Well it was just a little smoke!
![hahaha :hahaha:](https://board.marlincrawler.com/Smileys/marlin/hahaha.gif)
the link that was smoking is the one from the alt. and it was only getting hot when the truck was running (alt charging) if I left the ing. on it would stay cold. so after checking my pos wiring dig. and finding that one comes from the alt and that the plug it goes though is making it heat up, I put on a by-pass as to let the power flow to the batt. from the alt. then I removed the plug and wired str8 into the link with a butt conn. I just put in a bigger gas tank, no major work this time.
butt the truck was not run for about 4-5 weeks and the batt would have wanted a lot of jucie!+ junk conn.= smoking (just a little!)
was just wondering if anyone elas had ever seen this on there junk or if you find your two wire fuseable link plug by the batt. getting a bit warm?
