We fixed it We trimmed about 1/2" from the right side of the console and slightly bent the wire frame of the leather boot.
Sweet!! Make sure you still have a good 1/4 clearance between the shifter and the body. Depending on what crossmember you guys are using, that drivetrain can move around more then you might think, especially in some situations that you would rather it not pop out of gear!!If a stock 2.28 dual case is popping out of gear, 9 out of 10 times it is interference with the shifter. HD springs are never required/needed on this setup.The install looks pretty good If you want to get the 2nd t/case shifter up higher and reduce its range of movement at the same time, then consider a short throw kit for it. We typically move the control switches there to behind the shifter, and cut a complete square out of that area, and with the short throw, especially if this 4Runner has a rear heater, it fits like a glove, even with with a cab boot Mike
Started by booger_weldz General 4WD Discussion
Started by dms1 Toyota Pickup/4Runner Tech 1979-95
Started by jrock « 1 2 » Project Research and Build-Ups
Started by motoracer « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by Doable Toyota Pickup/4Runner Tech 1979-95
