Author Topic: FULL WIDTH ?  (Read 3632 times)
bigman
  • Turtle Points: -10
  • Male Posts: 201
  • Member since Jan '05
  • punish all jeeps
FULL WIDTH ?
« on: Oct 12, 2005, 08:13:29 PM »
ok im thinking on going full width on my 81 but i have a few Qs. first 1 is it street legal 2.what axel should i use and  3. what vehical should i get them out of  :headscratch:
MONTANA BOYS KICK A$$
IF U CANT DUCK IT F IT
toybuilt
  • Turtle Points: -275
  • Male Posts: 1,116
  • Member since Feb '05
  • toy + chevy = Toy-vie
Re: FULL WIDTH ?
« Reply #1 on: Oct 12, 2005, 09:00:15 PM »
Well your sapose to have your finders go out to the end of the tread on your tires, but if you run big mud flaps the cops are normally ok with it. I'm just put a Dana 60 and 14 bolt under my 83 toy, got them out of a 1978 K30 chevy truck.
1983 Toyota Turned Chevy
toyrolet
  • Turtle Points: 62
  • Male Posts: 130
  • Member since Apr '05
  • guns dont kill people!!! people do
Re: FULL WIDTH ?
« Reply #2 on: Oct 12, 2005, 09:51:50 PM »
Woa BIGMAN I see that you are from MT.  Aren't the laws there really leaniant.  i am in WA myself and have put full width 10bolts from a blazer.  going to try and run the mudflap thing but dont really think it will work.  The next choice is to put rubber garden stipping to the inside edge of the funder so it will look like a Jeep flat fender because i have an 86 4runner and the fender have a square opening.  my look hoky but judge mite let it pass and it is easy to reomve when on trail.  Also less expensive then bushwakers that break easy.
Redneck defined: Devine Lack of Sofistication
Life is sexually transmitted
The only difference between a rut and a grave is the depth
Tweeked89
  • Male Posts: 135
  • Member since Jun '05
  • Whoa!!
Re: FULL WIDTH ?
« Reply #3 on: Oct 12, 2005, 11:09:09 PM »
Just run it and get some big NAPA mud flaps.
W.H.O.R.E. founding member
-My G-Ride-[/b]
89 Ex-cab Toyota, V6, Locked Dana 60s, new 39" IROKS, kinda built kinda not
bigman [OP]
  • Male Posts: 201
  • punish all jeeps
Re: FULL WIDTH ?
« Reply #4 on: Oct 14, 2005, 02:51:05 PM »
toyrolet they really easy going in MT im hopin it is ok
what gears are in the k30 or any other 60
and is there a 6 lug or do i have to go 8
whiteman
  • Turtle Points: 669
  • Male Posts: 1,276
    • Buy me a cigar
Re: FULL WIDTH ?
« Reply #5 on: Oct 14, 2005, 03:54:56 PM »
3/4 and 1 ton trucks should have 4.10 or 4.11 gears.  I had a 78 3/4 ton chevy and it had 4.10's.
 :headscratch:  I think I got the 4.11 Idea from my toyota but I am not positive.
wa4x4
  • Turtle Points: -310
  • Male Posts: 1,569
  • Member since Jul '05
  • I'm about to tear the curb up
Re: FULL WIDTH ?
« Reply #6 on: Oct 14, 2005, 04:00:26 PM »
4.11 is a toyota ratio.
whiteman
  • Male Posts: 1,276
    • Buy me a cigar
Re: FULL WIDTH ?
« Reply #7 on: Oct 14, 2005, 04:01:49 PM »
THats what I thought. :screwy:   I get all confused with these No.
k20
  • Male Posts: 55
Re: FULL WIDTH ?
« Reply #8 on: Oct 15, 2005, 02:17:47 AM »
i think the ratio depends on what engine the truck was running
iNfErNaL
  • El Presidente
  • Turtle Points: 109
  • Male Posts: 7,509
  • Member since Aug '04
Re: FULL WIDTH ?
« Reply #9 on: Oct 15, 2005, 03:12:12 AM »
Depending on if you wanna go 1 ton or 3/4 ton.Either way,you'll need to go Chevy.I would look for a military K30-Dana 60 front,14bolt rear,4:56 f/r and a Detroit in the rear...If you wanna keep it 6 lug,you can go with a chevy 1/2 ton 44 front and a semi-floater 14 bolt or a 12 bolt rear.The type of wheelin' you'll be doing should determine your choice in axles.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
 www.RockBrawlers.com
 www.offroadtruckshow.com
iNfErNaL
  • El Presidente
  • Male Posts: 7,509
Re: FULL WIDTH ?
« Reply #10 on: Oct 15, 2005, 03:19:38 AM »
Here's mine...High Pinion Ford 60 front,and Full Floater GM 14bolt rear.
4.3s10
  • Turtle Points: -116
  • Male Posts: 128
  • Member since Aug '05
  • There's no replacement for displacement
Re: FULL WIDTH ?
« Reply #11 on: Oct 15, 2005, 05:51:53 AM »
1990 s10
4.3 bored out .030
Dynomax cat back
tbi spacer
Flowmaster delta 50
Holley 670
Accel coil
2 add-a-leafs
whiteman
  • Male Posts: 1,276
    • Buy me a cigar
Re: FULL WIDTH ?
« Reply #12 on: Oct 15, 2005, 08:36:23 AM »
THey didnt even have one toyota axle, shame. :headshake:
- Sales Employee -
freds40
  • Turtle Points: 293
  • Male Posts: 2,331
  • Member since Dec '02
Re: FULL WIDTH ?
« Reply #13 on: Oct 15, 2005, 08:56:27 AM »
On street legalness, usually states will tell ya you're okay if the tire is no more than 2" outside the fender. Anything more, run a mud flap and if ya get a fix it ticket, rig something up to cover the tires and gt the ticket signed off.
For axles, it all depends on budget and where you see the truck going. If you think you will never want a tire taller than say 38", then you can run a 44/10 bolt up front and a 9 inch/12 bolt in the rear. If you will want to go bigger or will want more motor eventually, then look @ a 60 front and a 60/70/14 bolt for the rear
If you stay with a pass drop t-case, the front axles will be Dodge/GM specific. 44s and 60s can be found in both and the 10/12 bolts are GM specific. For the rear, the 9 inch is from Ford, the 14 bolt from GM, and the 60s and 70s could be found in either Ford, GM,or Dodge.
"between projects"
gotrocks
  • Turtle Points: 107
  • Male Posts: 2,653
  • Member since Dec '04
  • FLOOR IT!!
Re: FULL WIDTH ?
« Reply #14 on: Oct 15, 2005, 10:48:51 AM »
I say go and find a military k30 and get the axles out of it.  I bought my set for $1100 and like it was said earlier, they have 4.56 gears and a detroit rear, mine 60 even has a limited slip (but I have an ARB I'm using though).  It'll be wide but I'm going to see if I can some way make it legal for the street.  Good luck with you decision, and let us know what you decide to do.
Last post May 19, 2005, 07:31:06 PM
by gotrocks
Last post Oct 16, 2006, 03:14:58 PM
by THErED1
Last post Jun 16, 2006, 08:41:52 PM
by jkimmel
Last post May 26, 2006, 12:13:35 PM
by pickemup81
Last post Jul 24, 2006, 04:25:52 PM
by wishin4atoy
