i know this is a tired subject and i have read through a bunch of threads but i cant seem to answer this question. know i will have to setup my bumpstops perfect to protect my oil pan and all that. but my question is with a flat pitman it seems you can get the box forward without cutting the rad support because on the box not being angled but your steering shaft angle is high? with a drop pitman you have to angle the box a lot to achieve the same clearance to the springs but in order to get it forward you have to go into the rad support but the steering shaft isnt really at an angle? does it really matter with the steering shaft angle?
this is the last thing i need to figure out for my hysteer setup. im only trying to clear 35's so i dont feel a drop hanger is needed and my w56 with square driveshaft with sincle u joint on both ends should take care on the pinion angle. thanks for any help.
