With silver solder, you need to apply the flux inside the connection, and it will pull the solder inside the hoping, sealing it. Don't try to apply it to the exterior of the joint the way you might weld it, that will just end up leaking.Looks like a factory fit though Sent from my LG-H830 using Tapatalk
Correction, 85 and later 22re oil pans you don't use a gasket, that's why there's a dimple going in. On 84 and earlier oil pans you do use a gasket as that bump is pointed out to help seal the oil pan to the block.
Yeah, this should definitely have a gasket.. I'd double check that master kit, then email Tod of you can't find it.. this is the pipe that bolts to the backside of the water pump right? Be sure to use permatex blue, be for water pumps and thermostat housingsSent from my LG-H830 using Tapatalk
I remember that my master rebuild kit came with it.. i can go grab one from Tod tomorrow and send itSent from my LG-H830 using Tapatalk
Yes it uses an o ring with no sealant. You can get one at your local parts store, it's what I always do.
Just so you guys know I'm not whacko.... I've attached a photo of 2 rings that came in the little plastic bag with the seals for the rocker arm cover. I checked very carefully to see if either one would fit inside the port... NO BUENO.And... I'm not yet sure what those two rings will go to by the time I get to find out.Gnarls.
Does the rubber o ring fit the bottom of the 710 cap..... Wait,oil cap
Gnarly, I fought a leak from there until I put the O-ring in. After that it never leaked and I didn't use any sealant. I had used sealant before but it didn't hold. There's no pressure in that hose as well, all that area does it give you your coolant temp.
Oil cap???.... the oil pan drain plug??.... no it does not.Gnarls.
sorry nothing to reference size with, stick a dollar bill next to it
Started by alfio Parts For Sale
Started by dune_it86 Engine
Started by richard head Toyota Pickup/4Runner Tech 1979-95
Started by KDXSR5 Toyota Pickup/4Runner Tech 1979-95
Started by 83yota Project Research and Build-Ups
