Author Topic: hybrid propane engine  (Read 7576 times)
dune_it86
  • Male Posts: 323
  • Toyfanatic
« on: Jul 27, 2006, 01:35:18 PM »
hey wha are the chances of doing a 22/20r hybrid and then running a propane crb setup on top of that, my ideas ar .30 over 22r bottom end with keith black high comp. pistions, a 20r head w/ largevalves, heavy springs and a good low bottom end cam then an offenhauser intake manafold off of a 22r then to top it all off a propane carb set up. howdoes that sound what are your guys's suggestions
heepofajeep
  • Member since Jun '06
Re: hybrid propane engine
« Reply #1 on: Aug 17, 2006, 11:44:54 PM »
I thought the 22r intake would not work with the 20r?  No personal experience, just thought I came across that somewhere.  What would you use for a mixer/vaporizer combo?
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #2 on: Aug 18, 2006, 12:56:05 AM »
a 22r intake wont work on a 22r, however a 20r/22r hybrid means using a 22r old style block and a 20r head usually
dune_it86 [OP]
  • Male Posts: 323
  • Toyfanatic
« Reply #3 on: Aug 18, 2006, 09:55:24 AM »
the gotpropane. com kit it's 9 hundred somthin but i have decided to buld the engine for a formula toy type project
heepofajeep
« Reply #4 on: Sep 03, 2006, 02:42:04 PM »
There's a lot to be said for buying something ready to go... but I don't think you save $700 worth of time in the gotpropane kit, when used Ebay setups are available online for $100-200...
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #5 on: Sep 03, 2006, 04:37:42 PM »
have you actually ever done the research? do you run propane or are you just enlightening all of us with all your propane knowlege?
heepofajeep
« Reply #6 on: Sep 03, 2006, 06:33:31 PM »
Yes, I have done a LOT of research, & run two different propane setups.  The engine I ran it on was a 258 in a Jeep CJ, but there's really no difference.  There are quite a few people that have actually used the impco 225 mixer on 22rs with good results-- that is what I used on my CJ.  I watch ebay periodically (about once a month or so), just to keep tabs on the cost of a propane conversion.  I sold the impco 225 for $75 on Ebay.
Currently I have an impco 300a that I am unsure if I will try to make work on my current Toy, or sell it in favor of a slightly easier to bolt-up mixer.  (I ended up running dual fuel on my CJ-- hence where the 300a came from).
Here is a good link on how to tune the mixer/vaporizer: http://www.wildyoats.com/vbulletin/showthread.php?t=12585 (since you seem to be concerned with me enlightening you with my propane knowledge, I figured I would add to the tech).  FWIW, I am sore4x4 on there.  Also, I have received an email from the guy saying the setup works great.  He spent about $600 on his setup, but he went the new route.
Here are some additional links that might be helpful.  Please note, these are not really the best links for hooking up the mechanicals, but rather some informative reading on lpg as a fuel (as a generality).
http://www.pirate4x4.com/tech/propane/index.html
http://www.envirogas.co.uk/faqs.htm#where
http://www.eere.energy.gov/afdc/altfuel/propane.html
http://www.propanecarbs.com/propane.html
http://hypertextbook.com/facts/2003/ArthurGolnik.shtml
http://zebu.uoregon.edu/2001/ph162/l8.html
KYOTA
  • Wreckin Ball '09
« Reply #7 on: Sep 03, 2006, 07:37:34 PM »
cool, most of the time people just spew :pokinit: they have no clue about. glad to see someone that HAS done their homework. I see your in Spuncouver, probably run into at TSF sometime. pic of your rig?
heepofajeep
« Reply #8 on: Sep 03, 2006, 10:06:24 PM »
Lol, yeah, I know what you mean.  Unfortunately, the rig is pretty much in pieces at the moment, hence why I am on the site ;).  Here are a couple threads on the build progress though:
http://sore4x4.com/forum/viewtopic.php?t=16&sid=10cf698c117301d5473562372e22fcb1
http://sore4x4.com/forum/viewtopic.php?p=3218#3218
yotadork83
  • Turtle Points: 18
  • Male Posts: 705
  • Member since Mar '06
  • ninja turtules rule!!
« Reply #9 on: Sep 09, 2006, 01:24:15 PM »
i am doing the same setup as we speak. the 22r intake will not work on 20 head. and if you use the 20 head you have to get a 22r carb base plate and then get a 22r to 20r adaptor plate from lcengineering. other than that it should work great.
yotas 4 life homie!
tanabuse
  • Turtle Points: 4
  • Male Posts: 185
  • Member since Dec '09
  • sleeper, any time any trail any where
« Reply #10 on: Aug 22, 2010, 10:03:09 AM »
man it seems no one does research on this :pokinit:. the offey intake was bilt for spliting primarys and secondarys through out rpm band it is suspost to give u a cooler  charge of gasoleen  and they flowed a little better now in my experience i have had a 22 R, 20 R,and the  21 RU  i have ben  running on propane for three weeks now and i far as i can tell it wont help much to put on a offey with propaine it dont matter popane will run with a stock intake just fine. and i just dont c the point of putting an offey on a propane  it wouldent be able to tell the diffenence
and i am talking about a offey  dual plane you can by a c series for a weber but it does not have dual ports for your  primarys and secondarys
Turning
Over after
Years
Of
Trail
Aabuse
Last post Nov 01, 2004, 10:22:57 PM
by kneedownnate
Last post Apr 07, 2006, 08:10:31 AM
by AzBearFan
Last post Nov 18, 2017, 09:52:43 PM
by 79coyotefrg
Last post Jul 06, 2012, 07:00:14 AM
by SloCrawler
Last post Oct 16, 2017, 07:55:16 AM
by H8PVMNT
