knuckle ball rotation ?
Started by yotakid88, March 14, 2007, 07:15:46 PM
yotakid88
I was just wondering if I should rotate them or not
got low range
95/91 pickup, 3in tuff country lif and a bunch of marlins stuff.
AaronB
yotakid88
why ? I would like to rotate the pinyon up to get the angle up more.
got low range
Fearofrunner
unless your binding really bad i wouldn't do it, throws the camber off
AaronB
if your using a toy front axle your not going to be able to bolt down the u bolts with out some major modifications.
alwayzbroken
Quote from: Aaronb on March 16, 2007, 02:39:17 PM
Major modications such as angle wedges.
alwayzbroken
Quote from: Fearofrunner on March 16, 2007, 02:28:16 PM
It does not do anything to camber since you are rotating the knuckles to stock.
rude86
if you use wedges your crossover tierod will hit your springs...
member of team marlin crawler
AaronB
Mine has a crappy angle to, but it works fine. if your really concerned, buy a high angle third.
Willy Mammoth
Do you have a high pinion yet? I would do that first.
Or duals would also help your angle and give you better gearing options.
rude86
yotakid88
Im gunna be running dules and i set it up to day and it looks good with out weight on it.
got low range
