Yes there is a rubber gasket on the top. Let me try and find a picture of it.
Ok maybe they are not rubber. Either way you can pickup the gasket rebuild kit from Marlin here: https://www.marlincrawler.com/transfer-case/parts-upgrade/tc-hilux/gasket-and-seal-rebuild-kitThese are them:
Correct. Consult a FSM if you aren't sure how they go.
I went out and looked at it. Sure enough the top plate had a bolt missing and the gasket was as thin as writing paper and torn up.I found another bolt and made a gasket. All is well. I do need to get a oil slinger though.
Without the oil slinger it will leak out the shifter. It is upside in this picture.
I just got an oil slinger in the mail. So now the question is, oil slinger, gasket then shifter base.Or gasket, oil slinger then shifter base?
Started by Big Daddy Ty Ty Engine
Started by mike86sr5 Parts Wanted
Started by mmessier2 Toyota Pickup/4Runner Tech 1979-95
Started by John Doe « 1 2 » Engine
Started by 84solidaxletoy Toyota Pickup/4Runner Tech 1979-95
