I think he is preping his axle for the swap. It shows he has a 93 4runner.Scott
well if you have a 85 then you already have a solid front axle, SAS= Solid Axle Swapwhat it sounds like your talking about is getting the brake rotor off the wheel hub (where the wheel lugs hold the wheel to the axle)you dont need to remove that to get the inner bearing out, the seal is all that keeps the bearing in there when its not on the trucklook at the outer bearing that fell out on the ground when you took the big nuts off the spindle, if it doesnt look like its about to fall to pieces then most likely your inner bearing is fine tooif your rebuilding the axle you just need Marlins Knuckle rebuild Kit
i want to take it off any way because marlins sas kit comes with new rotors. or do i use the ifs rotors and wheel hubs? so how would i seperate the wheel hub from the rotor?
yes you want to remove the rotors, i didnt realise you were putting the 85 axle under a 93 4runner,yes you will use Marlins rotors so just remove the 2 bolts then either press or using a drift drive the studs out try not to mess the threads up
thanks for the info i would have been pounding those studs out with a hammer
do i have to set my gears and lockers before i put the axles and the knuckles back together?
Since you're doing a SAS and you'll have the torsion bars removed, use the torsion bars (as a really long punch) and a small sledge . The extra weight drives the studs out in a big hurry and since you're hitting the torsion bar and not the stud directly you greatly reduce the risk of damage to any of the studs. You can even stand up and drive them out with the rotor on the floor... . If you decide to keep the torsion bars for future use as tools, you can cut one in a 1/3 and 2/3 length and have 3 different length punches. They're quite tough too being they're made of spring steel .
Yes, your locker will have to be installed, and your gears set.It goes like this:Empty HousingInstall 3rdInstall new bearings/races and sealsSet bearing preloadInstall knuckle backing rings/felts/sealsInstall Knuckleand so on. The FSM has all the information you need as far as rebuilding it properly.
after the third do my axles go in ?
No, after the 3rd, then your knuckle bearings/races, then your knuckles, then your axles, then your spindle, then your rotors, then your hub.
do i need that snap ring plier to get in to the manual hub? or can i do it with some flatheads
so it s like hammering the studs out just with an extension to prevent damage to the studs. i was almost going to pound directly on those studs.
No, you want Lock-Ring plyers
ive done it with 2 flat screw drivers but its a PITA
Lookin good so far Do start with the diff though... that is the center and work your way outward towards the knuckles and wheels
im just going to buy a detroit locker and a set of yukon 529 all ready to go so i could just bolt it on.
i understand that i just gotta save a little bit more so i could buy the third member thats already set up with detroits and yukon gears. is there any place where its cheap to buy that third setup? or would it be cheaper to get the parts seperate and get it installed proffesionally?
Started by Benge Scott Project Research and Build-Ups
Started by alyssa2004 Engine
Started by Kurlee Daddee Toyota Pickup/4Runner Tech 1979-95
Started by naga_81 Toyota Pickup/4Runner Tech 1979-95
Started by Red October Newbie Questions
