Fount it... I bought 36" of 3 1/4"OD x 2 3/4ID tubing.
looks good so far.I'm starting my SAS tomorrow,i'll have front end done by sunday.check out onesloyotas 88 buildup.
what size tires are you going to run? Lift is coming along great. Keep up the good work.
Hubs locked or unlocked?
Does anyone know where the caster should be set on the axle? My hysteer arms are pointing up a little bit, Should they be level?
Also, here is my steering... I'm not sure if it is going to be ok or not.
It looks level to me, maybe trim the rear fenders a bit and that will make the fender Wells look even.I think it looks good . I really like the look of narrow tires.
It's going to be really close.have someone jack up the passenger side with a hi-lift while you watch the pitman arm.
Thanks whiteman, I was thinking the same thing about the fenders. I like the narrow tires, but I want to go with the radial toyo open country's and they are 14.5" wide I'm kind of nervous to buy them because I need something thats good in the snow and mud.Yea, I know... but I don't have a Hi-Lift (I need one though) and my floor jack doesn't go high enough. Anything else that might work?
Started by WarPony Chit Chat Camp
Started by awhotrods General 4WD Discussion
Started by YOguyDa General 4WD Discussion
Started by 82 HiLux « 1 2 » General 4WD Discussion
Started by montanatoy General 4WD Discussion
