Low & Slow Quad Cab V2.0
Started by Talon84x4, March 14, 2007, 04:59:51 PM
Talon84x4
Quote from: Peterbuilt84 on December 03, 2011, 01:15:23 PM
It might have been covered, but did it pass smog with the new tank? Do you think it was worth it? Run into any other problems? I never liked the placement of the stock tank and it looks like the swap isn't too hard.
It hasn't passed smog but not because of the tank, but because of my numbers. I pass visual
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
Peterbuilt84
Sucks to hear, thanks for the info.
IVrunner
Do you plan on putting the gauge cluster from the 3.4 in yours or wiring to custom gauges or making it talk to your current cluster?
~Josh
-87 4Runner SR5 - SAS, 4.88's, 33 KM2s, Lockright front, elocker rear, frenched hangers, TG in front, 63's in rear (DD)
-2010 4runner Trail (wife DD)
-2000 4runner 4WD manual Highlander -SOLD:(
-1986 Toyota pickup SAS on 35s -SOLD
-1985 4runner (first car) -SOLD
because of your numbers? what numbers?
BHT12
I just went throgh your whole build and from page 7 to 26 i didnt read a thing.. i was too eager to see all the pictures.. I have no words that describe your fabricating skills.. your insane..
:respect: :respect:
Where do you live? if i ever drive through that area i want to stop and see this thing. i have a hug amount of respect for you. Crazy
:rockingout:  :thumbs:  :king:  :clap:  :clap2:  :beerchug:  :bowdown:  :yikes:
1984 4runner. Trailgear fronts, custom backs with shackles, 36 iroks, hi steer, hybrid 20+22r motor, full exhaust, lowsy weber, power everything, rear heat, power Antena,  sr5, altimeter,  back seat eliminator, tube bumper
1981 2wd long bed parts getter. All stock, sr5
1983 Toyota Sandtana Motorhome 4x4 Stock.
Talon84x4
Quote from: IVrunner on December 05, 2011, 06:15:38 PM
I have the cluster from the tacoma, as well as the column which after working on the wiring for my friends 3.4, getting the 3.4 column eliminates a lot of wiring headaches
Quote from: THK on December 05, 2011, 07:45:00 PM
In CA we have to pass a sniffer test, my numbers are too high in 2 areas and still trying to figure out why
Quote from: BHT-ToyotaDude112 on December 05, 2011, 08:19:27 PM
Thanks, I try to post a lot of pictures, they describe things much better than I can. Hopefully this next season you'll see it on the trail
Oh gotcha, bunk deal buddy. they didnt tell you possible problems to cause the high numbers?
Talon84x4
My truck is test only so apparently they're not allowed to give repair advice
thats retarded. try a different ref?
theslayer85
Quote from: Talon84x4 on December 03, 2011, 12:01:18 PM
Here's one of my earlier posts:
As far as getting it running, I pulled the old fuel pump from the sender and just extended and draw tube down in it's place within the sending unit. I also flipped the float over in the other direction so that the fuel gauge would read in the correct direction. Any other information you're looking for?
Also here's the pirate thread, I found which tank to get from reading this: http://www.pirate4x4.com/forum/showthread.php?t=484247&highlight=ford+gas+tank
This is what I needed.  I called a junk yard looking for a tank and they asked if I wanted a front or rear tank, and I had no idea.  Thanks for the help I am hoping to get a tank soon and get it all figured out.
Toyotadon
Quote from: THK on December 06, 2011, 10:38:21 AM
By CA law, the Test-Only Smog station can only perform tests.  They cannot even recommend a specific shop to perform repairs.
BTW, I have been helping a little bit with the issues on this truck.  It has a lean condition, and so far we've found the EGR Tube gasket leaking and a faulty Vacuum Advance on the distributor.
GONZO97
Quote from: Talon84x4 on December 06, 2011, 06:31:01 AM
i would take it to a shop that isnt test only have them test it and then get their recommendation on what to do it, my buddy did that for me and i had no problems passing after that
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
Talon84x4
Looking for some advice..
Smog is really kicking me around and I'm tired of the headache. I am going to try to fix one more issue on my carb and see if anything changes. If nothing changes i'm tempted to just pull the entire motor and sell it off to pay for parts for my swap. The motor is great and has been running better than ever as far as power but I'm just having a lot of trouble getting it to pass and I don't know if it's worth the time and money when i'm just going to swap it out anyway. What do you guys think?
id agree. why put more money into something you plan on swapping out.
BHT12
i think its time for a 2.7... o r what ever else your planning
Quote from: BHT-ToyotaDude on December 17, 2011, 04:28:10 PM
he hasa 3.4 already
BHT12
Zs Confederate Toy
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
BHT12
Yota87Truck
No updates?  It's been over a month now...  How's the 3.4 swap going?
Talon84x4
Quote from: Yota87Truck on January 24, 2012, 07:36:18 PM
The swap is on hold, I haven't been able to source any parts that I need for it and I don't have enough to buy a package deal from any dismantlers  right now. I either need a smoking deal with someone parting out or 1700 to get everything else i need including trans in a package deal.
That being said have been kept busy with other things aside from work. Made some gifts in december:
a sword for my brother out of an old leaf spring from my stock toy front pack I had laying around (sorry for the sideways pics)
he's a big fan of Skyrim so I engraved some stuff into the paint
finished up an old art project for my mom
and whipped up another leaf spring sword...this one I kept
heated and flattened
ground & sharpened
and decided to blue this one
Zs Confederate Toy
Those swords are kick ass! I have been making a hunting knife out of an old Bronco leaf.
ZACH
87 Rock Rat X
Trail Junky
Sparkplug
thats some pretty sweet metal work man, i like it alot :thumbs:
Talon84x4
as far as this month goes I built a couple more tables, more shallow to fit up against the wall and will be building metal storage into them later
picked up some more work, made a winch mount for this FJ40, 1.75 tubing and 1/4" plate, 8 bolts into frame & bumper
all finished, painted, and mounted
next it will get removable sliders
Talon84x4
Thank you, I just ordered some parts for a used weber 32/36 dgev to put onto my truck, I'm hoping that I will have better luck with this carb and that the truck will finally pass smog
Talon84x4
Small update regarding that spare carrier I built:
The owner was able to get it to unlatch while out on the trail a couple times on a snow run. I thought I had addressed the issue but wheeling puts forces on things that you can't always predict. Good news is the stop pin worked but suffered
the old was cut off and a new beefier pin and slide made, almost twice as thick and gusseted
as for the carrier popping open, I was able to torque on the spare when it was mounted vertically enough to re create the force that opened it. The gate would twist enough for the latch end to twist out from under the cap and let the pin jump out of the hole. So to keep it from twisting I extended the stop tab
and then welded on a hook to grab the tab and keep the gate from twisting away
after that I could not get the gate to open with the same force as before so hopefully that solved the issue completely.
For my 84 I was able to get the weber on and all hooked up, only thing left are some wires for electric choke and fuel cut off and I should be ready to start again with tuning and attempting to pass smog
Yota87Truck
I hate emissions.  That is the only big thing keeping me from driving my 78 as a DD work truck.
Bobby Hunter
I want more info on the highlighted, and how big is the tank? Thanks!
Tech head for 2nd gen Runners
Talon84x4
The tank is about 19 gallons. As far as the highlighted part: when you pull the sender the fuel pump is housed in a reservoir. If you pull that apart you find the pump inside, mine was bad and didn't want to buy a new one when I didn't need it. So I just replaced the pump with some tubing so that it would still draw from the bottom. The float is just on a metal rod which can be bent easily.
