Author Topic: what do you think my Turbo is worth  (Read 1739 times)
dj
  • Turtle Points: -2
  • Male Posts: 519
  • Member since Apr '04
  • whoops
« on: Nov 09, 2005, 09:52:09 AM »
I have a factory 22r-te turbo set up I was thinking of selling, what do you guys think it is worth.   :confused:
Toyota + Chevrolet = Toylet
82 toylet
400hp of birfield destructing fun
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: what do you think my Turbo is worth
« Reply #1 on: Nov 09, 2005, 09:53:21 AM »
$25 and I'll come pick it up! :greengrin:
dj [OP]
  • Turtle Points: -2
  • Male Posts: 519
  • whoops
« Reply #2 on: Nov 09, 2005, 09:59:09 AM »
I' not even sure I want to get rid of it I might try to retro fit it onto my 2.7 tacoma.
82 toylet
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #3 on: Nov 09, 2005, 01:53:45 PM »
$30!  :_order:
chim
  • Turtle Points: 1302
  • Male Posts: 1,258
  • Member since Apr '05
  • www.infowars.com
« Reply #4 on: Nov 09, 2005, 02:30:47 PM »
I think that your 2.7 taco engine is worth more than the turbo... my grandpa has 3 turbo runners and they are all dogs off the line and run rough after supposivly being "rebuilt". Turbos burn up too quick also.  I think they are only good for freeway, and some hills... so whats it worth? whatever someone is willing to pay! Looks like you have a $30.00 high bid.. I will make it $40!
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #5 on: Nov 09, 2005, 05:04:18 PM »
Sadly the stock ct20 isn't worth jack, now if you had upgraded to a t3/t4 hybrid then the bidding would be on.  Stock setups are low gain/high risk of failure.  If somebody wanted to buy it and upgrade themselves that'd probably be best.
KWP
  • Male Posts: 878
  • Ghost Hunter
    • East Central Oklahoma Paranormal Society
« Reply #6 on: Nov 09, 2005, 05:18:55 PM »
How do you upgrade the turbo? I really don't know that much about them.
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
robrub00
  • Turtle Points: -231
  • Male Posts: 929
  • One Day Ill be actually driving my toyota!
« Reply #7 on: Nov 09, 2005, 10:36:52 PM »
You GEt an intercooler a new bigger turbo and Make an adapterplate for the exhaust housing.  then go from there  New oil lines ect.  TEC( turbo engineering corp) make a kit for under 2000 bucks!
dj [OP]
  • Turtle Points: -2
  • Male Posts: 519
  • whoops
« Reply #8 on: Nov 10, 2005, 09:09:44 AM »
If i retro fit it onto my 2.7 tacoma I full intended on an intercooler and bumping the boost by means of wastegate adjustments I also have very big Garrett from a UD 2300 (nissan cabover truck) with a 425hp I6 Diesel. I am a little scared of putting that on the taco, it would probably waste the engine, it's just too big.
82 toylet
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #9 on: Nov 10, 2005, 01:13:27 PM »
dj,
Seriously, you do not want to even play around with the CT20. It is very small, and is known for it's excessive backpressure.
Instead, if you want to keep it all Toyota parts, and stay cheap, then find a CT26 Toyota Turbo, commonly found on the 3S-GTE engines, from 1991-1993 Toyota MR2s and 1991-1995 Celica Turbos including the Alltrac models.
The CT26 is a big improvement over the CT20, not to mention it's a larger displacement Turbo, which is what would be better for the 2.7.
I would rather run the larger CT26 Turbo at ? 60,000 rpm to get 5 psi instead of running the smaller CT20 at ? 80,000rpm to get 5 psi.
BTW, about 5psi is all you are looking for, right?
Why not run a SC14 Toyota Supercharger unit from a (domestically) 2TZ-FZE 2.4l Engine (Previa SC) or (internationally) 1G-GZE 2.0l Engine (Soarer)? It's a 1.4l displacement, which is just smaller than an Eaton M92 which is used on V6s and V8s.
I still really want to Supercharge my 2.7, but I still think that I will find a rainbow somewhere with a used TRD Smog Legal Supercharger sitting at the bottom of it. But if I get around to it next summer, I will definately fabricate a setup usign the Toy SC14 and nothing less. I bet with just a 1.5 pulley ratio it would eaisly boost the 3RZ-FZE to 5psi. Hell, the SC14 I ran on my 1.6l 4A-GZE Engine in my '87 MR2 could sustain almost 18psi at almost 8,000 rpm.
Anyways, for ALL Driving Conditions, I would much rather have a Supercharger than a Turbo ANYDAY. I've driven both Turbo and SC cars, and I hate having to (1) wait for the boost and (2) not being able to control the amount of boost with the skinny pedal. Once a Turbo starts boosting, if you try to regulate it with the throttle, it'll choke it and kill the boost. Not the case with a SC. Then add a homemade SC Boost controller (the bypass valve method) and you can run any psi you want, from zero to max.
And it I can get 5psi from only a 1.5 ratio drive system with the SC14, then it would save loads of power by not having to spin the SC as much. Heck, I think I had a 2.2:1 ratio with it on my 4A engine. Crazy
dj [OP]
  • Turtle Points: -2
  • Male Posts: 519
  • whoops
« Reply #10 on: Nov 11, 2005, 07:36:55 AM »
Thanks for the input, the theme here is cheap and different from everyone else, I have been keeping my eyes open for a supercharger but have not ran across one yet.
I am wanting about 4-6 psi any more than that would make the combustion temp too high, cause detonation and hurt my engine
82 toylet
  • Male Posts: 9,757
« Reply #11 on: Nov 11, 2005, 05:12:11 PM »
Once again bigmike comes through with some good info!  I'll hafta look for a sc previa at the yard tomorrow, I'll already be there looking for some springs anyway.
Last post Dec 16, 2003, 11:45:06 PM
by 84runner
Last post Jan 13, 2004, 04:12:02 PM
by 84runner
how much is it worth?
Last post Feb 20, 2004, 10:31:50 PM
by 85Yota22rE
Last post Aug 19, 2005, 10:45:58 PM
by 88-REDRYDER
Last post Jan 19, 2010, 07:57:19 PM
by NaturalDisaster
