did you do the mounting yourself at home?
Have you had any problem with loosing air over periods of time, other than what might be caused from temperature changes? mine dont leak, just gotta have good welds w/ no pinholes, the only time they get low is when i air down to 2-3lbs 8) And how many cop's have asked if those are real bead locks never had a problem I am thinking about doing the same with my wheels to, any recommendations? nothing that hasent been covered in this thread already
you CAN do it,the thing is a 2.5 BS wheel is actually a reversed center to get the small backspace, which when reversed now puts the safety bead on the outside of the wheel. So putting beadlocks on a reversed wheel is pointless because then you would be having problems loosing inner beads. just use standard BS wheels, lock them, use spacers if need be and dont look back.
KYOTA, maybe you know but...................what backspacing do they STOP reversing the center??? I want as much BS as possible as my current setup is 2.5" BS wheels with 2" spacers. I run like a total of .5" of BS on my axles. That is the setup I LOVE and really dont want to lose that but understand I would have to with my current wheels.
y do the rear leafs stick out so much
y do you newbs dig up such old threads? its probly because he is running 63" chevy leafs
Started by E YOTA Parts Wanted
Started by Jack8542 Engine
Started by camokid Parts For Sale
Started by 4.3s10 General 4WD Discussion
Started by ToYocRawleR For Trade or Barter!
