Lizard Toy 2
Started by Lizard_lips, August 02, 2007, 03:36:24 PM
baconator
oh ok... gotta keep them happy.  i live out in BFE so i dont have to worry about them.
check out the first project from Born Crazy Customs
Quote from: MrsWillyMammoth
OK so we got the thick bacon... but RK can't find the salami... and Deans wife has the cheese...
Lizard_lips
yeah they frequently send letters saying we have engines laying in the driveway. Or my personal favorite. The engine has fallen out onto the driveway. I don't know what that means.
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
baconator
haha that sucks... :headscratch: how does an engine "fall out"?
Lizard_lips
no idea. I had one blow up on me while driving on the freeway out to an even. It blew out the bottom but it didn't fall out.... but they wanted to fine me because it had fallen out and left on the driveway?
Lizard_lips
Did a little work on the truck this weekend. Welded the front spring hanger on
I moved the spring hanger an inch or two forward.
Lizard_lips
I might be puttin some 44" boggers on it. Hopefully the the guy will get back to me
Lizard_lips
Ordered some sliders today and a pitman arm from sky's the chevy tire rod ends.
Hopefully getting them soon and putting them on. I need to get working on this. But still waiting for parts
Lizard_lips
Here's some front shots. I got some sliders and a box mount and hopefully the rest of my steering will get here soon. Should have the sliders, gm master cylinder and brake lines, and steering this weekend
tom w.
Lizard_lips
I'm just tryin to get it done for an event here and then I'm tubing the rear and linking the rear
tom w.
Lizard_lips
coilovers most likely. 4 linked tubed and tied into an incab cage or something.
tom w.
Are you gonna try to keep any kind of a bed or anything? or just full tube?
Lizard_lips
well I don't have a bed right now. I'll be making a tool box holder for it and a spare tire mount just for the events.  But I might pick up a bed for cheap tube it out and see if I can some how put the skins on. But then again. We'll have to see
Lizard_lips
Some pics from the weekend. Got the sliders on, the 2" body lift. My steering hasn't shown up yet. made the plates to adapt the master cylinder, removed all the stock brake lines and found out that the lines and fittings and everything I had didn't work so I need to get new brake lines again. I'll have some better pics of things later
sliders
and the gm master cylinder
toyotaexo
looking good making good progress
Lizard_lips
Thanks, My steering still hasn't shown up. I need to call them so I can atleast drive it down and have a rear drive shaft made. and then finish the front square driveshaft. I'm selling the crossmember and going with a front range offroad crossmember instead to push it up and make a flat belly.
Lizard_lips
here's some recent pics. More of the sliders. I made a temp crossmember and sold the trail gear crossmember. I'll be using a front range offroad one with a flay belly.
started layin the brake lines and everything. It's going for driveshafts should have it back in a few days.
Lizard_lips
Finished up the truck. Never made the event I was building for. The front driveshaft was late and ended up making one and then had problems with the calipers. They were leaking so I went to pick some up at the junk yard. Here's the pics.
Line loc ran into the cab
Front range offroad crossmember. The crossmember's great. I'll be moving it up about another inch or so.
square front shaft
ford shock towers and 12" travel rancho's
box moved forward, sky's pitmar arm
Finished pics of the truck
Lizard_lips
#79
some wheelings pics. There wasn't many obsticles I could find. It was too dark and I haven't been out where I was in about a year. The pics are bad but oh well
and some of my old rig, the last time i'll be driving it.
Lizard_lips
Ended up going with some 38x15 swampers grooved. And when I ordered the wheels they screwed up again and now I have 2 white wheels and 2 black wheels. UPS took forever and the driveshaft was supposed to be here friday and never was. I ended up making one and didn't have the right flange for the transfer side and the calipers were leaking and wouldn't seal. I ended up picking up some at the junk yard and went to register it and went wheeling.
tom w.
Those tires look small on there...
What event were you tryin' to make?
Lizard_lips
It'll have one tons soon and 44's or 42's. I was trying to make a local event called hump and bump. but ups sucks and delivered the driveshaft to the wrong place so I had to waste time making one when I could've been doing the brakes andran out of time.
BNRSHNTZL
that truck is bad a$$!!! cool pics :bowdown:
tom w.
Quote from: Lizard_lips on November 06, 2007, 02:22:33 PM
Yeah I thought about driving over there, but figured it'd be kinda gay since i couldn't actually wheel. If i can get some gas money, I might go out there this weekend.
Lizard_lips
yeah I'm going to try and plan something out there with some guys. I have another truck I want to build but probably going to sell it and get something else. You live in vegas? Hopefully i'll go out again soon and have better wheeling pics. Been really busy with things. so we'll see
tom w.
I live in moapa. I need to get out and get some drivin' done so that when my truck is more capable, i'll be able to actually use it.
You should let me know when you come out, might be kinda cool to meet you and hang out for a minute or two.
Lizard_lips
yeah. I'm down for that. I'll keep you posted about that. Hopefully I should have some more wheeling pics soon. Atleast I will on turkey day.
tom w.
toyotaexo
who's adapter for the master cylinder did you use? or did you make it
