Scott Wilson's 1988 4Runner Build, Version 2.0
Started by swilson, May 30, 2016, 10:56:03 PM
0 Members and 22 Guests are viewing this topic.
swilson
Yes, bought the rock lights from Marlin.
Paint was done at M&S Collision in Santa Clara.  They painted my FJ40 years ago also
Today I finished up the lower portion of the swing away, welded in the latch, and welded in the hard stops - so they hit a stop when closed and hit a stop when they open 90°
Scott Wilson - TLCA #5261
1966 FJ40 [sold] - Click for Build thread
1988 3RZ 4Runner - Click for Build thread
1964 FJ40 TBD
swilson
#331
Put in the struts tonight.  They were in stock at AutoZone
1964 FJ40 TBD
cabot
swilson
Still making progress. Tire is mounted. Telescoping pole for the LED floodlight is mounted. Front Runner shelves with slide out cutting boards are mounted.
More to come!
1964 FJ40 TBD
swilson
Sweet! I haven't played with it yet, but it sure looks cool!
Might have to fill the fender bolt holes and paint it to match
http://blog.rcmart.com/rc-kyosho-new-mini-z-4x4-rtr-crawler-toyota-4runner-hilux-surf-suzuki-jimny-sierra/
1964 FJ40 TBD
gnob
hold this. . .
swilson
I really need a CNC table.  This took me about 5 hours by hand.  ... And it's still not welded
1964 FJ40 TBD
gnob
hold this. . .
Willard
It really is amazing the quality of your work man. It's inspiring! Also, at least you can say you hand CNC'd it lol. Good job!!!!
swilson
Thanks guys
I enjoyed making it the water jug holder, but what a time suck!
With just enough room left for the Powertank, I am officially out of space.  The license plate will actually get mounted to the HiLift, because except for inside the spare wheel, there's no space to mount it!  (I have a Trasharoo, so I don't want to do the spare tire idea)
I want to make a couple of changes to the bumper and then it all goes out for powder coat
Suspension changes are in my future... The tire is so heavy the whole truck leans to the drivers side
1964 FJ40 TBD
emsvitil
Quote from: swilson on April 06, 2020, 10:25:26 PM
Put another water holder (or fuel holder) on it to the right..............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
cbeers
is your release handle safe from rocks? very impressed with all of your work!
:beerchug:
CB
84 yota dude
Nice work!!
What about mounting license plate to water jug holder?
swilson
Quote from: cbeers on April 07, 2020, 08:19:51 AM
:beerchug:
CB
If I try hard enough, not even my sunroof is safe from rocks [emoji16]
Thanks!
1964 FJ40 TBD
swilson
Added more structure between the hub and swing-outs
1964 FJ40 TBD
swilson
My bumper was off when I was flaring my fenders.  As a result, the lower edge of the fender stuck out too far.  I already scraped one with a rock.
I added on to the bumper to get more paint protection.
Everything's off to powder coat tomorrow
1964 FJ40 TBD
swilson
#346
All of my Alcan springs have been hard on spring bushings. Looks like I was overdue in changing them.
Here's one of the suspension upgrades I was referring to.  I've been thinking of adding a sway bar for awhile.  So I took the plunge.
I took it for a joy ride tonight and was extremely happy with it!!   It handled downright sporty on some curvy roads, albeit the truck was extremely light ... no load, no bumper, and no swing-aways.  I'm sure even with a load it'll be a huge improvement though.  And thanks to a cool equalizer app gnob told me about, AC/DC was sounding even better too [emoji106][emoji106]
My body roll was a bit out of control with orbit eyes in both ends of the Alcan springs. The sway bar tightened things up nicely.  If I don't like how it behaves off road, I'll just disconnect a link when I'm airing down.
I also need to adjust pressures in the ORI struts, they're contributing to the drivers side lean
1964 FJ40 TBD
gnob
What am I missing? Do you have bushings or orbit eyes?
hold this. . .
helipilot77
Quote from: gnob on April 13, 2020, 06:21:14 AM
I am also confused. I can only think these must be the bushings at the top of the shackle?
redneckcustoms13
I am in line here also. I would imagine his spring have orbital eyes and as you said, these have to be the frame side of the shackle.
01 double cab hunting truck
06 tacoma street truck
swilson
Yep, yep... springs have dual orbit eyes... top of shackle has factory style bushings.
1964 FJ40 TBD
redneckcustoms13
I'm sure you are, but were you aware that lubricating poly bushings with a non synthetic grease will cause them to deteriorate?
swilson
1964 FJ40 TBD
swilson
#353
Finally wrapped up the swing out project.  Swapped out the latch for a larger one. Made a new, larger, piece out of delrin for the swing outs to rest against when closed.  Wired in some 3/4" red LEDs for brake lights... Same type as my turn signals up front.
I ended up making a bolt on license plate mount, which mounts it to the HiLift.  It uses illuminated bolts, so I'm still legal.
I found a neat waterproof switch for the LED flood light and cut a spiral cord off a test light I had that I never used, to handle the telescoping pole.
The sway bar is fantastic.  I needed it before adding the extra weight, but now even with the extra weight, it's handling much better on road.
Pretty happy with the results. Nice and sanitary.
1964 FJ40 TBD
Gnarly4X
Quote from: swilson on April 13, 2020, 09:33:06 AM
Didn't know that, thanks
I didn't either....  :disturbed:
"Polyurethane bushing manufacturers advise to never use a petroleum based grease for poly bushing lubrication. Polyurethane should only be lubricated with one specific type of grease to insure long bushing life, and squeak-free performance, Silicone based synthetic water-proof grease.
We've found this grease to be so good, we use it for the entire chassis lubrication on the cars we build and race out of our shop. It stays where you put it and doesn't wash away. This grease can be very hard to find at your local stores. This grease is available from Spohn Performance, it's our Part #902, click here to check it out."
http://www.spohn.net/shop/1982-1992-GM-F-Body/Suspension/Polyurethane-Bushing-Chassis-Grease/Polyurethane-Bushing-Chassis-Grease-14-oz-Tube.html
Gnarls.
Gnarly4X
Quote from: swilson on April 21, 2020, 10:10:58 PM
... Nice and sanitary.
swilson... You are the GURU of "nice and sanitary"!!  :beerchug:
Gnarls. :thumbs:
swilson
This was part of my swing away project that I didn't get around to doing right away.  I took the carpeted panel off the tailgate and ordered a 3/8" thick sheet of grey cutting board material.
I used a router to put a round edge on it.  The screw holes are counter sunk, but I didn't buy the stainless flat head screws yet.
1964 FJ40 TBD
gnob
Whats the purpose?  Tailgate cooking?  Or just tired of carpet jank?
Looks tight as usual.  Im in need of a router setup.  Seems more and more uses coming up.
hold this. . .
Willard
Man, I had a piece of 3/16" aluminum cut out for mine and will secure it with riv-nuts. I really like the cutting board idea as well! That stuff is not cheap either. Where did you snag a sheet of it from?
swilson
All the above.
I figured a giant cutting board would be super handy.  I do most of my cooking on the tailgate, so keeping it clean was impossible. Now cleanup will be easy
Plus, I'm considering eliminating all carpet from the rear of the 4Runner, so this was a good start
1964 FJ40 TBD
