Project Mo Power
Started by Brandon, August 16, 2002, 10:42:39 AM
Brandon
1983 Toyota pickup..
I bought it 12 years ago now and the project is still going. Current status is little odds n ends to make him legal (ref time)
Sports Marlin Crawler dual 23 spline cases, but axles are now front HD HP 44 with hi-steer, rear is a 60 with 9" ends and disk breaks, spool, and 35 spline moser shafts. It has a removable top, flatbed, rear mounted radiator, half doors, etc..
Best part is that purrin High Output Ford 5.0, gotta love power that puts you in the back of your seat with 38" swampers..
Tranny is a NP435 giving me a low of 142:1 with 4:10's in the diffs and 2.28's in the cases.
http://www.rivercityrockcrawlers.com/TechReports/MoPower/mo.htm
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
Brandon
#1
had to have a custom speedometer cable made with one side to the automter gauge, the other to a speed sensor that adapted to the toy tcase
Brandon Miller
yota83
#2
ill conferm the sweet sweet sound of the purrin 5.0... ::)
man it sounds nice... now lets see you smog it so you can hit the trail brandon? ... lol
i cant remember!!!!!
CRAZY PEOPLE ARE NEET!!!!!
Brandon
#3
Truck is SMOGGED AND LEGAL..
I just built the front bumper for my 8274..
Brandon Miller
brainlessfool
#4
Hey Brandon, looks sweeeeeeeeeet!:thumb: how bout some more pics of that dash you've got? it looks very nice . I have an 83 and the dash is so small that any way to do some mods to it or of great intrest to me:drool:
cruzila
#5
Nice job on the bumper :thumb: Got a full pan back shot of thr rig with the bumper and roll bar?
dhbiker456
#6
  Clean swap.   :beer: :bowdown: :bowdown:
   But i still dont like Ford Engines  :disturbed:
Dont blame me for something breaking on your truck it was your fault you followed me.
Brandon
#7
QuoteNice job on the bumper :thumb: Got a full pan back shot of thr rig with the bumper and roll bar?
I need to take a real clean one so I can start getting ideas for my new flame paint job :)
old bumper in that shot, side view of my bumper though..
Brandon Miller
Brandon
#8
Quote Clean swap.   :beer: :bowdown: :bowdown:
ride shotgun and I'll change your mind..  :beer:
Brandon Miller
Brandon
#9
winch is recessed in a bit, cut the grill out behind it. Still have room for my ac stuff back there though :)
Brandon Miller
brainlessfool
#10
that dash:drool:
Brandon
#11
check out my switch panel :)
Brandon Miller
cruzila
#12
Which one is for nitrous?
Brandon
#13
plasma's are cool..
still need to put a top on the bumper, can't decide metal or aluminim diamondplate. Still workin on the flame scheme too
Brandon Miller
Squirrel_4_life
#14
That rear mounted radiator, how well does it work. Did you simply move the radiotor to the bed and run longer coolant lines to it?
85 x-cab, 22re, welded rear, 5.29's, marlin high steer, front axle forward 2", rear moved forward 9", ARB hilux bull bar, flatbed and 37's on the works
cruzila
#15
Quoteplasma's are cool..
Use expanded or perforated metal :thumb:
Brandon
#16
QuoteThat rear mounted radiator, how well does it work. Did you simply move the radiotor to the bed and run longer coolant lines to it?
works great, hardly need a fan. Stays at whatever thermostat I use..
I used copper lines with hoses at the ends
Brandon Miller
#17
hey brandon nice job on the swap :bowdown:
heres another way to do the lines
i went to school with the local exhaust god. made the job easy. at first i didnt want to use exhaust tubing, then it clicked, antifreeze is an anticorrosive!
#18
heres another one
Brandon
#19
I wish I knew someone that could do that for me.. How is that flat rad workin??
Brandon Miller
#20
it sure works great no matter how much mud gets caked on it it stays cool.  soon im either gonna replace the bed or cut the supports out and give it a bit of an angle cause its just a little tricky to fill!!! luckily i have a very steep hill on the side of my lawn that i drive up to fill it.  just pull the upper hose and fill away like normal.
hows yours did you have to pull your hose off of the engine to get rid of the impending air lock of did it fill ok?
#21
exhaust is kinda close :smack:
Brandon
#22
I had it get air bubbles a couple times, but it is working well now. I would like to put another fill at the engine sometime
Brandon Miller
Brandon
#23
slight fender trim, got plexiglass and/or expanded metal for the holes to put in still
Brandon Miller
Brandon
#24
bumper
Brandon Miller
Brandon
Brandon Miller
Toyoballs
So are you going to be able to reuse your orig frt grill - from the photo's it looks like it.  BTW reaaaaaaally nice work, looks great
Just Grind It Down To Metric...
"MAKE IT OR BREAK IT"
Extreme Off-Road Club
Brandon
no, the radiator is where the grill was - so no hood latch either. I have a toyota land cruiser grill I will put in front and then fab something for the sides. Most will be hidden by my bumper with 8274 in it anyway
Brandon Miller
Brandon
rad is back up front and I still have issues! Drove it one day and the next it shot to 240 (air in the system) so I'm rippin the motor apart..
if there are any motor guru's here maybe they could recommend what to do with the heads and if I should do anything else, here are the plugs (distributor would be at the top, firewall at the bottom)
Brandon Miller
Brandon
what is wrong with this picture?
weeeeeeeee
Brandon Miller
