Blackdiamond (Gup-C build-up)
:)bestgen4runner
I am 1/5th of Perfect Fit
It's been almost a year since I last posted anything on this thread.
My exhaust system has a small leak in it somewhere that I'm sure will be under warranty when I get the time to take it back to the muffler shop.  I'm thinking that I may take the leap and have them swap it out for something with a little more sound.  I don't really like the sound of a loud 22R-E, but something with a little more sound that stock would at least be fun to try and could easily be reversed.  The current muffler measures 18" x 6" for reference.  Any suggestions?
I'm also going to replace my tach that has been intermittently not working.  It's likely a wiring issue, but since it's at least 13 years old and will cost less than $50 to replace, I might as well spent my time replacing it.  I can get the same one so I will only have to reconnect four wires and continue using the same mount.
#902
I think Magnaflow is an option at the shop and I think I'd like the sound of this.  I'm not sure exactly what it is though other than Magnaflow.
https://youtu.be/_uUskBw89IM
https://youtu.be/malsQtLGzgo
Maybe this?
https://www.magnaflow.com/products/10416-performance-muffler-magnaflow-4-round-centercenter-straight-through-performance-muffler#
Rockcrawlintoy
I was super happy with my thrush turbo muffler. It was quiet overall but had a little bit of sound to it
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
I stopped by the muffler shop briefly on the way home and they actually offer Magnaflow style mufflers and not Magnaflow branded mufflers.  It looked like they had something that's equivalent to a Magnaflow #11225.  I think I'll give it a shot.
Quote from: Rockcrawlintoy on June 21, 2020, 02:53:43 PM
I also like the Thrush Turbo mufflers.
I stopped by the muffler shop yesterday and found out that they don't sell Magnaflow branded mufflers, but they do have some Magnaflow style mufflers.  It appears that they are a copycat product and should work just fine.  They were dead yesterday, but I didn't have the 4Runner.  I drove the 4Runner to work today and was able to get away early afternoon, but they were really busy, so it'll have to wait until next Friday.
I got the tach replaced on Sunday and got the muffler leak fixed today.  The estimate for the Magnaflow style muffler was higher than I was expecting and too much to justify.  It's the first time that I've felt this muffler shop has played games with me.
The equivalent muffler from Magnaflow is $94 and they acted like $120 was giving me a half off deal.  The killer was that the current exhaust is actually 2" instead of 2-1/4" and since the inlet and outlet were different it would have required more pipe work that it was worth.
No biggie, just a lost opportunity to try something fun.
#908
Today I pulled the rear driveshaft with the plan of having it serviced.  I have a vibration around 60 mph that seems to be worse.  The t-case output and differential both seem to be tight so I'm thinking that some of the marks on the driveshaft may have altered its shape or balance somewhat.  Looking back it was installed in July 2007, so it's probably reasonable to have it serviced.
I also have new tie-rod ends for the front and plan to get them swapped out sooner rather than later as a preventative step.  They are also circa 2007 parts.
CB.TypeG
Great build man, Just read through the whole thread.
Very nice attention to detail and thoughtful mods.
Maybe I'll see ya at Tahuya sometime after I get my truck back together, I'm over in Sequim.
Quote from: CB.TypeG on August 16, 2021, 12:19:45 PM
It's a pretty typical Toyota build, but I have tried to overbuild where it makes sense to do so. The philosophy hasn't let me down so far, but I don't unnecessarily beat on my rig either.
CB.TypeG
I agree its typical of a quality Toyota build, but that's what makes it the preferred route  :thumbs:
Solid philosophy, I'm pursuing the same. Upgrade what breaks and strengthen what you can, treat it right, and hopefully it lasts forever!
Quote from: CB.TypeG on August 17, 2021, 07:02:34 AM
I skipped the "upgrade what breaks" phase because I will do just about anything to avoid trail repairs.  I was fortunate enough to be in a position to pretty much do the whole build all at once with parts swapped over from my '85 truck.  I really think having 4.70:1 gear in my '85 was key to avoid breaking stuff.  It forces a slow methodical approach unless you're just of an unredeemable send it mindset.
The word is that my driveshaft was still straight, but was out of balance with some wiggle in several of the u-joints. I should get it back next week and expect this to resolve my vibration in the 60-65 mph range.
Bananaclip
Seems to always be something. Fantastic thread.
84 extended cab
The driveshaft is back in and the vibration is more acute than before.  It appears that the u-joints in the driveshaft were absorbing the vibration rather than causing it.  It's definitely more pronounced on the throttle in the 60 to 65 mph range.
I think my next steps will be to get the tires balanced and also remove the track bar to eliminate that has a potential cause.
Bananaclip
I was hoping everything would have been cleared up. These are the little frustrating things that drive you crazy. Best of luck getting the vibration sorted.
84 extended cab
I pulled the track bar off this morning and plan to have the tires balanced tomorrow in my quest to identify the source of the vibration. I hope to go for a drive today and see if the track bar was preventing things to move as needed.
My understanding is that the goal is for the rear differential to be a couple of degrees low to allow for rotation under torque. Based on how the fins on the third member run compared to the driveshaft it would appear that it wouldn't take a lot of rotation for the third to be inline with the driveshaft which seems like the ideal scenario. Maybe the track bar has been preventing the differential from rotating.
The vibration was a lot less pronounced with the traction bar removed. It almost feels like it could be coming more from the front. What are the odds that both of my transfer case mounts have issues?  Would these or an engine mount lead to a vibration?
Quote from: blackdiamond on August 30, 2021, 06:19:01 PM
Could the driveshaft be out of phase??  :dunno:
https://managedmobile.com/driveshaft-phasing-importance/
Gnarls. :usa:
Quote from: Gnarly4X on September 06, 2021, 03:49:32 AM
Gnarls. :usa:
The rear CV style driveshaft was just serviced and was machine balanced. The guy even cut one tube end off and rewelded it because it was slightly misaligned (always has been I guess).  I was all one unit when I got it and I simply bolted it in. Is it possible to do that wrong?  I thought the phase issue was related to the splines in the driveshaft?
#921
Quote from: blackdiamond on September 06, 2021, 09:46:31 AM
If it is one piece shaft and no removeable splines the shaft itself cannot be phased.
I don't see how you can bolt it into the U-joint carrier any other way?
https://www.youtube.com/watch?v=SIsT3svMtVI
Gnarls.  :usa:
Quote from: Gnarly4X on September 06, 2021, 10:34:46 AM
If it is one piece shaft and no removeable splines the shaft itself cannot be phase.
I don't see you can bolt it into the U-joint carrier any other way?
Gnarls.  :usa:
With my CV style driveshaft the distance between the two would have to be part of the equation since it's not a game of matching angles at the two ends. I might be able to check things with my phone though.
Any update on your vibrations??  :dunno:
Gnarls. :usa:
Quote from: Gnarly4X on September 13, 2021, 04:18:06 AM
Gnarls. :usa:
Nope. Other forms of life are taking over for a while.
In unrelated news, I got some new tubes for my stereo amplifier and it's like having a new amplifier it would appear.  I can't say that it's absolutely better, but it's a night and day difference. Probably the start of a slippery slope for tube rolling.
#926
Quote from: Gnarly4X on September 14, 2021, 04:09:49 AM
OMG!  I hate it when that happens!! :yikes:
Gnarls. :usa:
The new Mullard tubes are quite an upgrade. The science of tubes for audio is somewhat fuzzy so has potential to be a slippery slope. The tubes are technically the same but the resulting sound is enough different to be heard via earbuds using an iPhone video of before and after.
Slabzilla
Heyy BD, I thought that if you had a CV-style drive shaft, that the diff flange should point to the transfercase flange.  Just my $0.02   :thumbs:
Quote from: Slabzilla on September 14, 2021, 08:41:50 PM
I don't think anything has changed with my driveline angles from when I had the differential rotated, but it's possible that the springs have settled just enough...
I always thought that the goal was to point the differential flange at the t-case flange and that my be correct. When I was looking at my CV driveshaft installed I realized that the CV Joint is about 6" long so the driveshaft really ends up pointing above the t-case flange. I had always thought that the driveshaft would be parallel to a line between the two flanges.
toyodaaddict
Quote from: blackdiamond on September 15, 2021, 03:18:34 PM
People always say point the pinion at the tcase flange. I feel like that is a bit misleading, its not like you just eyeball it. With a CV shaft you want the pinion 2* under the slope of the shaft. The idea is that the pinion will lift a bit under actual use. If you want to checked the angle, get a angle finder ( fancy  https://www.amazon.com/Wixey-WR300-Type-Digital-Backlight/dp/B00T6YZ0K6/ref=asc_df_B00T6YZ0K6/?tag=hyprod-20&linkCode=df0&hvadid=312229526558&hvpos=&hvnetw=g&hvrand=10607907044202652846&hvpone=&hvptwo
Not fancy https://www.harborfreight.com/hand-tools/measuring-marking-layout/dial-gauge-angle-finder-34214.html both work fine) Check the angle of the slope of the shaft, then remove the shaft from the pinion and check the angle of the pinion flange. The pinion should be 2* lower than the slope of the shaft. It is possible that with an anti wrap bar the pinion should be perfectly inline with the slope of the shaft, I dont know, I have never ran one.
https://4xshaft.com/blogs/general-tech-info-articles/slopes-vs-angles
