DTB's ANGRY TREE HUGGER (Now pulling an angry pop up camper)
Started by DTB, January 22, 2006, 10:48:06 PM
0 Members and 6 Guests are viewing this topic.
Quote from: skipnrocks on February 05, 2008, 10:37:28 AM
Im sure Ill get smacked for this but what advantage would there be to a marlin clutch?  What sets them apart?  Hopin for an answer other than supporin the site?
i asked Marlin this same question  and here is what he told me
at  idle aka  taking off, the centerforce  is basically  the same as a stock clutch,  it required rpm  to make those little weights  move out  and increase   "load"  on the pressure plate,  the Marlin clutch  uses  heavier springs, (actually dual springs like in the  valve train)  to  practically double the clamping force on the disc  to  increase  take off performance
so if  i had a  22RTE in a  2wd sport truck i would run a centerforce,   but for a 4wd  with big tires  you want the Marlin,  the NON ceramic,  the ceramics GRAB  and thats not cool for a dd  or  a truck that might  tow something
Quote from: sillywilly on February 05, 2008, 10:50:05 AM
my buddy got one and he said it blows for his truck... :dunno:
got one what
DeadlyPeace
#992
I've never used a Centerforce clutch, but I almost did when I replaced mine about 3 years ago. I went with MC The Super Heavy Duty clutch kit with a 1600 ft-lb pressure plate instead cuz of the fact that it had the dual springs so it would give me more bite on takeoffs on the street and when rock crawling. Plus I believe it was cheaper, but I don't quite remember. It's still holding up. I will definitely buy another one when needed.
Quote from: 79coyotefrg on February 05, 2008, 11:08:48 AM
got one what
I'm guessing he's taking about a MC clutch.
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
Never let people think you're a horrible person and always keep the heart of a young child...
       ...I prefer mine in a jar on my desk.
3 CAT scans a MRI and some time with the shrink and it's comfirmed. I'm just not right in the head.
Global Moderator for www.ToyotaOffRoad.com
Doof
i think it was the marlin ceramic... i dont remember ill ask him and post back in here
Quote from: sillywilly on February 05, 2008, 11:19:42 AM
if it  was the ceramic  and he was daily driving,  they i can definetly see why he didnt like it
ceramic  and daily driving  = :yikes:
tom w.
I have the ceramic, and it's not bad at all. But if I had to drive in the city a lot I wouldn't gave gotten it.
skipnrocks
Quote from: 79coyotefrg on February 05, 2008, 10:58:23 AM
Sounds good to me.  Didnt know their was an issue with the ceramic ones? I always heard they were great!
WILLYNILLY
Duffil
that is 100% correct...a centerforce clutch only increases clamp load as RPMs increase.  At idle/where you take off, it is a stock spring providing clamp force, at least with a CF stage 1 clutch...I think the stage 2 has more weights and at the stage3 the increase spring(static) clamp load.
MiniSimp
Duffil
Quote from: MiniSimp on February 05, 2008, 07:34:01 PM
Not 99.9%? :dunno: :gap: 246 toothpicks
every now and then, DA RAINMAN needs a mental break, which I am currently taking :boozer:
:rofl2:
alwayzbroken
I have a centerforce single friction in my rig and I really like it. It is easy to drive like a stock clutch. I don't see why anybody would need any more power. I have never noticed it slipping at all on me. Even dumping the clutch hard with both cases engaged in thick mud has never show any signs of slipping. I would be curious to drive a rig with a dual friction clutch to see what the real difference is. If the single is good, I'm sure the dual friction is better unless it sacrifices driveability.
46&2
Quote from: alwayzbroken on February 05, 2008, 07:51:17 PM
I have a dual friction in my 85 4runner, and i put a single friction in my girlfriends 93. They are both nice IMO. Honestly it is hard for me to explain the difference without you actually driving them both at the same time. the only thing i can say is the dual friction i prefer for offroading over the single friction, THOUGH the single friction does a lot better than a stock clutch offroad. The DF just seems like it is meant for larger tires and the single seems more meant for stockers. The main thing i notice about both of them is that you can bring the idle down to 300-400 rpms without having to put the clutch in. I was never able to get that low with either of our clutches before i replaced them (both with about 2-3 years of driving on the stockers of unknown mileage, but mine wasnt going out, just upgrading). That could just be because both of the clutches were really old. i dont know. I think they are a great, albeit a little expensive clutch. I got mine through my buddy's shop rate so it wasnt as bad as i have seen some places charge though. Over all I would say they both engage very smoothly and predictably and neither one has ever slipped on us yet. I would not say the DF sacrifices any driveability. If I ever run into you on any trails around nor cal I will let you drive my truck around :)
and you wont,  try dumping the clutch on pavement in 2 hi
or better yet Cole,  try towing a  2000-4000 pound trailer  thru town,  then  we'll talk :yesnod:
DTB
Quote from: fortysixandtwo on February 05, 2008, 08:34:21 PM
U might regret saying that to me!  :talkingn: :talkingn: :talkingn:
some good info and opinions here...thanks....
Toyminator helped me get the clutch in last night...went pretty smoothly...
All I can say is WOW....what a difference..there is actually a nice stiff pedal feel and the thing ENGAGES quick...I like it alot..havent taken it off road yet...just driven on the street about 100 miles.....
The true test will be next weekend at Was hita
alwayzbroken
Quote from: 79coyotefrg on February 05, 2008, 08:39:48 PM
If I was towing a trailer it would be with my F-350  :greengrin:
I also have a heavier flywheel. I am not sure how that effects clutch performance but my rig is real easy to drive.
unclejpl4x4
DTB
BUBBA
My budget beater
Doosty
hey dtb hows it going? havent talked to you in forever!
You Haven't Seen Cold Till You Lived Here
Doosty! :wave:  how've you been man?
Goose
So, I was thinkin of going with the heavy duty ceramic..
But after reading some of this people are saying its not so good for DD...
Makes me think now...
Wheres the pics???
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
DTB
Quote from: Doosty on February 10, 2008, 07:20:39 PM
Yo! Big D! :wave:
DTB
Wermz84
I like to Drive!
Doosty
i see ur gettin some work done to your truck..  i kinda regret selling mine
unclejpl4x4
toyspider81
RUN IT!!!
DTB
