Project Mo Power
Started by Brandon, August 16, 2002, 10:42:39 AM
Good to know that you have your issues resolved.....well at least the ones w/ the truck. ;)
WT
84runner
#31
Quote from: Brandon on February 18, 2004, 02:27:42 PM
what is wrong with this picture?
:headscratch:Looks like you polished your vavle covers to much :eyebrow: Is it the pic or is your reliefs in your first 2 pistons missing?
Brandon
blown headgasket was the right answer ;)
not sure why the blue looks so "baby blue" but it is ford blue - camera makes it look lighter.
Got it just about all back together, just gotta refab a new exhaust system!
I used arp head studs instead of bolts
my helper finishing up..
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
Brandon
currently reworking the headers.. to make em fit :)
Brandon Miller
Prismo
Looks very nice, those headers are close!
Brandon
beyond close, the steering box is spaced out 1.5" from the frame in that pic :(
Exploring other options like different steering boxes. The IFS one doesn't work because it hits the power steering pump on the 5.0
Brandon Miller
84runner
Might have to go full hydro
Brandon
Quote from: 84runner on February 27, 2004, 11:15:16 AM
It's my highway commuter, so I dunno bout dat!
Brandon Miller
84runner
Its your daily driver too :smack: well then what about going with a race car like power steering pump? I know the one my friend runs on his promodified is real small.
Brandon
#39
gettin there..  Fired it up finally - exhaust is just tacked together right now so it sounded like a hot rod :)
exhuast made from mandrel bends.. butt welded together
FINALLY figured out the proper use of a full Bud Light can (they were given to me for some work I did, never could figure out what they were for)
tight fit! I am touching brake, fuel, AND clutch lines so I gotta do some re-routing :(
Went back to a toyota box, adapted to my AN hose for the high side and a brass fitting for the low side.
The arm is temporary, I got a real one in the mail (Gotta get the nut n washer from the dealer still)
Brandon Miller
Brandon
got it up on the rubycon last weekend, hmm I think I need to do something with the rear suspension..
Brandon Miller
Brandon
more here
http://www.rivercityrockcrawlers.com/gallery/albums/rubicon5_04/
I don't know what caused it but the nut on the top of my power steering box backed off and it shot all my fluid out. Then because of manual steering I stripped the splines on my steering wheel (patched with some aluminum foil). Engine ran great, I won't be doing a whole lot before my next trip. It was nice to fly up the hills at 70-80 mph getting to the trail  :driving:
Brandon Miller
84runner
What kind of MPG ? Just curious, not like it matters
Brandon
Brandon Miller
84runner
Thats as good as my 4 banger runner turnin 36's  :yupyup:
Brandon
Quote from: 84runner on May 26, 2004, 09:56:05 AM
does it do 80mph up the hills and peel out in 3rd gear on asphalt?  :joke:
Brandon Miller
yotaboy79
with my 4banger and 31 in tires im getting 14mpg when i baby it
Brandon
If you had a 230 HP, 300+ ft-lb torque v8 you probably wouldn't baby it ;)
Brandon Miller
yotaboy79
hell no and i prolly wouldent have a tranny long any whay instead of replacing it ever 5,000 miles id be replacing it ever 5 miles. i plan on doing somthing similar to what your doing except im gunna run chev 350 or 327 th350 tranny dule cases and dana 44 front and dana 60 rear, what tranny are you running?
Brandon
HD 44 (Reverse cut) front, D60 rear (35 spline moser shafts, disk brakes, etc), NP435 4speed, dual 23 spline cases, etc etc..
Gotta go fuel injection fo sure  :yupyup:
Brandon Miller
Brandon
current project is new half doors. You can see in the other pics that I have made doors in the past but I wanted to try something different.. sort of..
making "inserts" like broncos that I will run
and then I am going to make some half doors to slip in for when the wife is with me or for longer trips etc.. I got it all figured out just need... time :)
Brandon Miller
84runner
Don't forget the money 2
Brandon
Brandon Miller
84runner
Quote from: Brandon on June 13, 2004, 10:26:23 PM
You said you just need time but you always need money right  :dunno:
Brandon
gotcha ;)
I trade for my stuff for the most part but ya always need money! If I had the money I'd just buy this stuff built though ;)
Brandon Miller
84runner
I have thought the same thing about buying it  :yupyup: but then it's not really yours you know . That's just how I feel , I'm proud like that I guess  :dunno:
Jared
building stuff yourself can always save money but with the prices of steel you might as well just say screw it..... Sometimes youd be better off just buying it built... :dunno:   :_oops:
yotaboy79
Brandon
door inserts in progress..
Got Johnny Joints and greasable shackles ready to go on too..
BTW I did check with Chris first to see if marlin carried the Johnny Joints but I am VERY impressed with the AP setup, shackles and all. It will be the first AP thing on my truck but like I said, I am very impressed with it all.
Brandon Miller
