Scott Wilson's 1988 4Runner Build, Version 2.0
Started by swilson, May 30, 2016, 10:56:03 PM
swilson
Quote from: Willard on May 23, 2020, 08:17:55 PM
Man, I had a piece of 3/16" aluminum cut out for mine and will secure it with riv-nuts. I really like the cutting board idea as well! That stuff is not cheap either. Where did you snag a sheet of it from?
Actually it was cheap!  About $30, cut to size.
Port Plastics
550 E Trimble Rd # A
San Jose, CA 95131
Scott Wilson - TLCA #5261
1966 FJ40 [sold] - Click for Build thread
1988 3RZ 4Runner - Click for Build thread
1964 FJ40 TBD
Willard
I'm gonna look into that. Seems easier to clean than aluminum would be lol. Cool deal and thanks for the contact info!
gnob
I pulled all the shyt out of my cargo area.  I use recycled tire mat on the bed.  I really like the cutting board.
People dig on stock plastics, but all that stuff does is squeak and rattle.
hold this. . .
swilson
Long overdue, I finally finished off my B pillar emblems.
From 10' away they look amazing.  Up close, they're ok
1964 FJ40 TBD
swilson
Since putting the 37" spare tire on back, my rearview mirror has been nearly useless.  I started shopping for a rearview camera with a small video screen built into it
I ended up finding something even better, a rearview mirror that is also 100% video screen. It's a BrandMotion FullVUE FVMR-1000. I has front and rear 1080p cameras.
I was able to fish the wiring harness through the dash, up the A-pillar, and through the roof.  After removing the stock mirror I was left with a whole, which was perfect for the harness to drop out of.
Only installation trouble was glueing a standard mirror mount to my windshield.  Took 4 attempts before it finally held.  I think I was dealing with bad adhesive.  Once I bought a fresh package, it stuck.
When it's powered off its a normal review mirror.  When powered up the whole screen is a video screen.  Tilting the mirror so that the reflection you see is now the cab of the truck gave me the cleanest view of the video screen.
In rearview mode (which it automatically starts up in when you key-on) it gives you a zoomed in image that is consistent with what you'd see from looking in a rearview mirror.   When you shift into reverse it switches to a wide angle view, with grid lines, like you see in most OEM backup systems.
Finding a spot to mount the camera that gave me the best image for both rearview & backup modes was difficult. I ended up putting in the empty receiver hitch. I don't ever expect to tow with the receiver and I have 2 other shackle mounts on the rear bumper.
Driving on the road, it's a good rearview.  Doesn't take any getting used to.
Rearview mode works well, but doesn't give much depth perception.  It would work better if it had 2 cameras... One level-for the rearview, and the other at a down-angle-for the backup mode.
When you're driving, it's recording the footage from both front and rear cameras like a dash cam would.  It also has surveillance modes for when you're parked.
Haven't tried it at night yet, but so far I'm happy with it [emoji106]
1964 FJ40 TBD
swilson
Garage art!! Gonna have to hang these ASAP
DB Metal Marvels is the shop that made them. They're in AZ
Sent from my Pixel 4 using Tapatalk
1964 FJ40 TBD
swilson
After adding the 37" spare on the back, the rear of the 4Runner was really sagging.  And that's with no wheeling/camping gear in the bed.
I called Alcan and got them to make a duplicate set of my springs, but without the expensive main leafs (due to the orbit eyes).  Kind of like a 6 leaf add-a-pack.  Instead of 7mm leafs, they used 8mm.
First I installed my main leafs on top of the new packs, but the end result was a 5-6" increase in lift.  Then I started over and built a pack using only 3 of the thicker leafs, alternating between the 7mm leafs.
The end result leveled the truck out nicely.  Since it has a higher spring rate now, it should sag less when I'm loaded for the trail.
I have a lot of extra leafs now which is also handy.  Any future rear suspension changes will be a quick reshuffling of leafs until I have a pack that works for what I need.
I also finally went through my parking brake cables and have a P-brake that will hold on an incline again.  After a couple Rubicon trips I had stretched the cables enough that the p-brake wasn't working
Did you know that a 3RZ can do a burnout, even with sticky 37" tires?  I found out last night!  I was teaching my daughter to drive a stick shift.  She had stalled out on a hill and was super freaked out that the truck was rolling back as she switched from brake to gas to get going again.  The end result was her redlining the engine and dropping the clutch. She sure lit up those 37s! [emoji43]
1964 FJ40 TBD
helipilot77
Your build inspired me to go with the NWTI rear bumper. I really like the look of it.
OVRAROK
Quote from: helipilot77 on July 27, 2020, 02:18:29 PM
His rear bumper is a 4x4 labs bumper WIY..
swilson
Not familiar with that one.  Got a link?
1964 FJ40 TBD
swilson
A friend bought a built JK and needs to learn how to drive it. Spent Saturday goofing off at Hollister hills with him.
1964 FJ40 TBD
helipilot77
Quote from: OVRAROK on July 27, 2020, 02:28:07 PM
After posting I went back and read that it was a 4x4 labs bumper.
Quote from: swilson on July 27, 2020, 04:44:11 PM
https://nwtrailinnovations.com/toyota-4runner-bumpers/toyota-4runner-1984-1988-bumpers/1984-1985-1986-1987-1988-1989-toyota-4runner-rear-offroad-bumper
They look pretty similar but I like the side protection thay the 4x4 labs has. I might add that to the NWTI bumper.
swilson
Last year on the Rubicon I noticed my passenger slider had bent up and contacted the body.  I finally took a closer look and saw the frame had split.
I cut the gusset free and hung a 1/4 wall piece of tubing from some soft shackles.  Then I drove my Tacoma onto the pipe.  Then I welded it up and added a new gusset over previously cracked area
1964 FJ40 TBD
swilson
#373
I spent some time this week cleaning up my center console.  At first I thought about copying the factory style and making some custom vinyl shift boots.  The more I looked at it, the rubber shift boots I already have look pretty good.
I decided to make a panel to fill in the gaps instead.  I realize there would be a large flat area if I just used a flat sheet of plastic. I decided I'd like a coin tray there.  I ordered some kydex which can be heated and molded to shape. Once it cools it holds the new shape.
I just happened to be building a small vanity top for my RV, so I had a sheet of Corian laying around. I cut out the shape I wanted and routed the edges round to create a buck to mold my kydex.
Just for the time being I sprayed the factory trim piece with a spray dye I had on hand. I'll respray it once I find a better matching spray dye
1964 FJ40 TBD
emsvitil
Where are you going to put the Super Big Gulp?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
swilson
I couldn't figure that out.  Too many shifters in the way!  I'll have to build a set of half doors with a cup holder built in
1964 FJ40 TBD
helipilot77
Cup holder are a real problem in a 1st gen 4Runner. I used to have one on the passenger side of my shifters but then I realized that the passenger seat would hit it when it would slide forward to allow access to the back seat.
cbeers
http://www.etsy.com/shop/bh3dprinting
i hope this is ok to post?  i just got their bpillar badges.
CB
helipilot77
swilson
Wow, they make some cool stuff.
I spent the last few days on the Rubicon. Went from Loon to the overlook and back to Loon. Pretty good weather... But lots of smoke in the air.  4Runner ran great!  Kissed the back corner... Needs a new taillight
I'm EXTREMELY happy with the new swing out on the back bumper.  Really worked great. Much more cooking area, loved having my water out of the way, and the telescoping light was awesome around camp
Tried towing with the Tacoma for the first time. It was asking a lot of the Tacoma, but it did well.
1964 FJ40 TBD
helipilot77
So I would ideally like to go with the Alcan orbit eyes in the back of my 4runner but I am feeling intimidated by the idea of ordering a set of expensive custom springs that are calibrated to my setup with the drawers and rear bumper and whatever gear I plan to carry. If they don't work right for my setup I will be stuck with a set of springs I can't use that cost me a pretty penny to have built. Can you offer me any solace?
swilson
I've had a lot of luck pulling bottom leaves to lower ride height, then as the packs break in I put the leaves back in.
So I suggest ordering them for a bit more weight than you really expect to put on them.
1964 FJ40 TBD
Huh, nothing wrong with that light crack adds character.
swilson
Another trip to the Rubicon, another set of shackle bushings.  I think I mentioned before I was considering hitting my machinist buddy up for a set of stronger bushings. I need to do that.
1964 FJ40 TBD
mudmaster
Time to go wheelin!
swilson
Half day at Hollister Hills too, but I doubt that did much to them
1964 FJ40 TBD
Engi-nerd
Quote from: swilson on October 09, 2020, 12:07:16 PM
Look into UHMW-PE.
Good stuff - super wear resistant, chemically inert to most things, self-lubricating, and generally pretty tough.
McMaster might have something that works:
https://www.mcmaster.com/uhmw-polyethylene-bushings
mudmaster
I remember someone making some a few years ago.......
Time to go wheelin!
Ghettofab88
I've seen a guy that was using bronze bushings.  I might try it in the future.
Kevin
ScaldedDog
Scott, after our text conversation yesterday, I've been reading this thread every chance I've had. What a great rig you've built!! As you know, I'm just starting a delayed 4WU 3-link project, and am thrilled at the great way you documented yours. I'm starting to have bad thoughts... about chopping off the front of my frame, though I think I'd do it in front of the motor mount. I just want to clear the links, and I'd like to move my steering box up an inch to get it out of the way. With no more spring hangers in front it, it's going to be out in the breeze.
Here are a couple of pics of your old rig from this year. The first is just a poser shot from Moab, as I knew that was the last time it'd be clean for awhile. The second is the last pic with the old suspension, before I cut the leaf spring stuff off.
For those who don't know, I'm the guy who bought Scott's first 4Runner, just over 20 years ago. I clearly have a much longer automotive attention span than he has :D , as I still own it. It still looks, at a glance, a lot like it did then, though I've done a lot of work on it. It's been a terrific rig for our family. If you happen to remember the PIAA lights Scott had on the front of the 4Runner, they are still around, on the front of that Excursion in the pic (which I've owned for 17 years.) I live in the country, and they make great deer lights this time of year.
Mark
