Low & Slow Quad Cab V2.0
Started by Talon84x4, March 14, 2007, 04:59:51 PM
Bobby Hunter
Quote from: Talon84x4 on February 29, 2012, 10:49:34 AM
The float is just on a metal rod which can be bent easily.
I keep hearing this but I still don't understand? How, in what way do you bend it?
Tech head for 2nd gen Runners
Talon84x4
Quote from: Bobby Hunter on March 01, 2012, 07:12:53 PM
Here is the ford sender
Inside the tan plastic housing is where the fuel pump is located, i removed the pump and ran a tube to the bottom of of the tan housing. The sender float which in this picture is shown pointing away from my hand is modified, the stock float arm normally would be hanging out where my hand is in this picture. It doesn't read quite as accurately but it reads in the right direction for the toyota cluster now and will at least let me know when i'm getting low
stock ford sender (version i used on left)
Central Valley Crawlers
Bobby Hunter
Talon84x4
finally got around to the rest of the weber 32/36 install
had to throw together a little wiring extension for the elec. choke and fuel cut off
and a bracket to relocated the throttle 1" over and 3/8" up
also a helpful link, where I was able to find all the missing parts I needed: http://www.carburetion.com/
and the adapter plates for the 22r intake were from LCE http://www.lceperformance.com/Weber-32-36-38-Carb-to-20R-22R-Manifold-Adapter-p/1033027.htm
working on a sketch for the dash too, may get that up later
Talon84x4
have been keeping busy:
cup holders for some FJ40 half doors
also started on build a dash for my truck, mine was cracked and I want to try my hand at making my own. It hasn't had a dash since the cab chop and i'm tired of looking at the wires and naked cluster
i've found packing the pipe with sand works best  :twocents:
i was able to get a pretty good fit for not much work
Talon84x4
currently working on some tacoma half doors for a friend:
he wanted them at arm rest height and to keep the stock mirror location, cuts made accordingly
started with the cap template
double checked the fit
cut and bent the cap to match template
shaped and tacked my way from one end to the other
Talon84x4
#786
fully welded cap
top latch (this will be getting moved back to the inside now)
cup holder
3" exhaust tube, cut a tab inside to hold cans/bottles from rattling around
relocated exterior latch
flap disc'd all the welds, now ready for some filler & primer
BirdDog
Looking good Talon. Mine are next, I hope.
Talon84x4
Quote from: BirdDog on March 22, 2012, 05:48:33 PM
Thank you. I have you up on my board and my schedule opens up on the 2nd
kycrawler
Quote from: Talon84x4 on March 22, 2012, 04:32:56 PM
fully welded cap
cup holder
Really nice work on those doors, around here we cant keep our doors free from dent from all the trees.
Talon84x4
Quote from: kycrawler on March 23, 2012, 11:01:45 AM
Thank you, these are the cleanest set of doors i've worked on, most are hiding damage
theslayer85
I like all your side projects.  They turn out way sweet.  Any progress on the 3.4 swap or your doors?
Talon84x4
Quote from: theslayer85 on March 30, 2012, 08:29:48 AM
Thank you. The 3.4 swap is on hold, don't have the money for the rest of the parts. The doors are on hold as it's warming up here already. Worked on the carb this weekend, going to take it again to try to smog it...again. Whenever it finally passes the list will go dash, sliders & bumpers, spare carrier, doors.
theslayer85
oh the never ending saga, no money.  which we have to work for, which brings us the money but in return we then have no time.  Most of the time I have no money and no time.
Toy-Cra-Ze
Nice rig you are pretty good at fabbing stuff!!
Talon84x4
Thanks guys, not a huge update but:
As far as smog, found a thermo-switch that was bad that diverts the smog pump air, looking for a solution that doesn't involve the $130 dealership solution.
Finished off the tacoma doors a while ago, don't have a finished/painted pic just primed
Made a small 12" press break for bending brackets, works great
bad example but here's the first test on this dash flange
In the mean time got something done i had been meaning to do for quite a while now. Plated my front frame rails and new shock hoops:
I also added a leaf to each of my RUF packs, gained 2 inches so now i've got a comfortable 5" up travel so that's a big improvement on what it was before. Bump stops will be next
OOOO new stuff. looks good too Talon.
Talon84x4
It's been a crazy past few months but here's an update. (I took some time off of this, my mom passes away late last month from cancer at 45...too young.)
Dash is done
included some switches for the rock lights
$20 string of 20 LED pods I picked up a while ago, found them in the LED lighting thread in general 4x4 discussion (pirate4x4), they will also be interior lighting
plan for interior lighting
going to start to lift the rear 2" today, doesn't look like it in this pic but it's sagging a bit after i re worked the front, doesn't even have weight in it yet so needs to be fixed
In a couple weeks I should have enough to get the material for the sliders and rear bumper, my new goal is to have it armored enough to try to make it to the Marlin Crawler Round Up in Sept.  :crossed:
John Doe
Amazing work. I am looking forward to possibly seeing it in person at the round up. I know it would be nice for you to get out and wheel that thing.
Toyotadon
That dash is looking good, but are you thinking of adding any padding anywhere?
Now you need to redo your inclinometer image, LOL.
Talon84x4
Quote from: Toyotadon on July 23, 2012, 01:43:42 PM
I am thinking of adding a pad on the passenger side, i'll also be adding a retractable handle bar for the passenger
Quote from: John Doe on July 23, 2012, 12:02:15 PM
I'm really hoping I can make it, i've never done the rubicon before so a little nervous as to how capable my truck is for it. And It would be very nice to get to wheel again, it's been much too long.
Gotta hand it to you Talon, You have my favorite Toyota build on the MCF.
Props to your fabwork, talent, skills and having a one-off-4door yota buddy.
Keep up the amazing work.
Also, sorry to hear bout your mom. she is definitely being taken care of.
Now on with the fab :flamer:
Dereks83Toyo
yo bud your dash came out awesome i remember talking about it when u first got the truck u wanted to take it out and build one :pokinit: looks amazing cant wait to get another rig and do some wheeling again.
:beerchug: :thumbs: :thumbs: :thumbs:
derek e
Russell_G
WOW i love the quad cab...Where have i been that i missed this?
87 longbed bobbed 12inches, locked,geared,Tacoma dash, 3rz swap Its a never ending project.
My build
http://board.marlincrawler.com/index.php?topic=58589.0
Bigdady
Sorry for the loss of your mother, I feel your pain. Lost mine last year and i know how ya feel.. Nice build and you got some talent brother..
1980 toyota swb, 35 km2s, 529s, elockers f/r, trussed f/r. ect.
Talon84x4
Quote from: Dereks83Toyo on August 03, 2012, 12:43:48 AM
Yeah it has been a long time, I remember driving around without any dash when I first got it on the road just trying to get the motivation to just get it done
Quote from: Bigdady on August 03, 2012, 11:08:57 AM
Quote from: Russell_G on August 03, 2012, 01:22:54 AM
Quote from: THK Matt on July 23, 2012, 03:26:08 PM
Thanks guys
small update:
Started on the sliders
The main rail is 2x5 1/4", kick out and legs to frame are 1 3/4 .120 wall. Still more to do but they're coming along
Have a list of things to do before the MC round up:
-Pick up some spare birfs & axle shafts
-Turn out steering stops
-Rear bumper & recovery points
-Rear shock hoops & replacement shocks
-Front bump stops
-Rock lights (will be heading in late)
-install CB
-Some interior lights
John Doe
Sliders look great! I really like the use of both rectangular and round tube.
Nimyad
Looks good! I love those doors. I'll probably steal the design when I make my tube doors.
Toy-Cra-Ze
I really like those half doors! Nice  truck too!!!
