IFS is gone!! 3.0 Killer on 1 tons
Started by BLACKDOG, April 17, 2006, 08:57:18 PM
BLACKDOG
Quote from: cdgvw1 on July 23, 2009, 03:52:11 PM
You going to have this ready for MCR??  Oh, and that would be the PO of the PO of the PO that cut those..  =]
:yesnod:
and yeah, I figured you didn't cut them :gap:
              -Ronald Reagan
BLACKDOG
#361
Got the parts I needed at PnP.  :gap:
Truck is back on 4 wheels.  Gonna weld the rear end and finish up the gears on Tuesday, then all that is left in the rear is brake lines.
Hopefully going to weld the hanger on Tuesday as well.
Tire the truck's been sitting on for 6 mos.
Had a buddy helping me out today
              -Ronald Reagan
luvyota
luvyota
Rocksnail
looking good. Do  you have any part numbers for the toy to GM  mc fittings? im almost done butting tons under my first gen. need to get my brakes finished. keep up the good work
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
BLACKDOG
Quote from: Rocksnail on July 25, 2009, 12:33:34 PM
Not off the top of my head, but I'll look at them tommorow, and see if they've got anything stamped on them.  :thumbs:
              -Ronald Reagan
Rocksnail
Thanks Blackdog.  keep up the good work.
blackdiamond
Quote from: BLACKDOG on July 24, 2009, 10:58:46 PM
...then all that is left in the rear is brake lines.
Are we gonna see some rear shocks?  :eye: :eye:
BLACKDOG
Quote from: blackdiamond on July 28, 2009, 06:26:58 PM
Eventually :gap:  Probably not before the roundup though.  I'm running out of money, and out of time.  Haven't had rear shocks for 4 years or so, should be alright.  :yesnod:
Sorry, don't have the numbers.
              -Ronald Reagan
BLACKDOG
clean garage (for now)
New toy.  Got the welder, and a 50 ft extension cord off craigslist the other day.
Gotta cut the hanger down, cutting the top section of box tubing off
Finally welded in my tunnel cap (been sitting on top of the carpet, sheetmetal screwed down) and sealed it with roofing sealer
Kingpin and all associated parts look good
Doing a little cleanup before rebuild.
Max wondering why I'm dirtying up his room
And that may be the end of pics for a while.  My camera took a header off my table in the garage, and is irrepairable.  :down:
              -Ronald Reagan
BLACKDOG
Got the other side stripped down, and the housing cleaned up
Gotta love  the 2 steering stabilizers
Quality stablizer mount :gap:
This side is a tad dirtier than the other
Got my hanger cut down
              -Ronald Reagan
kiyul4130
you can throw away those backing plates just like the toyota stuff. you dont need them an they'll just get in the way or banged up sooner or later.
-kiyul-
ECV 7-11
KYOTA FOREVER
BLACKDOG
Cool, thanks!  I'll probably just do that then.  Hadn't really thought to that point yet, but I appreciate it.
              -Ronald Reagan
BLACKDOG
Pics will come tommorow, but got the D side of the IFS pulled off.  Gotta do it the hard way, no torch or plasma, unbolting it piece by piece, then using a cutoff wheel and grinder to clean it up.
              -Ronald Reagan
BLACKDOG
:disturbed: slowly but surely!  :gap:
Sorry about the crappy cell phone pics.
              -Ronald Reagan
BLACKDOG
Once again, pics coming tommorow, but the IFS is GONE!!  All cut out, and ground down.  Work party tommorow, Plan is to get the axle hung under the truck :woohoo:
              -Ronald Reagan
BLACKDOG
cutoff
ground down
Its all out!
Welded rear
              -Ronald Reagan
*FFC*
BLACKDOG
front and rear gears are done, front hanger is tacked in place, shackle holes are drilled, and springs are just about ready for mockup.
Interior will go back in tommorow, and front axle will be assembled in the near future, pending arrival of parts.
To do:
Move steering box
mount shock hoops
buy shocks
brakelines
reassemble front axle
purchase steering (links, TREs)
mount bed
fix exhaust
reassemble interior
buy front diff cover
paint (if time)
              -Ronald Reagan
BLACKDOG
              -Ronald Reagan
kiyul4130
the ifs is finally off. i cant believe it, i dont think anyone can.
what are you doing for tires?
what are your plans for steering, i could help you out if you have any questions since most people dont run the 3.0s like us. oil pan swap?
-kiyul-
ECV 7-11
KYOTA FOREVER
BLACKDOG
Quote from: kiyul4130 on August 07, 2009, 03:16:36 PM
I barely can myself.
as of right now, I'm planning on running the typical high steer.  It appears as it sits right now, that I might clear the oil pan, but I'm not sure.  I've also considered running crossover, using the arms that are on the knuckles, and running the tie rod in the stock location.
what did you do?
              -Ronald Reagan
kiyul4130
go check out my build in Rig Gallery.
if i were to do it again id probably would have just bought 1 high steer arm an done the cross over steering with a burly tie rod. everything clears fine but if you want to do hydro assist the ram is right there under the pan an gives you a very small amount of up travel, depending on how much lift you are running. my springs were close to flat.
-kiyul-
ECV 7-11
KYOTA FOREVER
bigarms23
i did have issues with the 3.0 oil pan i ended up just notching it
BLACKDOG
Already got all the stuff for high steer, so i'll prolly just go with that for now.  Got the arms and tube bungs from ballistic fab, some good quality stuff :yesnod:
              -Ronald Reagan
BLACKDOG
Got a lot of minor stuff taken care of yesterday, started reinstalling the interior, fixed my exhaust, ran my rear brake lines, bolted on the rear diff cover, and cut out the centers on my H1 wheels.  Only thing I got pics of was cuttign out the H1 wheels.
Using a cutoff wheel is a PITA, but they turned out well.
Also got my shocks hoops,
IFS box relocation plates,
and my threaded steering ends.
Ordered my front diff cover, wheel centers, and rock rings from great lakes offroad.
              -Ronald Reagan
BLACKDOG
My latest toys
Moved the PS box
painted my knuckles
Thats about all I got done today, bought some other small stuff I needed.
TREs and Ujoints are on the way, as are my wheel centers and rock rings.  Should be here anytime so I can start putting the axle together.
Still working on the spring packs, I got them figured out, just need to get some spring clamps and new centerpins to put them together.
              -Ronald Reagan
86rustbucket
kiyul4130
your pitman arm is gunna be in contact with your tie rod most likely. did you already burn in your steering box mount?
-kiyul-
ECV 7-11
KYOTA FOREVER
BLACKDOG
Quote from: kiyul4130 on August 17, 2009, 06:33:26 PM
yeah, I did.  I moved the box as far forward as I could without cutting into the core support and body mount too much.  I should have waited, but its too late now.  We'll see how it looks.  :crossed:
              -Ronald Reagan
