Project "RAWHIDE" a High School buildup !!!shackles installed no pics.....yet!!
Started by Rainer, February 26, 2007, 04:24:27 PM
Rainer
Well ive decided that im going to gte new rings for the bad cylinder, new head gasket, and anyhting else i need. My friend from work came with me to my house, and he said its most likely rings, so he is going to help  me drop the oil pan crank and redo timing. So my next pay check will start the epoch!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mark
!!!FREEDOM IS NEVER FREE!!!!!!!!
1985 Toyota 4runner
22re rebuilt(offroad cam, internalls from enginebuilder)
5.29s with elockers f/r (high pinion front, v6 rear)
3inch suspensions 2 inch body
33 inch mixed tires. (bfg at, firestone at?)
weirdtimes_7
nice nice... keep us posted and don't forget to take a lota pics
military_stang
:respect:
Rainer
OMG!!!!!!!!!!! I just adjusted my idle bolt on the throttle body, and now the runner runs, rich, but runs!!!!!!!!!! It must have came alittle loose. So itwas running at 500 rpm and when i gacve it gas it must of starved and died. Now idleing at 1000 rpm it wont die after i floor it to 3-4 grand!!!!!!! IM SO HAPPY!!!!
Here are some pics!
MARK
1985 Toyota 4runner
Rainer
Unfortunitly, i cracked the little guy so i need a new one, any ideas were i would get it? Toyota dealer?
Mark
1985 Toyota 4runner
weirdtimes_7
Thats good, really good. But there is still a concern that you may have a bad head gasket. I wouldn't push it to hard untill you have determined if you have a bad head gasket or not.. you might blow her up if you don't find out
military_stang
:respect:
Rainer
Well on a compression test, bubbles would be coming up in the radiator, and i saw none, so im ruling out bad head gasket.
Mark
1985 Toyota 4runner
854RUN
#156
Hay man do you have the big vacuum hose for the throttle body, i see it not hooked up  :headscratch: if its not hooked up it will not run or will run like poo
-JOSH-
fatt_matt
Quote from: Rainer on May 30, 2007, 07:28:13 PM
Mark
why would it do that??? just curious...
Jeep
Rainer
Hey Josh, that hose i removed to get to the bolt better, it is reinstalled now. You doing anything this sunday? Could you help me? It runs now but seems to be miss firing alot. I dont know though.
Quote from: fatt_matt on June 01, 2007, 07:59:53 PM
When the head gasket is leaking air goes through the block into the cooling system. Im not sure how, but in my training in engine perf. I learned that.
Mark
P.S. im grounded from driving except to and from work for the entire summer. I get to do something i want in my car once every two weeks, due to a D in math. I need a B average in order to drive, my summer is kinda screwed.
1985 Toyota 4runner
fatt_matt
good luck man, on getting that B.. what math are you taking???
i dont really wanna go looking through the whole thread again,   but where are you in colorado???
Jeep
Rainer
Arvada, right outside Denver. Oh i didnt get the B that is why im grounded for the whole summer.
Mark
1985 Toyota 4runner
fatt_matt
damn... that's harsh...
you're out of school   already???
i got like 1-2 more weeks..
Jeep
Rainer
Yeah i got out on thursday. So iw ork full time now as well. MOre money to invest in my runner. LOL
Mark
1985 Toyota 4runner
GA Runner
i just got an 89 4runner and i was wondering what kind of axel u had in the front cause i was gonna change my front axel. thanx
89' 4Runner
Rainer
MY axle is the stock 85 axle that the 79-85 toyotas have.
Mark
1985 Toyota 4runner
854RUN
Hey Mark, grounded for the whole summer for getting a D, wow i was lucky to get D's in school, except for auto class (A's) lol.
-JOSH-
Rainer
Yeah Josh, I got 1 A, 3 Bs and a D. I had a 104% in auto class. Well im grounded from driving, only to and from work i can do. Every two weeks i can take my car or truck and do something i want. Other wise i can still do stuff, i just have to be picked up or meet somewhere. I have the truck almost fixed. I cant figure out the last problem.
Mark
1985 Toyota 4runner
fatt_matt
Jeep
Rainer
Yeah, it runs now, it just miss fires really bad. Also when im drivig it feels like it just revs when i get to 3k-4k rpms, like no power.
Mark
1985 Toyota 4runner
854RUN
As far as the miss fire goes, that sounds like a timing issue (cap, rotor, plugs, wires, timing) did you replace any of that stuff. so when driving when you hit 3k or so dose it feel like an instant power boost? If so it is most likely related to the time issues you are having.
-JOSH-
Rainer
NO when i hit 3k it just lags. I replaced my plugs, and thats it. Should i replace the distributor?
Mark
1985 Toyota 4runner
Vic stuff
start with the basic stuff, plug wires, cap, rotor, get your timing set.  sucks about bein grounded, wow dont miss those days, lol
84 4Runner - 37's, Locked F/R, 4:1 (single), Cab exo, new front bumper and some more tubage coming soon! Currently parked with a blown motor :(
05 Explorer - The Wife Mobile
04 Chevy Silverado - Towrig/DD
854RUN
-JOSH-
Rainer
I did my timing last night. WOW is what about 10 degrees behind. SO i set it ten degrees in advance. It idles better now, but it still miss fires really bad. So im going to replace my cap, rotor, and plug wires. Hope that will fix it.
Mark
1985 Toyota 4runner
Rainer
Well im stuck, i replaced the cap, rotor and put performance plug wires on the runner. Well it still miss fires really bad. This sucks! I need help. Here are some pics.
Mark
1985 Toyota 4runner
Jud
Your #'s 3 and 4 plug wires look like ther switched around!
"bout tree fiddy"
Rainer
I just got some Marlin Crawler rock sliders from a guy in town, brand new for $100. Im not sure what would be the best way to mount them? Any help would be great, maybe some pics as well would be nice. I think im going to bolt them on, not sure how though.
Mark
1985 Toyota 4runner
DTB
weld them on...plate the frame where you weld them and use gussets on the tops of the legs
use jackstands to hold them in position when welding (another person helps to hold too)
the plate in the pic is straight, a 45 degree turn or fishmouths would be better though
Rainer
I removed my intake manifold today, look and tell me what you guys see. I see anti freeze in my manifold? My injector electric plugins all suck balls. What to do? Hey DTB where can i get those plates? Is there fuel pressure in the fuel rail with the manifold off? I want to remove the injectors but will fuel poor out?
Mark
1985 Toyota 4runner
854RUN
http://cgi.ebay.com/ebaymotors/Toyota-Pickup-Truck-4Runner-22RE-INJECTOR-PLUGS-1987_W0QQitemZ320127850981QQcmdZViewItem?hash=item320127850981
if the truck as been sitting for a bit and not ran you should be able to pull the fuel rail and injectors with out fuel spraying all over. That look like antifreeze or the green mud u sucked up  :yupyup: .
-JOSH-
