Shambs Official 1-ton Build
Started by Shamb, April 02, 2006, 05:44:36 PM
yotaboy79
Quote from: Shamb on April 13, 2006, 07:37:22 PM
Yea whats the deal with that? I've been hearing that you can spin a bead off real easy on 16.5's for some reason. Whats the diff?
Someone also told me I'll need to run a double beadlock in order to keep the bead on at low pressure
the reason they come off is the lack of the lip that rides against the inner edge of the bead if you look at a set of 15's and then look at your 16.5's you will see a little ridge on the bead that helps keep the bead seated on the 15's and on the 16.5's it will just taper down so the only thing holding the bead on is air pressure i personaly would not run the 16.5s
Shamb
I will, they'll just be beadlocks.
synwars
Quote from: Shamb on April 19, 2006, 10:14:18 PM
Get the Hummer beadlocks, they clamp both sides.
http://www.pirate4x4.com/articles/tech/billavista/PR-Hummer_Rims
Perfect for 16.5" rim size... :D
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
CumminsDZL
Shamb, i like the rear taillight setup.  Recently i was thinking of doing the EXACT same thing because i thought i had a new idea.  But it looks like i will have to come up with something else.
Driver of the "Eyesore"
Shamb
lol those lights/bed/frame are no longer there. Chopped the frame right behind the cab!!!!!
Tubing the entire rear end, i'll post pics of the progress on Monday
gotrocks
Shamb
Pics as promised, few teaser pics. I have more...
Shamb
Shamb
some halfdoors i've been working on. Almost done.
toynorcal
Hey, how much bondo you got on those half doors?
:haha:
gotrocks
you able to get a front straight on picture to see how wide it is now.  Is that front axle sitting there or is it actually bolted in?
motorider228
what year and model gm did that read end come out of? is it a full float or no?
Shamb
QuoteHey, how much bondo you got on those half doors?
Half a gallon, YOU KNOW A-HOLE! I sanded down about 1/4 of a gallon the day after   :D
Quoteyou able to get a front straight on picture to see how wide it is now.  Is that front axle sitting there or is it actually bolted in?
Not bolted on yet, I do have a front on picture (kinda)  I'll post it.
Quotewhat year and model gm did that read end come out of? is it a full float or no?
Yes its a full floater, It came off a utility truck I believe. Bought it off a buddy that went to OK. to retreive it.
Shamb
front shot, doors open. kinda get an idea.
locktup
Quote from: Shamb on April 24, 2006, 10:09:25 PM
Did you do the flames oon the door?  :flamer:
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
www.LOCKTUPFABRICATION.com
gotrocks
Wermz84
It's comming along nicely.   :yesnod:
I'm licking those tires..
I like to Drive!
Shamb
QuoteDid you do the flames oon the door?
Lol that was a majic marker, my buddy Rudy is a painter and was f'n off while I was sanding them smooth. We did the flames on my hood in about 2 hours. Gonna redo the flames once its all said and done, probably paint it gun metal grey.
QuoteI'm licking those tires..
Personally I don't like the taste of rubber but do what you must!   :rofl2:   "liking"   :therethere:
Ramrod
so what kind of links and joints are you gonna run on there?  Are you using any kind of link calculator to set them up?  I could ask so many questions to every person with links right now
Wermz84
Quote from: Shamb on April 26, 2006, 09:57:31 PM
Crap  :smack: .  A guys gotta do what a guys gotta do right?  :rofl:
.. Gonna redo the flames once its all said and done, probably paint it gun metal grey.
I think that would look Good.   :thumbs:  but I have always been fond of gun metal grey.
I like to Drive!
Shamb
Quoteso what kind of links and joints are you gonna run on there?  Are you using any kind of link calculator to set them up?  I could ask so many questions to every person with links right now
http://shaffersoffroad.com/catalog/product_info.php?cPath=68&products_id=459
Something similar to that, just a bit bigger, links are like a 1 1/4" (can't remember exact size right now) by 1/2"
I'm not doing the links, I started major research... got pictures and started calculating X/Y axis points, anti sag.. blah blah.. and figured out it would take me twice as long.. besides I dont have the right resources to do it. I know a guy that own's a shop in YC that does bad ass work.
Rock-n-Roll offroad off Garden Hwy, Curt (the owner) is damn good with setting up links and tubing. You can see pictures of his buggy in the Peterson's 4x mag a few months back when they did the article on Fordyce.
I'll post new pic's on Monday.
KWP
 Sick build man :thumbs:. A linked suspension is next on my to do list.
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
Shamb
Nothing to exciting for this week, pulled the hood off, lights and shaved the corners. Hopefully have the links on by next weekend. I'll post up pics later.
Shamb
axles are linked. i'll post pics on Monday.  progress!   :hammer:
gotrocks
ok you can't leave us hanging with that update get those pictures up man, I know you said monday but thats WAY to long from now
Shamb
gotta make it suspensful.
Shamb
linked!
Shamb
stinked
Shamb
where's the beef?
