Hey T....I love that color on your truck!! One of my all time favorite colors for a vehicle. If I had to paint my white '86, I hope you don't mind me painting it the same blue!!Gnarls.
Thanks. I really wanted to stick with the factory blue but I'm real happy with this blue as well. At this point I dont think I even have a preference, they both look good. I wish I would have used a more durable paint though.
Got some EMF tie rod ends EH! I ordered them in pairs and luckily got my second order in right before they decided to stop making them. Hopefully they get back to making them eventually. I'm just going to stash em away and install them as needed.
Dang it.. you lucky guy.. im on a list right now..been waiting forever it seems,
I love the truck, it looks great! Hopefully my pro-comp springs survive better than yours did. Looks like you took out more leaves than me...Sorry you've been having so much trouble with the charging system.Know anything about the GM alternator conversion? I'm looking at it for my truck for reliability and parts availability.
LSPV going bad (if you still have it). Not enough free play in the pedal, master is not opening to release pressure. Or your booster is getting stuck boosting. You can test those by jacking the rear up with the engine running, pumping the brake pedal a bunch of times, then checking if the rear tires are locked up once the pedal is released. Curious what other ideas people have for faults / diagnosing.
Summer is almost here and the truck has been running good. HOWEVER, my rear brakes have decided to start dragging and I need some help. I've only got around 5K miles since I changed the shoes and until recently they have been fine.First time they did this I could feel the truck was down on power and when I got home the drums where hot and I could smell brakes. I crawled under there and used the star wheel to back the shoes off. The manual said I could use the Ebrake to adjust the shoes, so I pulled on the Ebrake a bunch I took it for a couple short test drives and it seemed ok, until yesterday. 15 mile drive and again hot brakes. Now I've got the drums off and everything looks real good other than I think the shoes are glazed (can I bring them back with some sand paper?)Any ideas what I might have going on? Only plan I have is to put it back together and see what happens.
this is the most likely culprit https://forum.ih8mud.com/threads/rear-brakes-over-adjusting.327957/page-3#post-10581135 ebrake over adjusting
oh yeah, you may need 2 washers
I suggest removing the OEM LSPV... I did as I was having trouble with adjustability after so many mod's.Here is what I currently run:
Started by sinbob « 1 2 3 » Project Research and Build-Ups
Started by Dr.Maxwe001 « 1 2 ... 6 7 » Toyota Pickup/4Runner Tech 1979-95
Started by HogCanyonHopper « 1 2 » Project Research and Build-Ups
Started by 84Yota Parts For Sale
Started by gottadog Parts For Sale
