Duffil's 84 Xtra Cab is still bringing the suck
Started by Duffil, March 26, 2006, 07:25:29 PM
Wermz84
Very cool.    More Pics...
I like to Drive!
Duffil
Quote from: Wermz84 on July 05, 2007, 10:36:46 AM
all in due time, grasshoppa.
Big thanks to booger for some plate!! :beerchug:
Duffil
some more work from last night:
I used the press at work to bend this guy...1/4" plate
still need to slice the axle tube a lil bit and bring it down
Duffil
 :cool:
Big thanks to Steve!! Ordered yesterday at lunch, got it today!
86bobbedtoy
hay looks like that axle will be sweet ! !
Jud
"bout tree fiddy"
Duffil
Jud
"bout tree fiddy"
Duffil
got the outside welded up tonight...should get the inside tomorrow and start on my gears.  :red_eyes:
86bobbedtoy
WOW again great work!  nice welds, what welder you got?
Duffil
Quote from: 86bobbedtoy on July 06, 2007, 10:37:33 PM
Thanks.
El Cheapo Harbor Freight Chicago Electric 220V unit.  I find that the higher I turn this thing up, the better they come out.  And the wirespeed is really fast, even at a low setting.
Duffil
Here is a rear view...you can see where I notched and dropped the axle tubes a little.
*** YELLER ***
Nice work dude
Nothin' says work bench like a couple of paper barrels and a folding chair  :thumbs: :disturbed:
:usa: :beerwhack:
except BACON
fordh8r
Quote from: oldyellercj on July 07, 2007, 07:20:39 AM
Nice work dude
:usa: :beerwhack:
Dude, you need to step up and use some stackable milk crates or a stack of tires even... :gap:
And very nice job on your mod there!
Duffil
Quote from: fordh8r on July 07, 2007, 08:32:11 AM
I can't.  Both of those options have too many movable parts and I might get confused.
fordh8r
Quote from: Duffil on July 07, 2007, 01:11:57 PM
Plus they're kinda pricey unless you know where to shop... :eyebrow:  :shhh:  :gap:
Duffil
#376
 :red_eyes:
got the case cleaned up last night, started today on getting the gears done.
froze the races and they fell right in!
It took me WAY too long to set the pinion bearing preload.  The solid spacer was about .010" smaller than the factory crush sleeve.
Solid spacer + .010" shim=full lock on pinion.
solid spacer by itself=no bearing preload.
there was a small .003" ridge on the front of the spacer, so I lapped it off with 400 grit and carb cleaner.
before:
after:
Duffil
 :inthedark:
I had to take off about .020" before I could get any decent preload with this thing.
this is where I ended up:
My SST:
after that, it was pretty easy...took me a little while to get the pinion depth correct, but it came out OK.
Not very clear, but here's my pattern:
and a fresh coat of flat black
Jud
"bout tree fiddy"
fordh8r
from the looks of those pics I'd run it!   :biggthumpup:  :driving:
Duffil
Quote from: fordh8r on July 08, 2007, 11:22:05 PM
I plan on it.  Hopefully under the truck tuesday night. :beerchug:
*** YELLER ***
nothing to see here movin along
except the new stackable boxes for a work bench
             :slap:
:usa: :beerwhack:
except BACON
Gittinit
#382
That shave job looks good. Do ya know how much ya took out? I love the rounded plate. Are you gonna add some more protection for the ring gear.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Duffil
Quote from: Gittinit on July 09, 2007, 03:53:15 PM
Thanks bro.  looks like around an inch.  I was planning on a piece of plate like the MC comp style guard, but I kinda ran out of steam on fab.  Maybe once I get the housing in.
Duffil
 :beerchug:
here's a before shot with a stock diff:
New axle bearings and seals, and the new one is in:
and a new clearance pic.
hopefully less of this:
Headed down tomorrow to get some rear driveshaft tube.
Wermz84
Awsome work!   your info on the spacer will help me out as well.
I like to Drive!
Duffil
Built new rear driveshaft today.  I got some 2.625"x.120" wall tube yesterday, and had the yokes turned down to fit.  So far, the rear end is great. On/off throttle transition is very smooth, no humming or odd noises and the detroit seems to be working fine.  I got it up to 55 with the new shaft and it was waaayyyy smooth.  Better than it's ever been.
Duffil
I've noticed my housing has one small leak in it, in one of the corners i couldn't get to from the inside.  I'll stitch a bigger bead over the outside later.
snowshoebrue
who did you have turn that down?
Duffil
Quote from: snowshoebrue on July 12, 2007, 10:14:16 PM
one of my customers. He and his dad are jeep guys, and we :bull crap: a lot.  He has a full machine shop at his yard.
