ive had two toyotas and i always seemed to have a problem with the starter cylanoid sticking after it got hot. and now in my crawler after running it for a while and everything warms up if i stall out or turn it off it just wont start until the truck cools down or i bang on it enough where it knocks itself loose, it sucks gettin stuck in a bad spot when the truck dies. so has anyone heard of this or hae any suggestions, all would be appreciated.
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
yeah ive been gettin rebuilt ones from like kragen and auto zone, ill go to the dealer and see if that works
NAPA has some good rebuilds, i've always had good luck with them!!
otherwise ill go to napa.
Go buy a rebuild kit from the dealer. A lot cheaper than a new starter and its not hard to do
yeah ive gone through 3 starters with this truck so maby ill try a heat shield or something
I've seen the bendix gear stick out and burn up the starter on toyota cars that haven't been in the mud or water. The usual culprit is the starter relay sticking closed. Sometimes the solenoid on the starter will just stick for no apparent reason though - on these cars, I still replaced the starter relay. Better safe, then sorry.
Started by guywithuglyyota Engine
Started by JDouglas Parts Wanted
Started by KDXSR5 Toyota Pickup/4Runner Tech 1979-95
Started by superyota General 4WD Discussion
Started by offset442 Newbie Questions
