Author Topic: Is this my front seal leaking, 22RE.  (Read 5931 times)
Lobo176
  • Male Posts: 34
  • Member since Feb '16
« on: Mar 15, 2016, 06:39:13 PM »
Just want to make sure before I tear into it, is this where the front seal leaks?
Looks to be leaking on the back side of the oil pump, not from the front by the pulls. Thanks
In advance.
85 SR5 long bed, 22RE, original owner, paint, and interior.
8" lift, 35" All Terrains, 5.29's W/TRD limited slip front, Detroit rear.
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
Re: Is this my front seal leaking, 22RE.
« Reply #1 on: Mar 15, 2016, 08:18:49 PM »
How many miles?
It starts at the front seal, and smears back with airflow.    I've never seen a leak at the oil pump to front cover.
Just pop off the front pulley.
The only seal worth a damn is the Toyota one (dealer)
Lobo176 [OP]
  • Male Posts: 34
« Reply #2 on: Mar 15, 2016, 08:26:20 PM »
Don't know how many miles as this is the 2nd time now. Last time I did it was probably 15yrs ago and don't recall
It leaking at the oil pump like it seems to be now. Guess either way it's got to get torn down, thanks for
The reply. The motor has 160k on it. I'm in the process of fixing all the leaking seals before summer.
Sent from my iPad using Tapatalk
Mudder
  • Turtle Points: 3487
  • Member since May '15
« Reply #3 on: Mar 15, 2016, 08:40:30 PM »
If you're going to do the front main I'd do the oil pump as well. With Toyota seals.
  • Male Posts: 3,561
    • emsvitil's album
« Reply #4 on: Mar 15, 2016, 08:44:03 PM »
The oil pump is usually fine..................
Mudder
« Reply #5 on: Mar 15, 2016, 08:52:00 PM »
Sorry, I meant the oil pump o ring between the oil pump and front main seal housing. I know it's rare to see them leak it seems but you're in there that far and it's not to much more for a Toyota one
Lobo176 [OP]
  • Male Posts: 34
« Reply #6 on: Mar 15, 2016, 08:56:24 PM »
Thanks will replace the o ring seal also.
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #7 on: Mar 15, 2016, 09:20:22 PM »
Irs us ally not the seal, but a groove worn into the harmonic balancer itself, from the lip of the seal.
You can either get a sleeve and seal which has always worked for me  or a new harmonic balancer, or crankshaft pulley. Make sure the belt pattern matches your accessories if you do this.
  • Male Posts: 3,561
    • emsvitil's album
« Reply #8 on: Mar 15, 2016, 09:31:15 PM »
I've replaced the seal a couple of times.
Never been a groove in the pulley.
The new design Toyota seals are thinner, so you can position the lip of the seal in a slightly different spot if there just happens to be a groove.
Mudder
« Reply #9 on: Mar 15, 2016, 09:44:15 PM »
Part number 90311-45014 for the front main seal that you can put in different spots and part number 15188-38030 for the oil pump housing o ring. I bought those two for an 89 22re.
  • Male Posts: 3,561
    • emsvitil's album
« Reply #10 on: Mar 15, 2016, 09:51:44 PM »
The front seal is really easy when the oil pump isn't attached to the front cover..........
 :yupyup:
Lobo176 [OP]
  • Male Posts: 34
« Reply #11 on: Mar 15, 2016, 09:58:25 PM »
Thanks Mudder I really appreciate those P/N's
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #12 on: Mar 16, 2016, 11:42:25 AM »
I need to tear into mine too.  Been told that there is a Celica seal that is bigger.  I need to check my buddy to see what part number.  Also, I have been told to shave the inner part of the seal too.  This will help in getting it in a different location too.
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
« Reply #13 on: Mar 17, 2016, 07:13:10 AM »
I've done both, a thinner seal tapped just a hair further in than the original and I've also ran a sleeve. Both work fine.
01 double cab hunting truck
06 tacoma street truck
22RE Front Main Seal
Last post May 29, 2005, 04:53:38 PM
by Weldo
Last post May 14, 2006, 01:01:54 AM
by la bomba
Last post Jun 01, 2007, 07:20:46 AM
by weirdtimes_7
Last post Jan 22, 2016, 03:55:52 PM
by redneckcustoms13
Last post Mar 16, 2016, 06:48:41 PM
by Lobo176
