46&2's 85 4Runner Build-Up
Started by 46&2, January 14, 2007, 06:55:22 PM
John Doe
Quote from: THK90 on May 29, 2009, 03:30:36 PM
now if you could only get some of my wimminz on all over your truck...... hmm.... :rofl:
I think we all need some of your wimminz all over our trucks.
46&2
Haha I got one woman thats enough for me hehe
why have one when you can have 5! MUAHAHAHAHAHA Jk.
I got one :P
46&2
That was fast!!! :woohoo:
Time to get to work....
46&2
#575
Update: Everything is almost back together but then.... a snag.
I always used to have a hell of a time shifting back into 2WD with my rear tcase. Turns out my rear case high range shifter shaft was bent to hell, not sure how. Anyway, tried to straighten it... and in the process busted the forks and its still bent  :smack:
So far I have not been able to find one locally. There are still a few more shops I am going to hit up later this week but I figured I would get the ball rolling on this.
So if anyone has a spare top shift case they have maybe taken apart or for some reason don't need the high range shifter shaft, LET ME KNOW!! I want to get my junk rolling and this is the only thing stopping that at this point.
:beerchug:
Thomas P
i think i have one here in magalia, i will have to look..........
'14 Camry SE
SCX10 Honcho on roids!
46&2
Quote from: Thomas P on July 11, 2009, 12:36:50 AM
Sweet, let me know. Still no luck locally, found one online but I'd rather just deal with something local.
Jud
I ahve a foward shift rail... Probably wont help though.
"bout tree fiddy"
-Matt-
take a picture of it, i have a few shift rails laying around.
46&2
Cases are back together! Just gotta find time to put my Marlin clutch in and then put the tranny and duals back in. After that I need to get a new gas tank that doesn't leak, get new tires, and take care of a few odds and ends, like fixing my gay rear window that won't roll up and down for some reason. I know the motor is good, I think the wiring is screwed up somewhere.
Quote from: fortysixandtwo on August 25, 2009, 04:46:22 PM
try the console switch :D i had that problem in my 85 and in my 90.
everytime it was the console switch
peacesells
Quote from: THK90 on August 26, 2009, 12:07:40 AM
X3, 84, 86 and 89, All console switches.
this my man lysol, fresh out the joint
Jud
push on the tail gate on the top left corner. When mine wouldn't roll up/down I would have to get out and use the key while pushing the gate in.
"bout tree fiddy"
John Doe
Try the tail gate, and make sure you check the relay box behind the drivers side B pillar. I blew that a few months back.
Thomas P
slam the tailgate hard, then push in the middle while rolling it up.......
'14 Camry SE
46&2
Well last winter I was doing donuts and I slid into a snow bank in reverse going like 20 mph, my tailgate got dented in and my window couldnt roll down. so I popped the dents out. But a little plastic piece that holds the window wiring up against the tailgate so it doesnt get caught by the window broke, so I gorilla taped the :pokinit: out of it to try and keep it out of the way. It worked for a couple months then would get harder and harder to roll up. then the console switch stopped working and only the key in the tailgate would open/close it. sometimes I'd have to jiggle it into just the right place to get it to work. then it just stopped outright. key doesnt open it, nor the switch. I havent messed with it at all since it stopped working so I need to go back through and check out everything you guys mentioned. when you guys say 'console switch' do you mean the switch itself is bad or the wiring that goes to it?
John Doe
either is possible. I would get a test light and see whats hot and whats not, then go from there.
Quote from: fortysixandtwo on August 26, 2009, 02:22:02 PM
im meaning the switch itself.
cause I know if that switch is not connected you cant use the key switch at all.
so when that switch goes out... it hinders the key switch.
ajordan1975
when that happeed in mine i just wired a toggle switch up and never worried about it again. couldn't use the key to roll the window down anymore but i never really used it any way
46&2
Went and picked my cases up from my buddy's shop today. Thanks again Kyle  :beerchug:
This is Kyle's first gen Taco he just recently got done building. Its bad ass. He is running D60/70, a gear drive tcase with Marlin 4.7s and 41s on 20" rims. Hes working on a full exo for it right now.
46&2
Normally I am not a fan of 20" rims on crawlers but that actually looks pretty cool. He said he only got em cuz he scored the rims and iroks for $400. I'd prolly do it do thats a deal.
thegoofster21
#593
i like it looks damn good
3rz or 3.4
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
46&2
ajordan1975
thegoofster21
so you getting it all back together
jmoffroad.com
46&2
Quote from: thegoofster21 on September 03, 2009, 07:01:32 PM
Yeah in the next few weeks I will get it driveable and then back on insurance again.
thegoofster21
sick we will have to do some wheeling. i still got the tacoma. :beer:
jmoffroad.com
46&2
Quote from: thegoofster21 on September 03, 2009, 08:31:02 PM
Yeah the plan is to get it rolling and back on insurance to do a little snow wheeling and actually be able to get out of my driveway once a good snow storm hits this winter.
