what you need to find out is if you have an 8 inch, 8.4 inch, ect rear axle and front axle
I think it might be easier to start with tranny, i found out it is R151F, 5 -speed manual, dont know if it is same as in early Turbo Taco. Maybe same development version? Anyways, that might be something worth to investigate... ?
an r151f is a common tranny, i have one, however there arent any lower gears availiable for these, what we do is lower the low range gear set in the transfer case and axle to achieve a lower gear ratio. if you have a 151f then you may have a common transfer case that has parts availiable for it, or you could just buy a gear drive case from marlin built with lower gears as it will bolt up to your 151f easily.
Ariman,I'm gonna go out on a limb, and say if you have a passenger side drop on the Tcase, you DONT have the same 7.5" front diff that we have in the Tacomas (95.5-present years).
why donīt you contact Arctic trucks (Icelandic truck builder company) they are located in norway http://arctictrucks.com/
yea he has a chaindrive pass side output, with the same 7.5 front diff as the 86-94 runners had hereA09B A is supposed to indicate 7.5" 09 is a 4.22:1 r&p B=4 pinionhowever in your case i believe A 09 B indicates 7.5 in front and 8 inch in rear
Note that driver's side/passenger side varies throughout the world! For our discussion here, the driver sits on the left side of the truck.The ribs on the rear diff thirdmember make me think it's not the "normal" 8" diff, but my understanding is that the Hilux running gear was the same as the preTaco, about a generation behind what we got here in the USA. For example, solid front axles were available until (at least) 95.ariman - If you could take a pic of the front diff, we could tell a lot. If it's the older "chunk" version, it will be easy, if it's the newer "clamshell" version, it might take some more research.
what I am saying about arctic trucks. They should have all the info about these trucks.... I know there is at least one Icelander over there that knows his stuff... Haraldur Pétursson mabe you should try and reach him.
I will contact someone tomorrow to figure this out... you need to know about your diffs ? right is there something else you wanna know. you have a 2002 hilux with a 2.5 diesel
Started by HellbillyDeluxe Project Research and Build-Ups
Started by Polo New Member Check-In!
Started by BOGAN Rig Gallery
Started by klunk Toyota Pickup/4Runner Tech 1979-95
Started by Hilux92 Engine
