Different starters for 22r/re?
Started by superyota, September 20, 2011, 02:48:40 PM
superyota
My starter started clicking a while back and I put a new one in it.  I put the old one in another truck and it has no problems tried swapping it out again.  I'm wondering if it's something with my wireing.  I swapped starter back around again and same thing.  I have tried jumping the solonoid wire over and it still doesn't start.
Also, I have noticed that some starters sound like they crank a lot faster than others.  any idea why or what the difference is in the starters?  I had a buddy lose his starter on the trail over the weekend.  it has always been a really fast cranking starter.  replaced it with a napa starter and now it cranks slow.  any idea's/suggestions would be appreciated.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
crazykooter
They all should be the exact same but a good power wire to the starter would make it crank faster.  It sounds like your power wire to the old starter was corroded or something.
gtoyonrocks
have you checked to make sure it's getting power, good power, and that when you turn the ignition switch to start the truck that your getting power to the plug? I had one truck I had contact issues on the plug but after cleaning it was good as new. This should be a simple fix. Good luck.
yota13
Toyota a reliable friend that never let's you down and loves to keep on truckin
emsvitil
You can take the solenoid apart and check/clean or replace the contacts.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
dirtybird
I think there is 2 different starters one is an hd version.
91 ex-cab
When I replaced my original starter with the non hd napa version it cranked slower, but was still getting the same voltage as before.
Joey88RUNR
I have had several toyotas in my time, everyone of them had the starter click problem. I have never bought a new starter for any of them its a 5 dollar repair to remove the solenoid contacts abd replace them. good as new... kinda!
