Would Carl say that what he is seeing in more like normal wear, premature failure due to defect, improper original installation, failure caused by bent axle housing or components, or caused by a lack of maintenance issue? Gnarls.
It was installed in the 3rd around 2002. I doubt that installer wouldn’t have caught this issue since he was super picky.
Was the Detroit SL installed the same time the 3rd was installed?Gnarls.
It’s done and I’ll be picking it up after work today.
Hey b....I would think that with your added equipment, your Runner is well over 4,000 lbs.Have you weighed it and know what the weight is? Gnarls.
I have never put it on a scale. Why?
Carl is thinking that I most likely have a metal to metal contact point causing the current vibration. T-case mount, body mount, exhaust, etc. I’ll have to find some time to do some looking. For now, there’s enough other things in play that the 4Runner is most likely out for this years Moab trip. It’s not absolutely needed for our trip to be successful.
I'd say it was decidedly more up together than my first gen was for the rubicon trip.
From what I know about that trip I would have to agree. One significant difference is that you are far more suited for repairs along the way. Trail repairs are not my cup of tea.If this was a typical “boys” trip where the harder wheeling was the goal I’d probably risk it, but this trip is family wheeling centric so it’s just not worth it.
By trail repairs you mean holding the transmission in with a ratchet strap round the sliders and changing a tyre? The transmission waited till we got back before it grenaded
Geeezzz... Over the many years I wheeled, I have seen "trail repairs" that were nothing short of amazing!On the downside..... half of them were the consequence of stupidity or inexperience. Gnarls.
I put the 4Runner on jackstands this morning and the vibration seems to steadily increase with speed instead of before when things got wild above 50 mph. I took videos of both ends of the driveshaft and along the driveshafts length and I don’t see any obvious vibration movement. Next I’ll look for contact related vibrations.
Youve checked all the UJ's? Im going to assume it has no center besring?Gear man checked the axle shafts for straightness?The output of the tcase has no play?Youve not lost any balance weights off the driveline?
Of course the "phasing" has been verified. Gnarls.
Didn't read too far back, but you try getting your tires balanced or rotating them?
Started by blackdiamond « 1 2 » Rig Gallery
Started by blackdiamond « 1 2 3 » Project Research and Build-Ups
Started by *FFC* Chit Chat Camp
Started by blackdiamond General 4WD Discussion
Started by iNfErNaL Chit Chat Camp
