Lizard Toy 3
Started by Lizard_lips, August 21, 2007, 11:15:35 AM
Lizard_lips
Almost got the axle in. I need shorter bolts for the passenger side. But got it most of the way in.
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
DTB
Quote from: Lizard_lips on February 10, 2008, 07:58:32 AM
cant u just cut the ends of the bolts off?
Lizard_lips
not enough thread to thread it in and cut the rest off to put a nut on or just use the rest of the bolt. I'll pick some up today or tomorrow.
Lizard_lips
no updates yet. I got some more parts again. 14 bolt disc conversion parts,
some air bumps, they were converted from air shocks. 5" travel
and some bling high steer arms
Lizard_lips
Some updates over the weekend. Put the discs on the 14 bolt. Going to start The link truss today. They clear 15" wheels. I can't remember what kit it is but I'm using ruff stuff bent brackets.
mounted the 60 all the way. Mounted some 38's. Still haven't gotten the single wheel hubs.
Doof
looking good dude... keep up the good work.... :afro:
Jud
That thing is soo WIDE
"bout tree fiddy"
Lizard_lips
i need to get some srw hubs and it won't be so wide. Also need to get some gears and a detroit or something for the 60. Still working on the truss for the axle and frame mounts. should have more updates after today hopefully
DeadlyPeace
Awesome work. Though rear disc should be nice.
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
Never let people think you're a horrible person and always keep the heart of a young child...
       ...I prefer mine in a jar on my desk.
3 CAT scans a MRI and some time with the shrink and it's comfirmed. I'm just not right in the head.
Global Moderator for www.ToyotaOffRoad.com
Lizard_lips
They were cake to put on also. The hardest thing was loosening the bolts for the axle
Lizard_lips
Got some work done yesterday.
lower link crossmember and mounts I might have to modify it a little to clear the driveshaft.
Front range rotated crossmember
Everything mostly in place. The cases might go a little higher.
Lizard_lips
Some more work done over the weekend.
Upper frame link mounts. STill going to beef them up a little more.
Lower link crossmember in.
Started the axle lower link brackets.
Got the lokar shifter in after modifying it a little. And the 2nd case shifter. I still need to get a shifter for the crawl box
Lizard_lips
a few updates. Finishing up the rear suspension. The rest of my joints should be here tomorrow. Then I'm working on the wiring. Still need to finish bracing the rear truss and caping the front and rear of it.
whats with your last pic... is that a upper link brace?
toylife
sweet project. wedont have many rocks here in va that the crowd i run with go to. we put a 351 roller in a sammy with toy axles 4 a mud bog. we run mud bogs ant alot of trail riding throught timber cutovers. crawlin over downed trees and stumps :yikes:,up red clay hillsand swamp bottoms. most of the time we put that size stuff under blazers and shortbed fullsizes. i love the way yours is done i am workn on put cut fullsize axles under my 93 toy. hopefully it will be as easy as you make it sound. :thumbs:
only in a yota
Lizard_lips
I'm caping both ends front and rear of the truss. Then bracing it more. it's just the start of the truss
Quote from: Lizard_lips on March 25, 2008, 09:26:08 AM
sweeeeeeeeeeet
solar86yota
Looks like a fun project! Love tha huge Marlin Sticker Accents, keep up the good work, oh and Chevy 4.3's are great motors! I think that would be a good choice for a swap. An sbc is overkill in my opinion, not to mention horrid mpgs.
By the time I get the money for an SAS I'll be 65 at this rate!
Lizard_lips
Yeah, I have a 350 in my other truck with 400hp. It makes it fun.  :greengrin:
Lizard_lips
more pics of the truss. still going to brace the middle of it
and my front links. 4130 chromo 7/8 heims, going to be replaced with some new ballistic joints
uppers 1.5"  .250 wall
lowers 1.5"  .250 wall sleeved with 1.75 .120
Lizard_lips
some more updates. Took the toy cases off. Sold the dual case adapter, rear case and crossmember. Getting an adapter from OTT to put a dana 300 behind the first case. Just waiting on parts again.
Lizard_lips
Some updates finally. Got the adapter I still need a c clip for the output shaft. Hopefully I'll have it all in this week.
And the dana 300
Lizard_lips
Here's some updates finally. Got my 32 spline front and rear outputs. twin stick stuff. CPI harness and computer. greatlakes 14 bolt cover.
Had to redo the lower link crossmember
toy-dana 300 doubler up for mock up.
been working on my little brother matt's jeep Here's some other crap I got in for it.
32 spline front output for the dana 300
cpi 4.3 harness and comp
great lakes cover. Thick stuff
Reynolds
MMM gotta love the smell of flux core in the morning :D What welder are you using? Looks good!
-Brian
Lizard_lips
lincoln 175 I think it is or 185. I forgot I could check but I'm too lazy right now.
OOO new parts, i thought you died or something.... id like to see this HEEP you've been workin on.
:worthless:
Lizard_lips
Heep... you mean jeep haha
Been building my little brother jeeps as well. I haven't started a build on here yet of it. I could I guess. There's one over on pirate. No update on it today though. Got my srw 60 hubs. Gonna put them on along with my steering tomorrow.
Quote from: Lizard_lips on October 06, 2008, 09:49:53 PM
Nope, i meant "HEEP" lol
(I'm not a Jeep Fan)
i wana see pictures and updates.
link to this pirate build?
