Author Topic: Weird switch in my 93  (Read 3788 times)
93REDCRAWLER
  • Turtle Points: 110
  • Male Posts: 563
  • Member since Nov '10
  • You see it we wheel it
« on: Dec 09, 2010, 05:21:20 PM »
in my 93 i have a yellow switch underneith my hazards. and i dont know what its for.
ive flipped it on and off and i cant see any differences. does anybody have any ideas of what it might be?
or is it just there?
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
Re: Weird switch in my 93
« Reply #1 on: Dec 09, 2010, 05:45:30 PM »
a pic would help
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
« Reply #2 on: Dec 09, 2010, 07:37:30 PM »
x2
is it stock?
factory fog lights?
93REDCRAWLER [OP]
  • Male Posts: 563
« Reply #3 on: Dec 09, 2010, 08:18:43 PM »
a pic would help
ill get a pic of it tomorrow.
x2
is it stock?
factory fog lights?
yes it is stock but i dont have any fog lights
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
« Reply #4 on: Dec 09, 2010, 08:59:29 PM »
its gotta be the chrome reverse muffler bearing actuator deflection switch :yupyup:
yoshaleng
  • Turtle Points: 134
  • Male Posts: 1,258
  • Member since Jul '09
« Reply #5 on: Dec 09, 2010, 09:41:14 PM »
No No it's not a muffler bearing switch......it's to release your turn signal fluid to your bulbs. :rofl2:
On a serious note, more than likely it's fod light switch os some kind lighting switch because got one just like it from the wrecking yard from a runner....it fits perfectly in the factory pre-cut slot. just make sure you have no power source going into it so it can't ground out.
93REDCRAWLER [OP]
  • Male Posts: 563
« Reply #6 on: Dec 11, 2010, 07:02:31 AM »
a pic would help
Heres the pixs you wanted
93REDCRAWLER [OP]
  • Male Posts: 563
« Reply #7 on: Dec 11, 2010, 07:04:24 AM »
number two
93REDCRAWLER [OP]
  • Male Posts: 563
« Reply #8 on: Dec 11, 2010, 07:07:07 AM »
well there it is in the bottom third picture.
when i was taking pics of it i noticed that i could pull it wasnt hooked to anything  you guys still think its a fog light switch?
and then in the second pic down i found this does anybody know what this is and what it runs too?
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« Reply #9 on: Dec 11, 2010, 08:48:41 AM »
looks hot wanna sell it   i have a hole there
wakkjobb
  • Turtle Points: -18
  • Male Posts: 1,590
  • Member since Dec '08
  • Back at it after 5 years!
« Reply #10 on: Dec 11, 2010, 09:00:53 AM »
Looks like an aftermarket switch that was stuck where the clutch-cancel switch went. Toyota made blank filler pieces to go on trucks that didn't have switches (base models, auto trans etc...) and plenty of people used them for switch mounting spots. I have a few like that... no big deal.
>>Dan
Quote
IronClad: If I wanted to hold hands and be nice I'd become a hippie.
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #11 on: Dec 11, 2010, 01:18:38 PM »
That was a switch that the government decided that some vehicles needed so they funded it with tax dollars and put it in a few Toyotas.  It was known as the "switch no nowhere"   :greengrin:
Quote
93REDCRAWLER [OP]
  • Male Posts: 563
« Reply #12 on: Dec 11, 2010, 04:56:43 PM »
>>Dan
Theres another switch on the far left of my dash thats for the clutch start cancel..
93REDCRAWLER [OP]
  • Male Posts: 563
« Reply #13 on: Dec 11, 2010, 04:57:35 PM »
You really wanna buy it?
stackz
  • Member since Jul '10
« Reply #14 on: Dec 13, 2010, 07:12:53 AM »
clutch cancel switch is on the left lower side of the dash on my 93...
definitely an aftermarket switch.  probably leftover from previous owner using it as an amp switch for a system he had in the truck at one point.  you can easily see it doesnt match up to that harness pigtail behind it.
probably originally that pigtail was attached to the backside of the blockoff plug in that slot.  previous owner pulled the plug out and shoved the harness pigtail back up in the dash, cut the plug to fit the switch and away they went.
truck is likely prewired for dealer installable type options such as foglights, etc.  check the wiring colors of that plug to the FSM in the how-to section and that will tell you what it is for.  might be able to upgrade your truck for cheap.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #15 on: Dec 14, 2010, 03:12:57 AM »
Most definitely an aftermarket switch for some sort of axillary lighting, amp, or other electrical device.
rage
  • Turtle Points: 26
  • Male Posts: 142
  • Member since Jul '06
« Reply #16 on: Dec 14, 2010, 06:12:25 PM »
The switch that goes there is back window de-fog. if its a truck(not 4runner)
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
« Reply #17 on: Dec 14, 2010, 07:14:09 PM »
Extra switches attract bears...
– Steve McQueen
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #18 on: Dec 14, 2010, 08:19:33 PM »
:spit:  best response yet!  For this very reason, I don't have any switches in my trucks  :gap:
SpencerS
  • Member since Oct '10
« Reply #19 on: Dec 15, 2010, 02:51:24 AM »
its the switch too add oil into your exhaust manifold to make it look like you have a diesil in your yoter with all that black smoke!
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« Reply #20 on: Dec 16, 2010, 07:37:25 AM »
omg yall come on everyone knows thats where the  jake brake switch goes so that you can put back pressure on the gas motor   :welcome: thats a easy one
[img]http://bo
snowplow
  • Male Posts: 257
  • Member since Aug '06
  • smoke tires not drugs
« Reply #21 on: Dec 21, 2010, 11:24:45 AM »
I have a base model 93 pickup and never had a switch there. I do however have the harness behind like you stubbed out. Always wondered what it was for  :willynilly:
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
« Reply #22 on: Dec 21, 2010, 12:36:28 PM »
im assuming a common wiring harness for the runner and the pu when it comes to this part, as this is were the rear defrost button would be.....  i have heard rumors that some people with pu's have had rear defrost.... but thats not for this conversation lol
Those are some huge welds!
Tillamook, OR
Dr.Maxwe001
  • Male Posts: 627
« Reply #23 on: Dec 21, 2010, 01:48:37 PM »
Quote
:whistle:
 :turtle: :turtle: :turtle:
[img]http://bo
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #24 on: Dec 21, 2010, 03:31:38 PM »
the plug goes into the factory clock
boneyard customs
  • Turtle Points: -10
  • Male Posts: 31
  • Member since Dec '10
  • Build it yourself and wheel it !
« Reply #25 on: Dec 30, 2010, 01:34:12 AM »
That switch opperates the Flux Capasitor ! Dont remove it. Secret agents are headed to your house right now. Seems they might want to have a talk with you.
Dr.Maxwe001
  • Male Posts: 627
« Reply #26 on: Dec 30, 2010, 07:30:17 AM »
No realy I aint gona lie to ya this time all jokes aside that is where the Toyota puts the little factory nitro's switch that is installed when a 2 or more little hamsters under the hood dont have enough boost its a place for the little switch that you removed   :wave:
[img]http://bo
punchyyoter85
  • Turtle Points: 31
  • Male Posts: 171
  • Member since Sep '07
« Reply #27 on: Jan 01, 2011, 08:58:58 PM »
haha i did that to my buddys 88 in high school when we had stacks on our trucks.... good ol days.
Last post Jun 24, 2004, 01:29:17 AM
by WHITE_TRASH
Last post Oct 27, 2004, 06:27:38 PM
by Mike D
Last post Mar 25, 2005, 08:49:17 AM
by UNBREAKABLE
Last post Dec 08, 2005, 02:01:21 PM
by 79coyotefrg
Last post Nov 15, 2009, 02:16:50 PM
by rockymtn89
