Author Topic: 4runner bob is it worth it?  (Read 6505 times)
TRHS1980
  • Turtle Points: 2
  • Male Posts: 234
  • Member since Apr '06
Re: 4runner bob is it worth it?
« Reply #30 on: Dec 08, 2006, 12:25:22 PM »
Seems like your doing it right... Under "Don't use smileys" there should be an area to attach an image, not sure why it's not coming up for you. Maybe one of the seasoned veterans will hop on with some additional advice   :dunno:
2007 Tacoma 4x4 6-speed on 35's
"In all affairs it's a healthy thing now and then to hang a question mark on the things you have long taken for granted."
TrackVino
  • Turtle Points: 45
  • Male Posts: 1,038
  • Member since Oct '04
  • Rocking and Rollin with Marlin!!!
    • DCD Photo Studios
« Reply #31 on: Dec 08, 2006, 06:42:56 PM »
The frame is pretty easy, what you have to do is make sure you have the tail gate on, and open, make sure you cut the frame back far enough to clear the tail gate, otherwise it will not open. You will have to cut the rear hangers off. then add a second piece of square tubing under the frame to extend the frame. this is where you will add your rear spring hangers. This will also add a couple of inches lift on the rear, which always helps with the 4runner. At least this is what I did, and it seems to work just fine.
As for the windows on the camper, just got some plexiglass, cut it to size, and heat it up with a heat gun at the right spot and put a bit of pressure to cause it to bend. Worked just perfectly. You can check out my build to see it all work out.
badassfullsize
« Reply #32 on: Dec 13, 2006, 08:23:47 PM »
Definetly my favorite mod thus far.  Definetly makes it easier to get around the trails around here.
Last post Dec 16, 2003, 11:45:06 PM
by 84runner
how much is it worth?
Last post Feb 20, 2004, 10:31:50 PM
by 85Yota22rE
Last post Nov 11, 2004, 04:18:46 PM
by 79coyotefrg
Last post Oct 07, 2006, 03:23:14 PM
by 1Bad4Runner
Last post Nov 19, 2015, 12:21:21 AM
by esco_je10
