HELP!! Newb to CV's
Started by *FFC*, January 06, 2006, 02:07:00 PM
Exactly, take 5 minutes to design something that cost $5 more to manufacture then charge $5,000 to fix.  There hasta be somebody nearby that can pop in and give you some help.  Too bad my deal on 2 84s for $400 fell through or I'd be able to help you get an axle :thumbs:
*FFC*
Quote from: 79Coyotefrg on January 09, 2006, 06:18:51 PM
they made it that way so when your brought it to the dealer for replacement they could charge you $5000  to replace a $50 part
:yesnod:
It's retarded... and I'm startin to look for a SA.....
MrW, the d-shaft is on the pass side
reklund5
Ok.  That design sucks.
Here's what I'd do:  Like MrW said, separate the inner joint.  It looks like you might be able to remove the large clamp on the inner CV boot, and pull the axle out of the inner part of the cv joint.  It'll be greasy and messy, but it might come apart.  You'll have to clean out the old grease, and separate the new shaft the same way.  You *should* be able to put some new CV grease in the boot and the inner part of the joint and then stick it back together.  You'll have to put a new clamp on the inner boot, but you should be able to get one from NAPA or the like...
Hope that might work!
Ryan
*FFC*
Ryan, I thought of doing that.  Found that whole writeup on it on 4x4wire.  However... after what I've put that thing through... I'm thinkin I should open it up anyway... I just ain't lookin forward to puttin it all back together once I get it apart :ack:
Anyone know of any axles layin around? :gap:
*FFC*
OR what I can do is what this guy did and just drop the axle :smack: instead of the A-arm :headscratch: :dunno:
reklund5
I told you some  :flamer:  was what you needed.  Just put a 84-85 Toyota axle under it and be done.
Ryan
*FFC*
Quote from: reklund5 on January 09, 2006, 08:30:31 PM
Ryan
I gotta find one first :yupyup: then I gotta find a welder and some brains :disturbed:
Willy Mammoth
Well you are in better shape then someone with a Nissan if that helps at all. They have to use a flipped Toy axle cause the shaft is on the driver side.  :smack:
BLACKDOG
              -Ronald Reagan
*FFC*
uh FFC  what did :psss:  tell you ??   aint he got a welder??   i bet he would help for a :smooch:
*FFC*
Quote from: 79Coyotefrg on January 11, 2006, 08:19:07 AM
Glen, I tried to get a hold of :psss: and it was bad timing.... haven't seen him on since.... :down: And I can't contact him anyway.... can you help me initiate contact if you get a chance when we're all on? :smooch:
BLACKDOG
Quote from: FordFreakChik on January 10, 2006, 07:07:30 PM
Way to go BD :thumbs: :haha:
NOT HAPPENING!
Why not, I'll even do it for you....FREE!!!
              -Ronald Reagan
FATB0Y
SAS that is all that needs to be said :thumbs:
*FFC*
I'm lookin into a coupla axles, and if I go through with it, I'mma have to see bout finding someone with a welder and a torch that'll give me a hand, cuz I KNOW my stepdad ain't for it so he wont' help me do it :down:
Not to burst your sas bubble but have you researched and listed everything that you will need to do the conversion? It's not just an axle you'll be needing to do this.
*FFC*
Quote from: Rocksurfer on January 12, 2006, 07:22:39 AM
:yesnod: It's gonna take me a while to get all the parts, but I'm still researching what I'mma need and what's best to use :greengrin:
BLACKDOG
Quote from: FordFreakChik on January 12, 2006, 07:47:39 AM
well HURRY UP!!!
              -Ronald Reagan
*FFC*
Quote from: BLACKDOG on January 13, 2006, 01:14:07 PM
well HURRY UP!!!
Yer that anxious to help me huh BD :eyebrow: Cuz you KNOW yer gonna get stuck with me :haha:
*FFC*
This is how I got it out... instead of pullin the inner axle...
Dunno if you can tell, the bearing is not centered :headscratch: i'm assuming that's not normal :confused:
*FFC*
My solution :haha:
WOOHOO! Last 6 bolts before the lug nuts go on :woohoo:
:disturbed:
All this time I thought you were unbolting the flange bolts and having trouble getting the two flanges to seperate.
*FFC*
Quote from: kneedownnate on January 15, 2006, 05:34:45 PM
:hahaha: :nope: I was tryin to get the whole half shaft out, inner and outer, but to get the inner out I either have to pull the A-arm or pull the diff/whole driver's side of the axle... I said :nonono: and decided to throw it together then SA it... I go pick up the axle this week, and next paycheck (end of the week) I order the SAS kit and maybe hi steer from Marlin :hyper: :woohoo: and my rears will be in by next week :hyper:
