Project Mo Power
Started by Brandon, August 16, 2002, 10:42:39 AM
83yota
WOW that rig is awsome. i was also looking at a 5.0 for mine. how was the install. i got an extra 5.0 sitting around.  :bowdown:
Brandon
thanks.. 5.0 bolted right in with the NWOR motor mounts.. of course there were a million issues after that but all in all it was TOTALLY worth it. Being able to go up the hills as fast as you want is nice  :yupyup:
tons of pics in the gallery at RiverCityRockCrawlers.com
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
84runner
I just put those Johnny joints on mine just before memorial day and what a pain int he  :moon: I used a C clamp , a socket , and a piece of square tubbing to press against the housing.
Brandon
#63
Quote from: 84runner on June 24, 2004, 01:54:10 PM
Yep, I plan a full install writeup. I have read they are a pain and I will do my best to find the most painless way :)
Brandon Miller
83yota
good luck with your install
yotaboy79
just curios but whats so hard about installing the jonny joints it seems realativly simple
Brandon
squeezing the poly in tight enough to get the c-clips on
Brandon Miller
84runner
Jared
brandon, those doors are looking sick.. remember phillp?  the guy with the rolled truck?  well we started making his doors and i think that we cut a little to low and we just might have to make em like you just did.  keep up the good work.....  :beerchug:
ah the beauty of a cuttin torch
Prismo
Brandon, you started this build up before I joined the board. If only I had been around before you started I could have saved you a lot of time and money. I mean all you really needed was this......
Actually, really nice job on the build up. I am continually amazed at the quality of the vehicles that are shown on this board.
brainlessfool
 :laugh: :hahaha: Prismo, that's to funny  :bowdown:
84runner
I need one of those for my GO=PED  :talkingn:
83yota
83yota
brandon,
i am looking into this idea. i have found a 5.0 out of a 95 mustang. along with the tranny. can you give me a more indepth idea as to what is needed as far as wiring, t-cases, drive lines, and any other problems you ran into? thanks in advance. :thumbsup:
yotaboy79
i dont think your gunna be able to use the tranny that came with the mustang i might be wrong but i doubt it and ive been looking into this and it doesnt seem all that hard i might do this instead of the carbed 350 although a 383 with 450hp would be fun for as long as i can keep drive train parts under it
83yota
i run a 383 in my 72 blazer and it is awsome but 6 miles to the gallon sucks  :moon:
yotaboy79
yeah that is the main thing keeping me from doing it
Brandon
my 5.ota gets better mileage than my V8 grand cherokee and well the numbers might not be there but I haven't been passed by any other rigs yet and most run chebby's ;)
You can use the T5 but I personally wouldn't..
I got lots of tech at RCRC..
Brandon Miller
Brian83
heres a link to brandons 5.0 swap for anyone who has questions
http://www.pirate4x4.com/tech/Engine/index2.html
Common sense just isn't that common anymore
Brandon
Quote from: Brian83 on June 28, 2004, 10:31:23 PM
That one is outa date and needs to be updated or ditched, go here..
http://rcrc4x4.com/
http://rcrc4x4.com/TechReports/MoPower/mo.htm
lots of newer stuff there including wiring diagram, tons of pictures etc..
Brandon Miller
Brian83
thanks, actually I was just at rcrc looking at your site. cool.  :biggthumpup:
Brandon
guess I'll add to my update here :)
welded the AP JJ's onto some steel plate and put them together tonight. Gonna try something since I don't know what springs I want to use. I am going to weld some reciever tube to my frame and gusset it. It will have several different sets of holes in the bottom of it and this AP JJ setup will also have a few holes allowing it to be moved along the reciever tubing. I don't think it will look too hoaky but we'll see..
It should give me a bit of lift which I want..
Surprisingly easy to get the joints together after all I read. Here was my assembly tool.
the beginnings of a tapped and rebuilt IFS box..
Brandon Miller
84runner
What do you think of those greasable bolts ? I think there kind of cheesey myself , cause the grease zirk is not threaded in, just tapped it, I had to of them come out while I was greasing my JJ  :headshake:
At our shop, Andy, if you've ever seen his AMAZINGLY CLEAN buggy, did this using our Jonny Joints for his rear suspension and he loves em.
But its a buggy and not a daily driver, so.....
(sorry Brandon for kind'a hijacking your post, but the joints are related!!)
Brandon
Quote from: BigMike on June 29, 2004, 12:57:20 AM
... our Jonny Joints
Hey I asked Geiger if you could get the JJ's and he said no..
I have ran front northwest off road greasable bolts for yeeeaaaars and no complaints - I really think it helped up front. As for the rear I am putting the zirks to the inside but we'll see if they stay on - my knuckles and driveshafts no longer have em ;)
Brandon Miller
QuoteHey I asked Geiger if you could get the JJ's and he said no..
Woah, I did not know that. I've been talking with Andy about them :psss: (for my pickup) and I thought we stocked them :headscratch:
:dunno:
Brandon
probably a misunderstanding but I did try  :beerchug:
Brandon Miller
84runner
I did too I always try Marlin before I go somewhere else
Brandon
Brandon Miller
