Author Topic: Solid Axle Rebuild Questions  (Read 3570 times)
Benge Scott
  • Male Posts: 30
  • Member since Aug '02
« on: Oct 01, 2002, 01:00:10 AM »
I'm going completely through a 1985 Solid axle replacing all bearings and races including those for the knuckle pivots.  Looking at the factory manual for reassembling the knuckle they use a SST (special service tool) to select the shim spacing for the bearing caps.  From what I can figure, this effectively aligns the inner and outer axles to within tolerance and gives you a measure of how thick a shim to stick in.  My question is, other than using the SST from Toyota, how to you set the shim spacing?  The first and obvious answer is to reuse the old shims but I'm replacing the bearings and seats which negates this approach.  Appreciate your thoughts.
Benge
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
'88 SR5 4Runner, 3.4L swap, SAS with Marlin 3.5" springs, e-locks front & rear with 4.88's, Marlin Dual Crawler with Twin-stick, drive shaft e-brake, 33's on 16" rims, tube sliders & rear bumper.
Paul_Elbisser
  • Turtle Points: 43
  • Male Posts: 329
  • Supra Powered
    • KraZyfly
Re: Solid Axle Rebuild Questions
« Reply #1 on: Oct 01, 2002, 02:23:12 AM »
Are you using KOYO bearings? This is what Toyota uses from the factory.  The shims are there to make up for the differance in the housing castings. The tolerance in the Bearings are alot better than the axle casting, so if you use the same brand bearing it will be the same size as the old. Just use the old shims in the same place they came from.
Paul Elbisser
PastTLCA Eastern Rep,
Pres. Rice on the Rocks
One of Those Guys
cruzila
  • Go go cruzila!
  • Hawk
  • Turtle Points: 41
  • Male Posts: 3,848
  • MC20/21 Toybox #002 2.28 = 154:1
    • MTA
« Reply #2 on: Oct 01, 2002, 04:24:21 AM »
As Paul said :up: Also, you can check the preload without the tool. Add or subtract shims from the TOP to get it set right.  :beer:
hawaii500_1999
  • Turtle Points: -7
  • Member since Jun '02
  • Watch this!!!!!
« Reply #3 on: Oct 01, 2002, 07:04:46 AM »
i put the originals back in the same way they came out when i changed those bearings.  i did use toyota bearings.  haven't had any problems.  it's been 4 years and about 80,000 miles.
« Last Edit: Dec 31, 1969, 04:00:10 PM by -1 »
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
Benge Scott [OP]
  • Male Posts: 30
« Reply #4 on: Oct 01, 2002, 12:12:10 PM »
Thanks Fellas, Yeah, I'm putting in Koyo bearings back in the knuckle so after thinking about the problem more and with your inputs, by reusing the original shims that I pulled out I should be o.k.  Again, appreciate your inputs.
Benge
Last post May 02, 2007, 04:47:09 PM
by twistedtoy92
Last post Oct 12, 2007, 08:45:47 AM
by atoyot
Last post Dec 13, 2007, 04:08:02 PM
by 84pickup
Last post Oct 22, 2009, 01:49:39 PM
by Dark Knight
Last post May 02, 2019, 08:25:49 AM
by 83_P/U_4x4
