Duffil's 84 Xtra Cab is still bringing the suck
Started by Duffil, March 26, 2006, 07:25:29 PM
ouch... glad to hear its getting back together without much downtime though
CrazyYota
MiniSimp
Duffil
Duffil
everything is in now...teardown to start saturday after work.
Yota4life
Duffil
I hope so.
I should probably explain myself, and my results.  I got the cam specs for just about every aftermarket cam made, and made a cam file in Desktop Dyno, where I have my exact engine setup saved.  I changed cams back and forth between what I am currently running, and all other options, finding that with my specific setup (according to the DD, mind you) that I could not get as much torque as low in the powerband as I currently have.  I could get more HP or more torque, but it always fell higher in the RPM range.  I did notice, however, that if I changed the cam timing (ie, adjustable cam gear) I could get a torque boost all the way from idle. So I went with an LC cam gear.
Jud
Damn your sh*ts gonna be fast! haha
"bout tree fiddy"
Duffil
Quote from: Jud on January 24, 2008, 09:29:35 PM
:nonono:
:shhh: advance the cam for torque :yesnod:
Jud
Quote from: Duffil on January 24, 2008, 09:58:11 PM
:nonono:
Would advancing my stock cam create more torque?
"bout tree fiddy"
Duffil
Quote from: Jud on January 24, 2008, 10:08:43 PM
yes.  for $135 you too can increase the performance of your Toyota R-Series engine.  maybe if I get bored tomorrow, I'll run a comparison on a stock 22R with the cam advanced and post it for you.
Jud
Quote from: Duffil on January 24, 2008, 10:13:00 PM
That would be sweet. I am planning on doin a timing chain, water pump and all that good stuff here pretty soon. Maybe I can soop it up a little while doing all that. haha
"bout tree fiddy"
Duffil
my milkshake brings all the boys to the yard:
EGR Blockage:
:slap:
even made it thru the PCV:
For those that have never seen them(lots of my customers... :headshake: ) these are stock 81-84 Air Injection Tube Gaskets.
Duffil
so for tomorrow:
clean block surface
remove broken bolt in block
disassemble/clean head
lap valves??? might wait on that one
clean/regasket intake manifold
set LC sprocket to spec
new timing cover seal
clean valve cover/rocker assy
change adjusting studs in rockers
cut off torque arm bracket on frame
skipnrocks
MMMM that milkshake looks yummy!!!  That sheared bolt is impressive, did you hear it go, or just notice it in your oil?
WILLYNILLY
Quote from: Duffil on January 26, 2008, 09:58:44 PM
my milkshake brings all the boys to the JUNKyard
fixed it for ya :gap:
Duffil
Quote from: skipnrocks on January 27, 2008, 12:18:57 AM
no, it is the bolt under the damn distibutor.  I was loosening it and it was one of those ":pokinit:...that didn't feel good...give it another twist. POP" type of breaks.
skipnrocks
Quote from: Duffil on January 27, 2008, 09:23:58 AM
LOL got to love those!!  Did you get the rest extracted?  If so how?
WILLYNILLY
Duffil
Quote from: skipnrocks on January 27, 2008, 09:37:37 AM
I am going back over there in a little while to complete the above list.  we shall see. :crossed:
Doof
what flavor was that milkshake... sounds tasty  :yumyum:
Duffil
and then I see this:
exhaust lobes on #1 and #3 are poo.  time for a new cam anyway. :rivers:
skipnrocks
Hey man you got some greese under your nails there!!  LOL
WILLYNILLY
CTENG in KS
Isn't that how you know you are a man?
skipnrocks
LOL and here I thought you checked between the legs?  Guess I was wronge!
WILLYNILLY
Duffil
Quote from: skipnrocks on January 27, 2008, 05:10:20 PM
dude they teach you that in auto shop don't they?  It doesn't matter what's between your legs, it's under your nails that counts. :greengrin:
Duffil
Now I am starting to get a little pissed.
I got the valves out and then:
so I took a break from the head and let the truck know what was up :laugh:
and a broken bolt on the back of the head:
Duffil
I got that broken head bolt out with a MAPP gas torch and a stud extractor.
Quote from: Duffil on January 26, 2008, 10:02:44 PM
so for tomorrow:
clean block surface
clean valve cover/rocker assyfor now anyway
change adjusting studs in rockers waste of time
New cam and new rockers should be here Tuesday.
For Sale: Full Set OEM Toyota Rocker Arm adjusting screws and nuts.  $40.00+shipping
back to work...
CTENG in KS
Doof
did you weld a nut to the broken bolt in this last pic?
skipnrocks
Quote from: Duffil on January 27, 2008, 05:25:16 PM
LOL I dont know, I took a vet class and they said check for something and if its there tie a rubber band around it!
Never looked between the legs since!
Duff you should tone it down and quite breaking stuff on that motor!!
WILLYNILLY
