Man I have been fighting to get the new engine back in today. This joker doesn't want to go back in there. Am I missing something?Any ideas would greatly be appreciated.
, When you installed the clutch, did you align it? I have found when mating the two, leave the trans in gear, with the engine at the same angle as the trans, slide the two together, if/when stopped, turn crank a little to get the engine to mesh with the output shaft. This usually gets the two within 1/4" to 1/2" of each other, where you can then use the bell housing bolts to pull them together.If you have the engine mounts installed, you may want to remove them to give yourself more clearance until you get two together.
I highly recommend that you DO NOT use the bell housing bolts to mate the transmission to the bell housing. The transmission and the bell housing should mate almost completely flush with each other IF the tip of the shaft on the transmission has been inserted in the pilot bearing and there is nothing binding.That's just my opinion - it may be worthless.Gnarls.
I said pull them together, not force them together, , at a 1/4" or so everything is aligned and you can usually turn the socket with your fingers or spin the ratchet effortlessly. I have done it this way several times, whether mating the two in the truck or on the shop floor, no issues at all.
So should I unbolt the cross member and support the transmission then try to mate it?
I've done it this way twice....Yes, the risk of bending the Tranny drive shaft is there, but here's the tip.
Yes I am still fighting with it but have not messed with it much Saturday or today. I usually go bass fishing on the weekends. I had it put together once this morning but pushed the intake side to get the motor mount bolts to line up and it slid back out. I only have the motor supported by one chain and its a little crooked on the cherry picker. I think if I get one of those load levelers I can get it to mate correctly. I do agree you guys make this look too easy. I do appreciate the advice.
If it has slipped all the way and mated with the bell housing, then your clutch disc is aligned – obviously that’s big plus!That HB leveler does help get the engine at the right angle.You’ll getter done after you catch a few fish. Gnarls.
Did you catch any fish? Where's the engine sitting? Gnarls.
..... Every time I would get it in there the new motor mounts were off ....
Hey Hickory Nut,Great job on making some excellent progress!! Gnarls.
Don't forget to put a good charge on your battery before startup. Nothing like getting all excited about putting life into the motor, and then the battery is dead, or too weak.
Started by brainlessfool Chit Chat Camp
Started by KYOTA Chit Chat Camp
Started by RokCrawlinToy « 1 2 » MCR8 (Sept 11-13, 2009)
Started by benzo87yotr Project Research and Build-Ups
Started by RockyTOY Rigs For Sale
