Author Topic: Cooling issue...should these be connected to something?  (Read 3502 times)
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
« on: Mar 31, 2006, 07:39:30 AM »
OK, I have been having some over heating issues lately and the other day I noticed I had no coolant in the system.  I refilled the collant and still overheated, so last night I put in a new toyota thermostat, and went to look at the coolant level and she is empty again.  Can't figger out where all the coolant is going to, but I noticed these two grimey hose connector deals on the bottom of the radiator that have no associated hoses.  These supposed to be connected to something, or capped off?
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Oh, man if you didn't hook those up you are in big doo doo........
  • Momentum Man
  • Lego Enforcement
......those are the muffler bearing cooling lines. :gap:
  • Momentum Man
  • Lego Enforcement
Seriously I've only seen those on aftermarket radiator's, my guess is auto trans cooler line. I had those on a Kragen bought radiator.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
yea  those are for a auto tranny vehicle
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,854
  • Member since Feb '05
If your not leaking coolant you've probably got a blown head gasket
Time to go wheelin!
check your oil,  and under your 710 cap  look for a milkshake looking stuff,  if you find it  start :rivers:  cause the head gasket is bad
  • Momentum Man
  • Lego Enforcement
For some reason the aftermarket includes those even if you don't have an auto, to where OEM's don't even have them. I guess it's so they only have to Make 1 radiator for all applications. If your truck is running a little hot so did mine with that Korean radiator. Dump it find a new OEM or an old one recore it and it will run cooler. That POS always ran hot for me so I finally found an old V6 in good shape had it redone. I constantly had to refill mine with that radiator.
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
If you can't see any visible leaks, this is where I would check.
Happened to me,  couldn't figure out where my antifreeze was going.  So then I'm doing an oil change as part of regular maintenance, and sure enough the milkshake substance followed by a bunch of reglar anti freeze.  I was so confused   :headscratch:
But like Glen said blown head gasket  :yupyup:
 :twocents:
I like to Drive!
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
Arg, you people are killing me!  HG...better go have a look-see, maybe it is time for those engnbldr heads?
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
OK, so what are the recomendations for gaskets, the std felpro autozone stuff, or are there some super high end bad arse deals?
Rock products
i was very impressed with the quality of these gaskets
the entire gasket set was $60
all viton seals  and the HG was a Multi layer steel
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
Sweet...thanks Glen!
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
I'm going to remember that as well.  I have used felpro everywhere but on the head gasket, without any problems yet.  but it's always good to have options.  :yupyup:
Hey CTENG  "HG"  :headscratch:
I like to Drive!
mudmaster
  • Male Posts: 2,854
I got a Miloden (sp?) from Napa. No auto coolant lines and engines doesn't run hot.
Time to go wheelin!
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
Cmon Wermy, stay with us here... Head Gasket!
skid
  • Turtle Points: 144
  • Male Posts: 295
  • Member since Oct '04
Another somewhat common problem is the timing chain wearing through the timing cover into the coolant passage.  Old chains can bust the guides and do this.   Leak down test should help pin point a problem.
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
:smack:   :doh:  thanks CTENG!
What was the verdict?
I like to Drive!
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
I wouldnt use an auto-zone head gasket. Unless you just really happen to like changing them and are poor. Just my   :twocents:
Quote
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
those lines are indeed for the auto tranny cooler, noting inside that part except air unless there is a leak (its possible, but never heard of a leak actually starting there) mine just have rubber vacuum plugs on the ends.....
if you are losing coolant, and overheating, its probably head gasket or a manifold or a coolant system issue.....
  • Administrator
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
What does the underside of your oil fill cap look like? Any white goo on it? If so then you've got moisture in your oil system = leaking head gasket.
Have you done a compression check yet?
i told him RockProducts.com
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
Bringing this back up...where did you get your set Glen.  Can you order right from the company or does a specific store carry them?
bmxanddie
  • Turtle Points: 557
  • Member since Nov '04
check your timing cover for grooves in the back of it. Thats what happened to me and all of my antifreeze keep disappearing exactly like yours
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
I peeked down from the top after I got the valve cover off and didn't see much in the way of scarring, but I will see when I get to the timing cover...I haven't drained the oil yet so there is still some resting in the head, it doesn't look like milkshake, it just looks scuzzy and dirty, so maybe it isn't the head gasket.  I will inspect more as I pull things apart, maybe I will get lucky.   :dunno:
bmxanddie
did you ever check your water pump? make sure its working?   if the HG was blown you would most likely have some milkshake going on.
EDIT :  forgot his antifreeze was dissapearing and not just overheating:)
« Last Edit: Apr 10, 2006, 03:50:39 PM by bmxanddie »
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
Yeah, the coolant is going bye bye...
Glen, where are you....where do i get those gaskets?
Last post Jul 14, 2004, 10:37:16 AM
by 84runner
Last post Jul 15, 2005, 06:32:50 PM
by Uncle Jesse
Last post Oct 03, 2005, 05:10:39 PM
by Willy Mammoth
Last post Jan 03, 2008, 08:35:47 PM
by Thomas P
Last post Jul 10, 2012, 04:36:10 PM
by stihlmohawk
