I'll be interested to know as well. my blinkers are spastic right now and I know I'm annoying people when I'm at turning.
So like I guess I was supposed to look into this huh? ehhhhh hmmmmmmI will be doing some *top secret* work to my rig this weekend, so looks like I'll have to add this to the list I'll report back what I figure out-
what about using an el-12 flasher?
WITH THIS TRICK, I CAN RUN MY FRONT MARKERS AS TURN SIGNALS? PLEASE EXPLAIN!!!
Sorry but I disagree synwars.....YES - this also works for people that have plugged there blinker light wiring harness in to their parking light. see the resistance on the parking light bulbs is less than the resistance of the blinker lights, hence your blinker will flash fast thinking the bulb is burnt out (same thing with LED lights). so with this mod - you eliminate the low resistance circuit and your blinker will flash at the correct rate.
hey rick.... would that make the parking lamp blink brighter? they are kind of dim during the day....
No, you would need to install a higher wattage light bulb for that... Unfortionately I don't think there is room for a bigger bulb.
Started by Fireimp141 General 4WD Discussion
Started by SolidAxle « 1 2 » Chit Chat Camp
Started by toys4life Engine
Started by YotaJosh General 4WD Discussion
Started by Sluice Box Hero Project Research and Build-Ups
