I was going to get the chromo bir's and the longs are what 35.00 more but wait where can you get a 30 spline replacement, no i think chromo bir's and empi spares, sounds better to me, besides someone else on the trail may need a bir cause it's gonna break,
I was thinking the gusset's for rigidity, and if the gears will live with the pinion pointing at the t/case or is that for off road or comp trucks, or is their a benefit. I was going to get longer spring perches to reduce twist
I have s13wb calipers and l/c rotors for all four corners.
got the rear axle bearing set and the solid pinion spacers on the way, gotta get the wheel spacers
I have a Dana 60 rear , a RH divorced NP205 need a Dana 60f RH 69" wms. and a NV4500
haven't been able to find an R trans yet, I'm working on getting up some recent pic's.
