The pulley can be tough to get off. Loosen the nut, and take a small rubber mallet and tap the lip and spin the pulley. Eventually it will break loose. Don't hit it too hard. Just tap it. Spray it with some penetrating oil. Its just on a key way on the shaft. And mark the way the pulley comes off, because its offset.
You must have a special one then. Cause I had to on mine.
There's no reason to go the trouble of unbolting the cab. You have to lower the angle of the transmission t-case anyway. Unbolting the cab mounting on a 32 year old truck is something I would NOT do to pull or re-install the engine.But... I guess whatever works for you.Gnarls.
It takes maybe 15 minutes to remove the bumper and 3 cab mounts, it isn't any trouble at all, and never had an issue with lifting the cab on a truck, as I replace the body mounts on every truck I restore, the last one was 30yrs old...
I got the engine separated from the trans and pulled Sunday. Today I was able to take off early and start moving some of the old parts to the new Engine. I think for my level of mechanical skill things are going well. I was going to post some pictures but it keeps saying my file is too big. I got new body mounts in a kit but they have been in a box since I thought it would be a lot of trouble to install them. Sounds like I need to do this after installing the new motor so those Two Bolts will be easier to get to. I didn't have a chance to mess with the PS Pulley yet. Anyway, thanks for all the replies and encouragement.
As Snowtoy explained, stupid easy fix. I have done a half dozen myself. Small pick, solder, heatshrink it, and reinstall. It takes me longer to get the solder gun heated up, than it does to fix it.
Man I have been fighting to get the new engine back in today. This joker doesn't want to go back in there. Am I missing something?Any ideas would greatly be appreciated.
Yes sir.
So should I unbolt the cross member and support the transmission then try to mate it?
It took me awhile to finally get the input shaft to finally slide in.....
One of these helps:http://www.harborfreight.com/2-ton-capacity-heavy-duty-load-leveler-60659.html
Started by brainlessfool Chit Chat Camp
Started by KYOTA Chit Chat Camp
Started by RokCrawlinToy « 1 2 » MCR8 (Sept 11-13, 2009)
Started by benzo87yotr Project Research and Build-Ups
Started by RockyTOY Rigs For Sale
