brackets from poly performance and also some adjustable brackest from ballisticfabrication.com and welded them up.
cool deal, same brackets i got from Ballistic.
Lizard_lips
They seem pretty good. I just need to make the link and mount the drivetrain and then set up the links. Take a guess and hopefully wheel it when I'm trying to get done.
Lizard_lips
#6
well absolutely no progress lately. moved into another house. I did pick up a cpi 4.3 and a jet th350 and 4.7 tcase. selling the t-case and adapter and going with 23 spline dual cases. the motor mounts should be here soon hopefully and I'll put it in.
DeadlyPeace
Sucks that you haven't been able to work on your rig. Nice engine you got, hope to see pics of it in soon.
Off topic:
Was just noticing your sig and was wondering....... What if all three of your best friends are insane?
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
Never let people think you're a horrible person and always keep the heart of a young child...
       ...I prefer mine in a jar on my desk.
3 CAT scans a MRI and some time with the shrink and it's comfirmed. I'm just not right in the head.
Global Moderator for www.ToyotaOffRoad.com
Lizard_lips
I've wondered that too. possibly the neighbors are retarded like mine.... I mean insane
Lizard_lips
Put some 38x15" boggers on it and took it to my new house. Should be built pretty quick now
Lizard_lips
Got the cases yesterday. 23 spline front and rear cases. with a 4.7 in the rear case. Marlins 10* rotated adapter, marlin 23 spline inputs and tripple drilled flanges.
Should have some updates after this weekend
Lizard_lips
I have the motor in but no pics yet. It was cold and dark.
Here's the cases
Kinda prepped under the hood, with the gm master cylinder
Lizard_lips
Here's some more updated pic.
Motor mounts in
The motor still is going to be moved back about 3-4"
Front spring hanger
Box and steering
Lizard_lips
Got the adapter and the cases in
tom w.
Sweet. I haven't seen this until now...
Lizard_lips
I haven't been able to log in forever.
I should have some more updates tonight or this weekend. Getting rid of the 44 and putting a 60 in.
Jud
Looks like a cool project.
"bout tree fiddy"
Lizard_lips
tubing material. 1.75" DOM .250" wall, and 1.5" DOM .250 wall.
Radiator I'm using. For a nova or chevy II
28" wide, 18.5" tall and 2" thick at the radiator and 3" thick at the tanks
Doof
welder2000
Hey Lizard lips what pitman arm is that and does it have less drop than the Marlin one? The rid looks sweet.
83 toy Clovis, CA
toywthbdydmge
looking good bro keep the pic's coming  :beerchug:
Lizard_lips
The arm is from sky's offroad. with 3/4" less drop then stock drilled for chevy 1ton tre's
I'm not sure about marlins arm. I've never had one.
Some updates for you all. Here's some pics of the rear tubework
I'll have the rear axle sitting about where it is when I'm done
Under the motor
Sky's offset shackles
Waiting on the 60
to put in
Doof
looks good. what bender do you use for that tube work?
DeadlyPeace
Looking good. You have any special light you plan on using in the rear or just some standard aftermarket ones?
Gittinit
Quote from: sillywilly on January 27, 2008, 10:52:42 AM
That was origonally one of boogerwelds buildups. It has come a ways since those days.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Doof
o so its seen it share of trial time then?
Lizard_lips
yeah it's booger welds old rig. I'm rebuilding it and going to push him down the trails at the hammers.
For the rear lights I was going to use some 4" led's
Lizard_lips
1/4 ellips buckets.
Cut the rear axle off. Swapping it with my other axle on my other truck. Need to build the truss and weld the link tabs on.
Lizard_lips
Got the 60. I just need some spring plates and ubolts.
Lizard_lips
making room for the new tank.
