Author Topic: sas 99 taco 3.4 pros and cons of drivers drop or pass drop  (Read 5743 times)
79yota350
  • Member since Feb '08
looking to sas my taco with leafs on the cheap and easy ( relatively ) when my joints and rack take a dump here in about 20k miles. I'm sure there is a writeup somewhere here but I'm not finding one easily.  pros and cons for drivers drop and pas drop.  lefty is pricy what about adapters to run behind the 5sp to gear driven yota right hand drop? so many choices.... HELP got 2k saved for sas already.
« Last Edit: Sep 23, 2009, 10:25:52 PM by 79yota350 »
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: What axle would be easiest to sas a 99 taco
« Reply #1 on: Sep 17, 2009, 01:08:38 AM »
dana 44
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #2 on: Sep 17, 2009, 01:08:57 AM »
Early 80's Jeep Wagoneer D44
Quote
79yota350 [OP]
« Reply #3 on: Sep 17, 2009, 12:00:45 PM »
Whats a fair price to pay for the axle? and is there any specifics or different models i need to look out for?
79yota350 [OP]
« Reply #4 on: Sep 20, 2009, 12:22:09 AM »
Where can i find one? and how much. going to start buying the stuff ill need :)  i got a chevy axle out of an 80 k5 blazer but i think its to wide. id like to stay as close to the width of the rear axle as possible. its mostly a dd.  any links or help would be greatly appreciated. :)
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
Re: info needed for sas 99 taco 3.4
« Reply #5 on: Sep 20, 2009, 08:41:56 PM »
what about an fj 80 axle? too wide? i mean besides the fact that the pumkin is on the wrong side
UA 342
STEAMFITTERS
79yota350 [OP]
« Reply #6 on: Sep 21, 2009, 12:02:40 AM »
yea id rather keep it roughly the width of the rear axle.  id like to keep it drivers side drop so i can just use my stock case for now.  your rig is so nice btw i watched that build up.  My neighbor has an old hilux just like that one and it makes me wish i could fab and weld like you. :)
854RUN
  • Turtle Points: 30
  • Male Posts: 890
  • Member since Mar '06
  • 4WHEEL 4EVER
« Reply #7 on: Sep 21, 2009, 08:23:53 AM »
the second post i put a bunch of links to taco sas's:  http://board.marlincrawler.com/index.php?topic=59888.0
hope that helps
-JOSH-
79yota350 [OP]
« Reply #8 on: Sep 22, 2009, 12:29:31 AM »
thanks i was looking around and found that sky has a new sas kit out for the taco.  Anyone have any opinions about it? 1950 don't sound to bad for what you get. 7.5 in lift sounds like a lot tho.
854RUN
  • Turtle Points: 30
  • Male Posts: 890
  • 4WHEEL 4EVER
« Reply #9 on: Sep 22, 2009, 11:19:59 AM »
2K From allpro for a 3link  http://allprooffroad.com/9504tacomasas
-JOSH-
79yota350 [OP]
pros and cons for drivers drop or pass drop.  and price diforences? I'd like to do this thing right the first time. :)
854RUN
  • Turtle Points: 30
  • Male Posts: 890
  • 4WHEEL 4EVER
The drop really has to do with you t/c and your exhaust that runs down you passenger side. it will be cheaper for you to do a driver side drop. You can run your t/c you have right now and you dont have to mess with your exhaust.
what drive train do you wont to run (axle, tranny, t/c)? Do you have an axle?
if you are looking to spend around 2k that will be tuff if you dont have an axle, that will tack a good size chunk of your 2k.
good read, it will give you a good idea of the cost. he dose not have all the cost but i would bet over 3k. i Have always hear to plane on 3k to 10k to do a sas on a taco. the axle will the big kicker
http://www.toy4x4.net/sas/index2.htm
« Last Edit: Sep 24, 2009, 08:22:34 AM by 854RUN »
-JOSH-
88Rokyoat
  • Turtle Points: 2
  • Member since Sep '04
I used a ford HP 44 for my swap. The HP is nice and drivers drop made more room around the exhaust and links for me. I kept it full width tho. I also used the ford 9" rear end. I found a complete non-running 78 F-150 on craigslist for $500 and took the axles and a gas tank then scraped the rest.
like it's been said, 2K will go fast! I did a 3 link with coil overs but the little things add up quick if you dont cut any corners and build it right the first time...
heres a link to my build for some ideas. http://board.marlincrawler.com/index.php?topic=54649.0  Good luck. PRE-PLAN then Plan some more. :twocents:
stupid people shouldn't have kids.
Boheefus
  • Member since Dec '06
I have this on my Taco, with a D44 out of a Waggy. The ride is better than the stock IFS, it flexes like crazy, and is adjustable. Needs limit straps and bumpstops or you will blow out them purdy coilovers :D
79yota350 [OP]
yea i like the link setup better than leafs. but ill need to find a competent welder/fabricator on the cheap.  That's not going to be easy :(
-Matt-
  • Turtle Points: -184
  • Male Posts: 1,010
  • Member since Jul '07
  • Full throttle Rollin steady
check out this thread lots of good tech talk about pros and cons of the lefty versus passenger drop
http://pirate4x4.com/forum/showthread.php?p=9831767#post9831767
Steve97TJ
  • Male Posts: 133
  • Member since Mar '07
  • boss said pound it!
Id go for a waggy 44 or a diamond front. You can have a diamond cut for your specific WMS you want and there pretty bling and would be the more costly of the two. Waggy 44's are about 60" stock, i forget what a toyota rear is but you may would have to run a small spacer on both sides to widen it just a bit and they have an 8.5 ring gear. I got mine from a late 80s maybe early 90s grand waggy (it was the last year they made the grand wagoneer i forget what year) with a set of flat tops and lock outs for $200, which is a pretty damn good deal but i have to rebuild the whole thing anyways so that shouldnt be that bad.
Mines going in my jeep not my taco. But if i did a SAS, i'd do a drivers drop diamond 3-linked, only if money wasn't an issue. I don't like leaf springs and a link suspension isn't that complicated, just seems to scare people a lot more then it should i think. Also seems easier to make it lower with a link set up over a leaf sprung.
98 Taco
97 TJ
Stephen from SC
demasters
  • Member since Dec '08
So why not run a FJ60 Front. Thats what I have chosen. 58" wheel mount surface. I'll add spacers to get 60". Then gear drivin cases.
00taco
  • Male Posts: 156
  • Member since Feb '09
  • Cant wait to do SAS!!!
 :yesnod: i have been wondering the same Q's about doing my sas on my taco
Last post Apr 25, 2004, 03:56:43 PM
by kyle_22r
Last post Jul 30, 2006, 08:36:29 AM
by 79coyotefrg
Last post Aug 23, 2006, 01:09:15 PM
by gahaszuk
Last post Jul 02, 2009, 07:50:38 AM
by Pat
Last post Jun 07, 2010, 09:55:29 AM
by 81yotalove
